Mathematical induction problem
The problem involves proving a statement using mathematical induction. The original poster presents a claim that if \(x+1 \geq 0\), then \((1+x)^n \geq 1+nx\) for all integers \(n\). The discussion revolves around the induction process and the steps required to establish the validity of the claim.
  • Participants discuss the base case and induction step, with some questioning the clarity of the induction hypothesis. There is a focus on whether the expression \((1+x)^k + (1+x)^{k+1}\) is appropriate for the induction step, and participants are clarifying the correct formulation of the induction hypothesis.
The discussion is active, with participants providing feedback on each other's reasoning and clarifying points of confusion. Some guidance has been offered regarding the correct approach to the induction step, but there is no explicit consensus on the formulation of the hypothesis or the steps involved.
There is mention of potential typos and confusion regarding the expressions used in the induction step, indicating that participants are grappling with the definitions and setup of the problem.
DDarthVader
Hello! First of all I have like 5 exercises I don't quite understand so will it be a problem if I create 5 new topics in the next 24h?
Prove, by using mathematical induction that if x+1 \geq 0 then (1+x)^n \geq 1+nx.
Basic step: If n=1 then 1+x \geq 1+x which is true.
Induction Step: Now making n=k we get (1+x)^k \geq 1+kx. If the hypothesis holds for n=k then it will hold for n=k+1. Making n=k+1 we get (1+x)^k + (1+x)^{k+1} \geq 1+(k+1)x. And from this:
(1+x)^k(1+(1+x)) \geq 1+(k+1)x
But by our induction hypothesis (1+x)^k \geq 1+kx which means that (1+x)^k(1+(1+x)) \geq 1+(k+1)x is true.
Thanks!
This looks like a typo. → (1+x)^k + (1+x)^{k+1} \geq 1+(k+1)x.
And from this:
Thanks!
The induction step is:
Assume the following is true: (1+x)^k \geq 1+kx\,.
From that you need to show that the following is true: (1+x)^{k+1} \geq 1+(k+1)x\,.​
It looks to me as if you're assuming the hypothesis holds for n = k+1 .
That typo is actually not a typo. And I'm trying to say that if the ##n=k## holds then I'll try to prove that ##n=k+1## also holds by doing ##(1+x)^k + (1^x)^{k+1}##. I can write it clearer in my language. But the main problem here is ##(1+x)^k + (1+x)^{k+1}##. Is this correct?
No, the following is not correct.
If you substitute k+1 for n in \displaystyle (1+x)^n \geq 1+nx\,, then you get \displaystyle (1+x)^{k+1} \geq 1+(k+1)x\,.
By the Way: \displaystyle (1+x)^{k+1}=(1+x)^k\cdot(1+x)\,, it's not the same as (1+x)^k+(1+x)^{k+1}\,.
Maybe you're thinking of \displaystyle \sum_{n=0}^{k+1}(1+x)^n=\left(\sum_{n=0}^{k}(1+x)^n\right)+(1+x)^{k+1}\,.
