Melting Ice Caps and Sea Level Rise: Separating Fact from Fiction
The discussion revolves around the implications of melting ice caps on sea level rise, particularly in the context of climate change. Participants explore the principles of displacement and the effects of ice melting in both freshwater and saltwater environments, as well as the broader geological factors influencing sea levels.
  • Some participants assert that melting ice cubes in water do not raise the water level, questioning the validity of claims that melting ice caps contribute to sea level rise.
  • Others propose scenarios involving ice in saltwater, suggesting that the water level may behave differently due to density variations.
  • One participant notes that neither the Greenland nor Antarctic ice sheets are floating, which is a critical factor in understanding their contribution to sea level rise.
  • Another participant mentions that substantial loss of ice mass on land could lead to land rising due to reduced load, potentially affecting sea levels further.
  • Some argue that geological factors, such as the movement of the ocean floor and land masses, play a significant role in sea level changes, possibly overshadowing the effects of melting ice caps.
  • There is a discussion about the density difference between freshwater and seawater, with some claiming it is a minor factor in the overall displacement caused by melting ice.
  • Participants also question whether the salinity of the ice (frozen saltwater vs. freshwater) affects the melting process and its implications for displacement.
Participants express differing views on the impact of melting ice caps on sea levels, with some supporting the idea that it does not contribute significantly due to displacement principles, while others highlight the complexities of the issue, including geological factors and the nature of the ice itself. The discussion remains unresolved with multiple competing perspectives.
Participants acknowledge various assumptions about the nature of ice, water displacement, and geological influences on sea level, but these assumptions are not fully explored or agreed upon.
solarmidnightrose
TL;DR
the displacement of water and its possible connection to the claims made about climate change.
I'm pretty sure that everyone knows that if you put an ice cube in a cup of water, and leave it for some time for the ice to melt, the level of water in the glass will not rise. (you could use that principle where that guy was in the tub and said "Eureka!" and then ran around naked).
Now, my question is that with all this climate change business on the news, etc... is it correct for people to say that the ice-caps are melting and are causing the sea levels to rise? I mean, the ice-caps were already in the water, and so if they melt, would it cause a rise in the sea levels?
What's your take on this?
I'm really curious.
Thanks for reading!
What if you had an ice cube floating in salt water, and the ice cube melted.
Would the water level in the glass stay the same, rise or lower?
solarmidnightrose said:
Summary: the displacement of water and its possible connection to the claims made about climate change.
I'm really curious.
Thanks for reading!
You should do some research on this. For example:
https://en.wikipedia.org/wiki/Sea_level_rise
Ok, the water level would rise; because of the differing densities of the substances.
I guess I should have thought more about that before posting this.
Thanks for opening my eyes:)
Yeah, I realized my mistake a couple of minutes after posting this.
At the time I just posted my question without actually doing any research myself (you know those moments when you're just thinking about something & the obvious is right in front of you but you can't see it?... that's what I just did).
Thanks though for your input :)
The link was very informative, thanks.
Neither the Greenland nor the Antarctic ice sheets are already in the water.
Yeah, sorry about that @Nugatory . I wasn't thinking properly (I guess I was writing things down rather impulsively and without much thought).
Originally, I was thinking about the land (which has the ice sheets on it) being in the water and what effect the melting of the ice sheets would have on the water level. But I've realized some other points that needed to be considered from previous answers to my question.
Thanks for pointing it out though-really helped with further cementing the idea into my head :)
I heard that substantial loss of ice mass on land would result on the land rising due to reduced load. That could lead to further lowering of sea beds and some land levels. More potential problems.
another factor for sea level rise is the rising and moving ocean floor and land masses that encompass the oceans. it is safe to say that they are constantly in motion rising and falling which is a much greater factor than the sea level rise due to melting icecaps, that are not floating already on the ocean. (north pole melt, besides greenland is floating). sea level rise has always been near 7" per 100 years and this rate doesn't seem to be changing. and if it did, there could be many other factors rather than sea ice melting. the density differnce of sea water to fresh water a fairly minor component 2% the density of the sea water is a non factor, as Archimedes proved. fresh water floating on the sea water will displace exactly the same amount of sea water as it melts, even if it had millions of kg of gold sitting on top!
the water level would stay the same... unless you know something i dont. the buoyant force will equal the weight of the medium it displaced .
Does it matter whether the ice cube is frozen salt water or fresh?
The process of freezing tends to leave you with more or less pure ice and the salt goes into the seawater underneath, I think. That's not to say that the ice is totally pure because salt can be trapped in gaps between the ice crystals.
  • · Replies 52 ·
  • · Replies 55 ·
13K
  • · Replies 27 ·
  • · Replies 85 ·
9K
  • · Replies 21 ·
  • · Replies 19 ·
