Minimizing the sum of squared deviations from a parameter a
  • Thread starter autre
    Function
7 replies · 2K views · last reply
autre
Let [itex]f(a)=\frac{1}{n-1}\sum_{i=1}^{n}(x_{i}-a)^{2}[/itex]
Find the value of a that minimizes f(a) by replacing [itex](x_{i}-a)[/itex] by [itex]((x_{i}-\bar{x})+(\bar{x}-a))[/itex].
2. The attempt at a solution
[itex]f(a)=\frac{1}{n-1}\sum_{i=1}^{n}((x_{i}-\bar{x})+(\bar{x}-a))^{2}=\frac{1}{n-1}\sum_{i=1}^{n}((x_{i}-\bar{x})^{2}+(\bar{x}-a){}^{2}+2(x_{i}-\bar{x})(\bar{x}-a))=\frac{1}{n-1}[\sum_{i=1}^{n}(x_{i}-\bar{x})^{2}+\sum(\bar{x}-a){}^{2}+\sum2(x_{i}-\bar{x})(\bar{x}-a)][/itex]
I'm a little stuck here. Any ideas?
autre said:
Any ideas, guys?
Try using [itex]\sum_{i=1}^{n} x_{i}=n \bar{x}[/itex].
[itex]f(a)=\frac{1}{n-1}\sum_{i=1}^{n}((x_{i}-\bar{x})+(\bar{x}-a))^{2}=\frac{1}{n-1}\sum_{i=1}^{n}((x_{i}-\bar{x})^{2}+(\bar{x}-a){}^{2}+2(x_{i}-\bar{x})(\bar{x}-a))[/itex]
[itex]=\frac{1}{n-1}\left[\sum_{i=1}^{n}(x_{i}-\bar{x})^{2}+\sum(\bar{x}-a){}^{2}+\sum2(x_{i}-\bar{x})(\bar{x}-a)\right][/itex]​
In your final expression, the first sum doesn't depend on a. It's easy to make the other two equal to zero. Is that the minimum possible?
Is the third sum equal to zero for all values of a ?
I know that the minimum should be the mean a = 1\n[itex]\sum x_i[/itex]. How do I make the other two equal to zero?
What is [itex]\Sigma^n_1 (x_i-\bar{x})[/itex]?
Do you realize that [itex]\bar{x}[/itex] is:
[itex]\displaystyle\bar{x}=\frac{1}{n}\sum_{i=1}^{n}x_i \,?[/itex]​
So you're saying that the solution is [itex]a=\bar{x}\,.[/itex]
