Minimum separation between pucks
  • Thread starter Thread starter GingerKhan
    Minimum Separation
The discussion revolves around calculating the minimum separation between two frictionless pucks with given masses and charges. Participants emphasize the importance of conservation of energy and momentum in solving the problem, highlighting the exchange between kinetic and electric potential energy as the pucks approach each other. Initial calculations led to an unrealistic minimum separation, prompting a reevaluation of the velocities using the center-of-momentum frame. By correctly assigning negative values to one of the initial velocities, a more realistic minimum separation of approximately 8.63 m was determined. The conversation underscores the significance of careful calculations in physics problems involving interactions between charged objects.
GingerKhan
Two frictionless pucks are placed on a level surface at an initial distance of 20.0 m. The mass of puck 1 is 0.80 kg and it has a charge of +3.0 X 10^-4 C., while puck 2 is 0.40 kg with a charge of +3.0 X 10^-4 C. the initial velocity of puck 1 is 12.0 m/s (E) and the initial velocity of puck 2 is 8.0 m/s (W). Find the minimum separation of the two pucks.
I've got no idea where to start. I suppose the total electric force has to cancel out the net force of the two pucks?
Think in terms of conservation of energy. What forms of energy are at play here?
Would it be kinetic energy?
That's one. There's another.
Electric potential energy?
Yup. There will be an exchange between kinetic energy and electric potential energy as the pucks approach each other.
Hi, I'm confused about this question as well, so I thought I would revive this thread instead of starting a new one.
I believe I might have done it correctly, but the answer I got doesn't seem too realistic, so I would definitely appreciate it if someone could check my work!
First, I found the total energy of the system to be 110.9 J by finding the sum of the kinetic energy and electrical potential energy at a distance of 20.0 m.
Then, I used conservation momentum since the velocity of the two masses will be the same when they're at minimum separation.
v = ((0.8)(12) + (0.4)(8.0)) / (0.4 + 0.8)
v= 10.67 m/s
Then, to find the distance at minimum separation, I set the sum of the new kinetic energy (with v = 10.67 m/s for both masses) and the electrical potential energy equal to 110.9 J.
This yields a distance of 19.0 m or thereabouts, which is only 1 m away from where they started, which leads me to believe that this isn't a realistic answer. Also, I don't understand why the velocities of the two masses are the same at the point of minimum separation. My book simply stated this fact without elaborating. I don't feel too confident about this...
The velocity v that you calculated should be the velocity of the center-of-momentum frame of reference. As such you need to be sure not to drop the signs of the velocities when calculating it!
Note that you could, if you wish, move all your calculations to that new frame of reference by adding v to each of the original velocities. What's the new KE there? In that frame the pucks will have zero velocity when they have minimum separation, making KE calculation for that moment easy!
The center of momentum frame is useful for collision problems because at the instant the collision is taking place the two objects are at the origin of that frame and motionless for an instant. In this case where the collision is "soft" (the charges prevent physical contact) they will be motionless with some separation between them.
Any object with zero velocity in the center-of-momentum frame will have, in the original frame of reference, a velocity equal to that of the center-of-momentum frame's.
Thanks for the reply!
That's very interesting, I didn't realize that. So, if I assign a negative value to one of the initial velocities, then the magnitude of the conservation of momentum calculation becomes 5.33 m/s instead of 10.67 m/s.
With this new velocity value, the distance becomes 8.63 m instead of 19.0 m, which seems more realistic, I think...
Is that better?
Is that better?
Yes, that looks much better!
Thanks a lot! In retrospect, it was a foolish mistake.
If the velocity had been 10.67 m like I had originally thought, then the momentum would not have been conserved at all. In fact, the momentum at the point of minimum separation would have been twice the value that the system started with! Rookie mistake.
Thanks again.
Glad to be of help!
