Obtaining standard deviation of a linear regression intercep
The discussion focuses on obtaining the standard deviation of the intercept from a linear regression performed using Excel's LINEST function. The user is conducting an experiment to normalize quantity A by quantity B, derived from a standard curve with 8 data points. They seek clarification on converting standard errors to standard deviations and the correct approach for error propagation when background correcting the intercept. The user expresses confusion over the relationship between quantities A and B and how to accurately propagate errors in their calculations.
  • Understanding of linear regression and its application in data analysis
  • Familiarity with Excel's LINEST function and its output
  • Knowledge of error propagation techniques in statistical analysis
  • Basic concepts of standard deviation and standard error
  • Research how to convert standard errors to standard deviations in linear regression analysis
  • Learn about error propagation methods specific to linear regression outputs
  • Study the implications of degrees of freedom in regression analysis
  • Explore statistical techniques for handling correlated variables in regression
Researchers, data analysts, and statisticians involved in experimental design and data normalization, particularly those using Excel for linear regression analysis and error propagation.
Roo2
Hello,
I have an experiment that I'm trying to conduct where I measure quantity A and normalize by quantity B. I then want to report normalized quantity A with error bars showing standard deviation. Quantity B is obtained via a standard curve that I generated (8 data points measured once each as the independent variable, 8 data points measured 10x as the dependent variable). From this I performed a linear regression, and using Excel's LINEST function, obtained the standard errors of the slope and intercept.
I don't really care about the slope (since I'm normalizing I don't care what the true value of B is; I just need to make sure it's correct relative to the other samples). All I want to do is perform background correction by subtracting the intercept and performing the appropriate error propagation. However, for the error propagation I need the s.d. of the intercept, and LINEST gives me the s.e. For conversion, do I multiply the s.e. by the square root of the number of data points in the regression? Do I subtract 2 from N to account for the lost degrees of freedom? Does it matter that for each independent variable I have 10 measurements of the dependent variable (i.e. is my N going to be 80)?
Thanks for any advice!
Check out this thread for expressions. Note that the error on the intercept is usually very strongly correlated to the error on the slope: unless the center of mass of the measurements is on the y axis, "wiggling the slope" changes the intercept.
[edit] note I changed the link to the thorough one that has the references in it.
My impression is LINEST returns the standard deviation for the intercept (but they do indeed call it the standard error).
Thanks! This was very informative.
If I may, I'd like to ask one more question that's related to this topic, but not necessarily to the subject line. Quantity B is related in a linear way to quantity A - the more quantity B there is, the more quantity A. When I measure these quantities for a sample treated under a given condition, I combine n measurements for A and n measurements for B, background subtract the mean of B according to the linear regression (propagating the STdev of the intercept along with the STDev of B), and then divide mean(A) by mean(B)subtracted, propagating the previously propagated STdev of B with the STDev of A.
However, I don't think I'm doing this correctly - A and B are related for each sample but not necessarily between samples, and mean(An)/mean(Bn) != mean(An/Bn). Given this, I'm a bit confused as to where I start calculating the deviation. The standard deviation of mean(An/Bn) should capture the variation of both quantity A and quantity B; however, B first needs to be background subtracted according to the linear regression. How do I propagate the error of the intercept from the regression, given that I apply it to n individual samples which are then pooled?
Thanks again.
Hope you can understand this is very hard to follow for a reader.
I can't make out what mean(B)subtracted could possibly be.
Perhaps better to post a new thread with a concrete case/example so people can follow your steps and give comment.
  • · Replies 42 ·
  • · Replies 30 ·
  • · Replies 23 ·
