Mechanical Energy Based Civilization?
46 replies · 6K views · last reply
bob012345
Just for fun, suppose electrical energy had never been developed but technology had continued to advance after Classical Physics was well understood. What do you suppose the technology would look like by now in a fictional alternative timeline?
Clockwork. Venus Rover
Photo of a large brass and iron mechanical calculating machine with rows of toothed gears and stacked columns of numbered wheels, mounted on a wooden base with crank handles and flywheels.
Photo of a wooden punched card frame on a loom, with rows of punched holes in stacked card sections hanging above a fabric-covered mechanism.
Ok, but I wonder what that would be like after 150 years of mechanical development? And would we all have some kind of general mechanical power hooked up to our houses, businesses ect.?
Hydraulics and pneumatics would replace electric motors.
Diesel and steam engines would be common.
Shares in the railways would be a good investment.
Aircraft would have diesel engines.
Wind and water mills would still be widely used.
Computations would be mechanical, or by high speed pneumatic logic circuits.
Punched card data would be processed mechanically, or pneumatically.
We would communicate over distance by reflecting sunlight with mirrors.
Lighting would be by gas, or chemical phosphorescence.
Books would be used for education.
Perhaps steam could power a general system of mechanical or fluidic motion in a closed loop around a city?
I’m interested in thinking how far they could push it. For example, mechanical transistors at the sub-millimeter level. Mechanical displays screens with thousands of pixels? Memory ‘chips’ with millions of bits?
Back in the 1950s we had miniature pneumatic logic gates, including flip-flops, that would work as bi-stable memory elements. The moving fluid was air, steered by air, not by mechanically changing the circuit.
Here are "modern" long-distance signaling systems
Carlisle, Mass
Printed table titled Fire Alarm System Codes listing numbered codes 323 to 335 with street names such as South Street, Wildwood Drive, Heald Road and Berry Corner Road, plus a side box explaining horn pause patterns.
Naval:
Sailor in a light blue shirt with dark trousers, seen from behind, raising two signal flags overhead on a ship's deck, with grey warships and a calm blue sea in the background.
Row of maritime signal flags, including red and yellow, blue and white, red and blue, black and yellow, and a blue Saint Andrew's cross flag, flying against a clear blue sky beside ship rigging.
Transportation might be similar given steam, diesel and IC engines. Vacuum tubes would literally be long flexible cylinders using high and low pressure gases to send written and coded messages in containers that travel within the tubes, similar to pneumatic tube systems still in use in older office buildings and department stores. Probably pneumatics would be in much greater use, perhaps ubquitous, in place of electric appliances.
Telecommunication would be slow, clumsy, possibly nascent, compared to using electronics. For instance, telegraphs might use physical flags and telescopes. Wires might be used but would physically nudge switches and slide along guides similar to a railroad switch yard. Light signaling using chemical and natural sources such as sunlight might be highly developed. See heliographs.
Given that light would still be studied even without electronic theory, sophisticated signalling technology, possibly even chemical lasers, might develop. This may violate the OP's mechanical stricture.
If this thread were in the Science Fiction subforum, I would direct attention to a popular SF short story from 1940s where post WWII Earth lost the ability to generate and use artificial electromagnetic fields due to alien intervention. See "The Waveries" by Fred Brown.
In the early days of sending electrical energy to homes, there was debate as to the best method to send power to homes. It was considered to pipe high pressure air or high pressure water to homes instead of electricity.
Cable cars
Some HVAC still uses pneumatic controls. They can be quite sophisticated.
To some extent that's what steam punk and diesel punk are about.
How about [natural] gas? I don't think people realize how much more power a home can get from a gas hookup vs electrical. I think my townhouse's electrical system has a capacity of 24 kW, but my gas system is 290 kW.
The ultimate of non-electrical use of energy would be biological things. However, they do have some internal "electrical power" uses.
Many very small parts whose replacement is built into the functioning of the system.
Fairly efficient. Use chemical energy. Require environments that are compatible with them (supply of energy and resources, removal of wastes).
Can make more of themselves.
I’m wondering how to make a bright light like a headlight without burning fuel or using a chemical reaction but just using mechanical energy?
What have you discovered so far?
Phosphorescense and fluorescence come to mind where materials could be exposed to sunlight then concentrated with lenses and parabolic reflectors but the light would not be bright. Think taillights and warning lights rather than headlights.
Cerenkov radiation does not necessarily require electricity nor strictly chemical reactions and can be quite bright, if a bit ghastly. Typical Cerenkov sources do not seem very portable, as for headlights. The Wright brothers of aircraft fame experimented with bicycle headlights powered mechanically but biographies did not reveal their experimental
light emiting components.
@BillTre appears on a productive path with biological light sources such as the (relatively) brightly lit lures used by angler fish and certain cephlapod photophores. Biolumenescent organisms can be captured and concentrated but lumen output likely weak. Of course these involve chemical reactions.
During the 1989 Loma Prieta earthquake in Scotts Valley CA, several witnesses reported flashes of light from intense ground movements. Mechanical light not easily translated to vehicles but an interesting data point.
If infrastructure and vehicles were phosphorescent, we would not need to shine our headlights into the eyes of the oncoming traffic.
Our headlights now make up for the lack of marker lights on the objects we need to avoid. As retroreflectors become more efficient, and headlights become more powerful, we blind ourselves to the things that are not illuminated, things hidden in the contrast of the shadows.
Low energy biological or chemical lighting, should be applied to all potential targets. High energy lighting should not be used to illuminate everything, including the target.
We see the silhouette of black things, against an illuminated background. For example, trains crossing roads at night, do not reflect light. Reflectors, on the viewer's side of the track, blind the driver. Reflectors, on the opposite side of the track, would outline the moving train, in silhouette.
Read Girl Genius comics, available online.
I was thinking hypothetically of using mechanical energy combined with friction to make a light source.
If you allow burning, a Carbide Lantern comes to mind:
"Like all carbide lamps the base would be filled with calcium carbide, while the top of the lamp would hold water. Water dripping onto the calcium carbide in the lower chamber produced a chemical reaction which generated acetylene gas, which could be lit to provide a bright flame."
(from:https://summerhillcuriosities.com/e...-engineering-co-crestella-carbide-miners-lamp)
See also: https://en.wikipedia.org/wiki/Carbide_lamp
I find this this thread both interesting historically and thought provoking.
I first thought of childhood toys (1950s) that generated considerable light and sparks by running metal strips against a grate using the same coiled spring mechanism that powered the wheels on a small model car. The light was bright enough to see outdoors in bright sunlight.
This led to considering 'sparking' devices, once common technology used for igniting gaslights and fireplaces, later discovered to be source of EM radiation and radio interference. Early mechanical igition devices for automobiles also generated EMr, though not AFAIK, in the visible light spectrum
Consider also meteors entering the Earth's atmosphere. Mechanical energy generates light (and sound) plus ionization tracks from exited elements in the atmosphere. This leads to considering cosmic rays that generate light on scintallation (from the Latin word for spark) detectors.
Perhaps these examples of light generated from mechanical sources might spark practical technology. :cool:
A Computer made of Lego? | Mechanical Logic - 2in1 Bricking
Mechanical Square Root and Sine Calculator | Lego Technic
A Mechanical Calculator in LEGO
or analog means like slide rules, Curtas, Addiators, abacuii, water clocks,
or mentally via Trachtenberg math, or origami folds.
