Normal order of operator product
The discussion revolves around the normal ordering of operator products, questioning its well-defined nature. It is clarified that normal ordering applies only to expressions involving operators, not to operators themselves without specific forms. The normal ordering of a sum of operators is indeed a sum of their normal orders, but care must be taken with commutation relations. The conclusion emphasizes that normal ordering is not well-defined unless concrete expressions are provided, as demonstrated with the Hamiltonian example. Overall, the participants agree that normal ordering requires specific context to be meaningful.
paweld
I'm not sure if the normal orderdering of operator product is a well defined procedure.
I assume that normal order of a sum of operators is a sum of normal orders. It follows
from it that for bosonic creation and anihilation operators holds:
<br /> a^\dagger a= ~: [a,a^\dagger ]:~ =~ :[a^\dagger,a]+1:~ = ~ :[a^\dagger,a]: +:1:=<br /> a^\dagger a + :1:<br />
So we have :1: =0. Is it OK?
No. First of all, your commutators don't make sense.
But let me assume that you intended to say
a^*a = :aa^*: = :a^*a+1: = :a^*a:+:1: = a^*a+:1:, so that :1:=0.
This looks on the surface correct. Nevertheless, :1:=1.
If A is a formal linear combination of products of numbers, creation
operators and annihilation operators, the normal ordering :A: of A is
the operator defined by moving in each product term the creation
operators to the left of the annihilation operators.
In particular,
:AB: = :BA: = 0 for any A,B,
since AB and BA contain the same creation and annihilation operators
with the same multiplicity, only in different order. Therefore, we
also have :[A,B]: = :AB:-:BA: = 0.
This may look a bit strange since :[a,a^*]:=0 and :1:=1 although [a,a^*]=1. But nothing is wrong here, since [a,a^*] and 1, although equal as operators, are different as formal expressions.
Conclusion:
Normal ordering is applied only to_expressions_ involving operators,
not to operators themselves. The normal ordering of an operator is not
well-defined unless you specify a particular form of writing it.
Thank you a lot.
So normal ordering is well defined only when the form of expression is given.
For example :H: does not make sens if we know only that:
<br /> H = ( \pi^2 + (\nabla \phi)^2 + m^2 \phi^2)/2<br />
and \pi, \phi can be expressed in terms of creation and
anihilation opperators.
That is right. Normal ordering applied to expressions, not to operators. And unless the concrete expressions are given (or if there is a standard convention of assigning them), normal ordering is not a well-defined concept.
The same is true with time ordered product, because T(A B) \neq T(A C D)
even if B=C D.
paweld said:
Thank you a lot.
Well, one can do all the algebra that doesn't depend on specific equations relating the symbols. Thus if you write pi and phi as linear combinations of c/a operators and expand and normal order, you get correct results as long as you use neither commutation relations nor field equations.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 24 ·
