My reasoning: the inverse secx not the reciprocal of inverse cosx?
The discussion clarifies the misconception that the inverse secant function (arcsec) is the reciprocal of the inverse cosine function (arccos). It establishes that while sec(x) = 1/cos(x) holds true, the domains of these functions differ significantly, leading to the conclusion that arcsec(1/cos(x)) does not equal 1/arccos(x). Instead, the correct relationship is arcsec(x) = arccos(1/x), which was confirmed through various trigonometric identities and examples. The participants emphasized the importance of understanding these domain differences when working with inverse trigonometric functions.
  • Understanding of trigonometric functions and their inverses
  • Familiarity with domain restrictions of trigonometric functions
  • Knowledge of trigonometric identities
  • Basic calculator operations involving inverse functions
  • Study the domain and range of inverse trigonometric functions
  • Learn about trigonometric identities and their applications
  • Explore the relationship between arcsec and arccos through examples
  • Practice using calculators for evaluating inverse trigonometric functions
Students, educators, and anyone studying trigonometry who seeks to deepen their understanding of inverse trigonometric functions and their properties.
anniecvc
This came up when I was trying to evaluate to a decimal value an arcsec(something), but on TI-83 there is no inverse secant button. So, I punched 1/(arccos(something)). Naturally, this came up as a domain error.
Then my instructor pointed out arcsesc is not 1/arccosx. Oops.
Thinking about it, the domain of the cos-1x is [-1,1].
The domain the sec-1x is (-∞,-1]U[1,∞).
So although secx =1/cosx is an identity, it could not be the case for the inverses since there is a discrepancy in domain.
Also, the inverse cosine is the function which takes the y value and maps it to the x value, e.g cos-1(1/2) = ∏/3. The inverse secant for this domain value of 1/2 would be...well it wouldn't be since this value is not in the domain of the arcsec! That is an example of why the arcsec is not the multiplicative inverse of arccos.
Is there anything I should add or other pressing points or ways of looking at this?
Yes. You can also see this by playing around a bit with the definitions.
arcsec(x) is the value y such that sec(y) = x, in other words, arcsec( 1/cos(x) ) = x.
If you look at 1/cos(1 / arccos(x)) you don't get x back. The best you can do is plug arccos(x) into the secant and get sec( arccos(x) ) = 1/cos( arccos(x) ) = 1/x, leading to the identity 1/sec(arccos(x)) = x.
Combining these, you can conclude that
arcsec(1/cos(x)) = 1/sec(arccos(x)).
You can try numerous tricks like taking the secant on both sides,
1/cos(x) = sec(1/sec(arccos(x)),
but because of the pesky 1/...'s you cannot get your (inverse) trig functions to cancel out.
##\operatorname{arcsec}(x) = \arccos(1/x)## works quite nicely, as do ##\cos(\operatorname{arcsec}(x)) = \sec(\arccos(x)) = 1/x##.
As others have said, playing around with trig identities can give you interesting simplifications for nested trig functions. For instance;
##\sin^{2}x + \cos^{2}x = 1 \implies \sin x = \sqrt{1 - \cos^{2}x} \implies \sin(\arccos x) = \sqrt{1 - x^2}##.
Try finding an expression not involving a trig function for ##\sec(\arctan x)##, and perhaps other combinations if you're interested, e.g. ##\sin(\arctan x)##.
Question:
Let x=sint => arcsinx = t
sin2t + cos2t = 1
cos2t = 1 - sin2t
cos2t = 1 - x2
cost = + (1-x2)1/2
cos(arcsinx) = (1-x)1/2
But why is it necessarily the positive root of cos2t that we take? I don't believe the "lengths of a side of a right triangle" argument suffices, since x can be a positive or negative number. I want to argue that since we are taking t = arcsinx,
then 0 ≤ t ≤∏, but then the cos t for
∏/2 < t ≤ ∏ is negative, so it's not guaranteed that the root is positive.
Hm interesting, I worked it out and it does seem to be the case. So in the future, I now know what to input into my calculator if I wanted to find an arcsecx. Thank You!
