Nissan Leaf charging current and cost calculation
  • Thread starter Thread starter nchin
5 replies · 2K views
nchin
The Nissan leaf is powered by 107 hp electric motor, kept alive by a pack of batteries, It takes 79.85 kilowatts to run the motor, assuming 100% efficiency.
a) The Nissan contains a 24kWh battery pack and its estimated that using a 220V charging dock at home. The leaf can be charged in 8 hours. What the current as the leaf is charging?
b) if it cost 11 cents perkilowatthour, how much does it cost to fully charge the leaf?
my answers:
a) i = P/V =>(24000*8)/220 = 872.7 A
b)79.851 x 8 hours = 638.808
638.808 x .11 = $70.26
is this right?
Not right.
If the battery can supply 24 kW for 1 hr then if it had to be recharged in 1 hr it would take how many amperes to recharge? And if we can take 8 hrs to recharge, would that take more or less current?
rude man said:
Not right.
i don't understand. (24 kW times 8 hours to recharge)/220V?
Think about the units for kWh
= Watts * time(in hours)/1000
= Current(Amp) * Voltage(volts) * time(in hours)/1000
PS I believe a Leaf can be charged from a normal domestic socket so 800-900A is unlikely
24000 * 8 hours /1000 = 192 W
current=192W / 220Volts = 0.87 amps?
No you missunderstood my post totally.
I start from the beginning ...
The battery stores a quantity of energy. I wish they would specify that in Joules but they used kWH instead which is ok.
kWH means kilo Watt Hours so a sum that gives an answer in kWH will involve multipling power(in Watts) by time(in hours).
Specifically...
Energy (in KWH) = Power(in Watts) * time(in hours)/1000.....(1)
but as you know
Power(in watts) = Current(in Amps) * Voltage(Volts)......(2)
substitute to give..
Energy (in KWH) = Current(Amp) * Voltage(volts) * time(in hours)/1000
The question asks for the current so rearrange that to give
Current = (Energy * 1000) / (Voltage * time)
Then plug the numbers in.
