Need help solving review problems for math contest
  • Thread starter ballaholic8
    Contest
1 reply · 3K views · last reply
ballaholic8
Hey guys I am preparing for a math contest and this is a review set that we have recieved, however i have no idea how to answer these questions,
Can someone please help with some reasonable solutions with some explanation.
Thanks
  • Printed text of two math contest problems: problem 18 about a circle with centre O and tangents PQ and PR from external point P, proving angle POQ equals angle POR; problem 19 about factor 3x - 5 of f(x) = kx^2 - bx + k, finding k:b.
  • Geometry diagram of right triangle PQR with a right angle at R; point S lies on hypotenuse PQ, and segment RS is drawn perpendicular to PQ with a right-angle mark at S. Labels: P, Q, R, S.
  • Printed text of two math contest problems. Problem 24: Two concentric circles have radii 9 cm and 15 cm. Determine the length of a chord of the larger circle that is tangent to the smaller circle. Problem 25: Given a function g(x) such that g(x^2 + 2) = x^4 + 5x^2 + 3, determine g(x^2 - 1).
18. As in all geometry problems, draw a diagram. Draw in the angles you need to find. See if you can go from there.
19. What does it mean for 3x-5 to divide kx2-bx+k? It means that [itex]kx^2-bx+k=(3x-5)q(x)[/itex] for some polynomial q(x). It also means that if we set 3x-5=0, then the original quadratic will be 0 too. That is, when x = 5/3, kx2-bx+k=0, so 5/3 is a root of the quadratic. Every quadratic can be factored as follows: [itex]ax^2+bx+c=a(x-r_1)(x-r_2)[/itex] where r1 and r2 are the two roots of the quadratic. Thus, you can write [itex]kx^2-bx+k=k(x-5/3)(x-r_2)[/itex]. Multiply out and find out what r2 must be. You then can find k/b.
20. Which triangles are similar in that picture?
24. Again, draw a picture (this is a common theme in geometry problems), and try to draw a triangle using the information you have available.
25. Suppose [itex]y=x^2+2[/itex]. Then, you can rewrite [itex]g(x^2+2)[/itex] in terms of y, so you would have g(y) = some function of y. Notice then that [itex]g(x^2-1)[/itex] is merely g(y-3).
