Roberto Pavani
- 9
- 3
- TL;DR
- Assuming Maxwell, Einstein or Dirac valid for any observer, is it possible to describe those equations as three different projections of a single mathematical object, with what contraint? The proposed structure link the three equations using the Hessian of an Helmholtz field in Euclidean R4 space. The constraints are non-trivial and produce falsifications but also zero-parameters predictions.
Roberto Pavani — Independent Researcher, Sestri Levante (GE), Italy
ORCID: 0009-0002-9098-1203
Full papers on Zenodo:
Lean version (proofs): DOI: 10.5281/zenodo.19599262
Extended version (phenomenology): DOI: 10.5281/zenodo.19598026
1. What this is (and what it is not)
This is not a theory of everything. It does not derive Maxwell, Einstein or Dirac — it takes all three as established empirical facts.
The question is: if all three equations are true, can they be described as three different projections of a single mathematical object? And if so, what constraints follow from this simultaneous containment?
The answer is yes. The object is the Hessian [tex]\Theta_{ab} = \nabla_a \nabla_b \theta[/tex] of the phase of a Helmholtz field in flat Euclidean [tex]\mathbb{R}^4[/tex]. The constraints are non-trivial and produce zero-parameter predictions.
2. The starting point
Consider a flat, static, four-dimensional Euclidean space [tex](\mathbb{R}^4, \delta_{ab})[/tex] — no time, no causality, no dynamics. In this space, define a complex field H obtained via the Clarke transform (positive-sequence projection) of a balanced three-phase Helmholtz triplet:
[tex]H = \frac{2}{3}(h_1 + h_2\,e^{i2\pi/3} + h_3\,e^{i4\pi/3}), \qquad (\Delta + k^2)h_\tau = 0[/tex]
The three components are not summed algebraically but projected onto a complex field via the Clarke transform (positive-sequence projection). Three is the minimum number producing a rotating phase with constant amplitude (a singlet has no rotating phase; a doublet has no balancing; [tex]N \geq 4[/tex] reduces to triplets).
The phase [tex]\theta = \arg(H)[/tex] and its gradient define a unit vector [tex]u^a = \nabla^a\theta / \lVert\nabla\theta\rVert[/tex] and a tetrad [imtexath]\{u^a, E_i^a\}[/tex]. The tensor
[tex]g_{ab} := \delta_{ab} - 2u_a u_b[/tex]
has Lorentzian signature [tex](-,+,+,+)[/tex] by construction (trivial check: [tex]g_{ab}u^a u^b = 1 - 2 = -1[/tex], [tex]g_{ab}E_i^a E_j^b = \delta_{ij}[/tex]).
Time is not postulated — it arises as the direction of maximum phase variation.
3. Three sectors from one Hessian
The Hessian [tex]\Theta_{ab} = \nabla_a \nabla_b \theta[/tex] decomposes with respect to the tube axis [tex]w^a[/tex] into three orthogonal blocks (tensorial identity, valid for any symmetric 2-tensor):
[tex]\Theta_{ab} = \underbrace{w_a w_b (w^c w^d \Theta_{cd})}_{\text{LL (time scale)}} + \underbrace{w_a \mathcal{V}_b + \mathcal{V}_a w_b}_{\text{Mixed (EM-like)}} + \underbrace{\Pi^w_a{}^c \Pi^w_b{}^d \Theta_{cd}}_{\text{TT (GR-like)}}[/tex]
Mixed block → antisymmetric extractor [tex]\mathcal{F}_{ab} = w_a \mathcal{V}_b - \mathcal{V}_a w_b[/tex] satisfies [tex]d\mathcal{F} = 0[/tex] exactly for constant [tex]w^a[/tex] (proved: the third derivative [tex]T_{cab} = \nabla_c \nabla_a \nabla_b \theta[/tex] is totally symmetric in flat space). This is Maxwell's first equation.
TT block → extrinsic curvature [tex]K_{ab} = (\mathbb{G}_{\text{op}})_{ab}/\lVert\nabla\theta\rVert[/tex] of the equal-phase hypersurfaces. Via Gauss–Codazzi–Ricci, this gives the full Riemann tensor of [tex]g_{ab}[/tex]. By Lovelock's theorem, the unique field equation is Einstein's equation [tex]G_{\mu\nu} + \Lambda g_{\mu\nu} = \kappa T_{\mu\nu}[/tex].
Helmholtz factorisation → [tex]({\not\!\partial} - ik)\Psi = 0[/tex] via [tex]{\not\!\partial}^2 = \Delta[/tex]. The complexified Clifford isomorphism [tex]\text{Cl}(4,0) \otimes \mathbb{C} \cong \text{Cl}(1,3) \otimes \mathbb{C}[/tex] maps this to the Dirac equation.
4. The fundamental constraint: Pythagorean decomposition
Since the three blocks are orthogonal projections of the same tensor:
[tex]|\Theta|^2 = (\text{LL})^2 + |\mathcal{F}|^2 + |\mathbb{G}_{\text{op}}|^2[/tex]
This is a pointwise algebraic identity. The physical consequence: the three sectors share a fixed total norm. A change in one must be compensated by the others. Inter-sector energy convertibility (EM ↔ gravitational ↔ mechanical) is a theorem, not an empirical input. No action, Lagrangian or Noether symmetry is required.
5. Quantitative predictions (zero free parameters)
Three lepton families
The radial profile [tex]j_1(\kappa r)[/tex] (spherical Bessel, [tex]\ell = 1[/tex]) has zeros at [tex]a_1 \approx 4.493[/tex], [tex]a_3 \approx 10.904[/tex], [tex]a_5 \approx 17.221[/tex]. The three-phase twist-closure condition selects exactly the odd zeros (the even zeros miss by exactly [tex]120° = 2\pi/3[/tex], one triphase offset). This gives three families:
Electron: reference
Muon: [tex]m_\mu/m_e[/tex] predicted = 212.0, experimental = 206.8 (deviation +2.5%)
Tau: [tex]m_\tau/m_e[/tex] predicted = 3308, experimental = 3477 (deviation −4.9%)
Mass formula: [tex]m_i/m_e = (a_i/a_1)^6 \cdot (\phi(a_1)/\phi(a_i))^2[/tex], where the exponent [tex]6 = 2 \times \dim(\ker u)[/tex] (volume scaling × energy quadraticity) and [tex]\phi(a_n)[/tex] is the accumulated twist of the transverse frame.
Anomalous magnetic moment
The Dirac factorisation gives [tex]g = 2[/tex] pointwise. The finite radial profile of [tex]j_1[/tex] creates a mismatch between the internal energy distribution (TT block, [tex]\int j_1^2\,dr[/tex]) and the far-field reconstruction (TL block, [tex]\int j_1'^2\,dr[/tex]). An exact Bessel identity gives:
[tex]\mathcal{E}_{\text{TL}} = \mathcal{E}_{\text{TT}} - \int_0^{a_1} \frac{j_1^2}{r^2}\,dr[/tex]
Combined with the Malus projection (holonomy of the transverse frame, [tex]\sin^2\phi(a_1)[/tex]) and the angular normalisation [tex]3/(4\pi)[/tex]:
[tex](g-2)/2 = 0.001\,160 \quad \text{(elliptic closure, deviation } +0.016\%\text{)}[/tex]
Experimental: [tex]0.001\,159\,652\dots[/tex] — zero free parameters.
The structure [tex]\alpha/(2\pi)[/tex] is identical to Schwinger's formula, but here [tex]\alpha[/tex] is the geometric closure asymmetry forced by [tex]d\mathcal{F} = 0[/tex] (no monopoles), not the fine-structure constant inserted by hand.
6. Falsification conditions
The framework makes explicit predictions that can be violated:
Magnetic monopole discovered → framework falsified ([tex]d\mathcal{F} = 0[/tex] is a theorem)
Point charge observed (exactly zero size) → falsified ([tex]C^\infty[/tex] regularity)
Fourth lepton family → falsified (three-phase closure admits exactly 3)
Lepton with extra quantum number beyond spin and charge → falsified ([tex]\ell = 1[/tex] exhausts the degrees of freedom)
Curvature everywhere accompanied by EM signal → falsified (nodal regions necessarily exist)
White hole observed → falsified ([tex]d\theta/ds > 0[/tex] everywhere)
Gravitational dynamics beyond Einstein (massive spin-2, non-metric torsion) → falsified
All conditions are consistent with current observations.
7. What the framework does NOT do
Does not derive Maxwell, Einstein or Dirac — takes them as facts
Does not explain why Helmholtz, why three phases, why [tex]\ell = 1[/tex]
Does not replace QED, QCD or the Standard Model
[tex]\kappa[/tex] (Newton's constant) is empirical, not derived
The framework provides an algebraic bridge between the three theories whose consequences — energy conservation across sectors and retroprojection constraints — are theorems, not assumptions.
8. Summary
Starting from three postulates (flat [tex]\mathbb{R}^4[/tex], three-phase Helmholtz field, operational observer), the Hessian of the phase decomposes into Maxwell, Einstein and Dirac sectors. The sectors share a fixed total norm (Pythagorean constraint), producing:
Structural constraints: no monopoles, no point sources, zero total charge, EM-silent curvature regions, exactly 3 lepton families
Zero-parameter predictions: mass ratios (2–5% accuracy), [tex](g-2)/2 = 0.001160[/tex] (+0.016% deviation)
Falsification conditions: 7 explicit conditions, all consistent with current data
The image [tex]\text{Im}(\pi) \subsetneq \mathcal{S}_{\text{EM}} \times \mathcal{S}_{\text{GR}} \times \mathcal{S}_{\text{Dirac}}[/tex] is a proper subset: the restrictions are the content of the framework.
References:
R. Pavani, Lorentzian Structure, Maxwell and Dirac Equations Linked by the Algebraic Decomposition of the Hessian of a Harmonic Phase, Zenodo (2026), DOI: 10.5281/zenodo.19599262
R. Pavani, Physical Structures Contained in the Hessian of a Harmonic Phase: a Spectral Functional Framework, Zenodo (2026), DOI: 10.5281/zenodo.19598026
Critical feedback welcome, particularly on the TT/TL identification with the gyromagnetic ratio and the twist-closure family selection.[/tex]
Electron: reference
8. Summary
References:
