O-ring groove specifications and questions
  • Thread starter Thread starter Jynx18
This discussion focuses on the design specifications for an O-ring groove intended to create friction between two hollow tubes, specifically using an O-ring size 018 with an ID of 0.739" and an OD of 0.879". The recommended groove diameter is between 0.85" and 0.854", with a groove width of 0.093" to 0.098". Key considerations include the need for sufficient deformation of the O-ring to achieve the desired friction without pinching, and the potential for using spring-energized alternatives for better control of friction levels.
  • Understanding of O-ring specifications and dimensions
  • Familiarity with groove design principles for friction applications
  • Knowledge of materials and their friction properties, particularly rubber
  • Basic machining techniques for creating O-ring grooves
  • Research O-ring groove design using the Parker Handbook
  • Learn about spring-energized seals and their advantages over traditional O-rings
  • Investigate the effects of lubrication on rubber friction properties
  • Explore machining techniques for creating precise O-ring grooves
Mechanical engineers, product designers, and anyone involved in the design of friction-based sealing solutions in mechanical systems.
Jynx18
I am looking for some info. I have two hollow tubes that need to slide into each other and have the inside one not fall out due to friction from the oring INSIDE the larger one. It is not doing any sealing, the oring is just to cause friction. The inside tube will be moved to remove and replace it but it is not a constantly moving part. The tube diameters and oring size are set. I just need to size the groove for the oring to sit in.
Oring
OD: 0.879"
Cross section: 0.07"
Tube 1:
0.75" ID
Tube 2:
0.74" OD
Tube 2 goes inside Tube 1.
From the parker handbook it looks like the oring groove should be slightly wider than the oring. Also to keep some friction the OD of the groove should be slightly smaller than the OD of the oring.
Here is what I am thinking from the handbook:
It says Gland Depth sould be 0.050" to 0.052".
So 0.75" + 0.050" + 0.050" = 0.85" to 0.854"
Groove Diameter: 0.85" to 0.854"
And right from the handbook:
Groove Width: 0.093" to 0.098" (sounds a little wide to me though)
Any input on design of this would be great. Thanks
You want a frictional grip rather than a fluid seal so hydraulic data will be misleading since fluid must move around the O-ring to pressure seal.
The O-ring must be deformed sufficiently to apply the friction you require.
The volume of the O-ring is fixed. If not under tension the O-ring will have a fixed cross section. Deformation into a flat sided ellipse will require a groove width that does not pinch the O-ring.
1. Investigate the flattening needed to grip OK between cylinders. O-ring grip thickness = t.
2. Measure the O-ring width in that situation. Width = w.
3. Machine a grove of width w and depth t.
Tolerance will be taken up by filling the unused corners of the groove.
If all you are interested in is friction, why use an Oring at all?
Use something spring energized, that way you can control the level of friction.
I also need that the oring kind of centers the tube but am open to other methods. What would you recommend?
The great thing about deformation of a partially constrained rubber cross section is that it is elastic, just like a spring.
Unfortunately, water is a natural lubricant of rubber. The coefficient of friction will depend on the (water / oil / dry) state of the contact. If not lubricated, a dry friction surface may gall the rubber seal. Abrasive wear can be reduced by the use of a polished stainless steel or a chrome plated sliding surface. If grit is present it will become embedded in the rubber which will wear the metal sliding surface faster than the softer rubber.
One problem with O-ring seals is that they get pushed into, or pinched in, the small gap between the piston and cylinder. O-ring hoop tension can be used in the absence of fluid pressure by cutting the groove for the O-ring with a deeper dovetail section, axial pressure will then tend to lift the O-ring away from the friction surface. That can significantly reduce galling of the rubber and sensitivity to lubrication.
