Mean distance between points of 2D array
  • Context: Undergrad
  • Thread starter Thread starter cosmik debris
    2d Array Mean Points
5 replies · 3K views
cosmik debris
Say I have an N X N array of points, I would like a formula to give the mean distance between the points. There are lots of short distances but only two long ones (diagonal). There are plenty of algorithms to do this but I would like to work out a formula if there is one. Can someone point me in the right direction?
Thanks
Mathematics news on Phys.org
Yeah I know how to calculate the distances, and I meant median not mean.
My initial thoughts:
Number of points will be N², so number of distances will be N²(N²-1)/2.
So if theses distances were sorted by length, the one you would be looking for would be near N²(N²-1)/4.
As it turns out, N²(N²-1)/4 is always an integer, so it will always be possible that to get the median, you will be averaging between two values.
The number of distances of value 1 will be: 2·N(N-1)
The number of distances of integer value M will be: 2·N(N-M)
The number of distances of √2 will be 2·(N-1)²
Skipping to infinity:
When N is very large, the median distance between a corner point and all other points would be the radius of an arc that divides the square into equal areas: √(2N/π)
In contrast, a point near the center would be half that: √(N/2π)
Don't have time for more thinking right now.
Nasty problem.
Yes it's tricky. We managed to get a closed form solution for the continuous case and as it turns out it did give us an insight into our problem. In case you're interested; this is a massive MIMO investigation. We were trying to compare a linear array of antennas to a square array. It turns out that a linear array say 10m long is equivalent to a square array of about 6m X 6m, not really any improvement.
