Neutron Isomerie: Can Neutronium Have Metastable Stage?
  • Context: Graduate
  • Thread starter Thread starter Garlic
    decay isomers neutron
The discussion centers on the concept of neutronium potentially existing in a metastable nuclear isomer state, which could theoretically extend its half-life. While excited states of hadrons typically have shorter half-lives than ground states, examples like sodium-22m and 180mTa illustrate that certain isomers can exhibit longer half-lives than expected. The conversation highlights that single hadrons do not demonstrate metastability, as they decay rapidly via strong or electromagnetic interactions, while weak interactions result in slightly longer lifetimes. The Pauli effect and bound-state beta decay are also discussed as significant phenomena affecting half-lives in nuclear physics.
  • Understanding of nuclear isomers and half-lives
  • Familiarity with hadron physics and decay processes
  • Knowledge of the Pauli exclusion principle and its implications
  • Basic concepts of strong, electromagnetic, and weak interactions
  • Research the properties and implications of nuclear isomers, focusing on 180mTa
  • Study the Pauli effect and bound-state beta decay in detail
  • Explore the differences between strong, electromagnetic, and weak interactions in particle physics
  • Investigate the role of excited states in hadron decay and their implications in astrophysics
Physicists, nuclear researchers, and students interested in advanced nuclear physics concepts, particularly those focusing on isomer stability and decay processes.
Garlic
Hello everyone,
Can a hadron be in an excited stage? If yes, can neutrons -the element- neutronium have a nuclear isomer in a metastable stage, making it have a longer half life?
Yes, but hadrons with the same quark content but different internal configuration will generally be listed as separate hadrons.
Excited states generally have shorter half-lives than the ground states.
[QUOTE="Excited states generally have shorter half-lives than the ground states.[/QUOTE]
I understand, but aren't some Isomers of an Atom (Sodium-22m for example) have longer half live, and the letter "m" is put in order to indicate that it is an Isomer with a higher half life?
The m means that it is more stable than you would typically expect. It does not mean that it is more stable than the ground state. For example sodium 22 has a half life 2.6 years while sodium 22m has a half life of roughly 250 ns.
Okay. Thank you..
There are nuclear isomers with a longer half-life - most notably 180mTa where no decay has been observed so far (half-life > 1015 years) while the ground-state has a half-life of just 8 hours.
Single hadrons don't show such metastability. If they can decay via the strong or electromagnetic interaction they do so within ~10-20 seconds. If they can decay via the weak interaction only they live longer, but apart from the neutron "longer" still means pico- to nanoseconds.
Here's the explanation for this astonishing phenomenon. It's a drastic example for the application of selection rules:
http://en.wikipedia.org/wiki/Nuclear_isomer#High_spin_suppression_of_decay
Another drastic change in halflife of a beta-decaying nucleus can be due to the Pauli effect, the socalled bound-state beta decay. A nice example is Re187. This isotope as a neutral atom has a half-life of about ##40 \cdot 10^{9} yr##. As measured in the storage ring at the heavy-ion research center in Darmstadt (GSI), the half-life of a Re187 ion is only about 33 yr! The reason is that the beta-decay electron cannot be emitted easily in the case of the atom with all its electrons around, because it's energy is such that it would have to end up in an occupied atomic state.
That's pretty important in astrophysics, as you can read here:
http://www.euroschoolonexoticbeams.be/site/files/nlp/LNP651_contrib5.pdf
  • · Replies 20 ·
