Odd primes ≠5 have p²−1 or p²+1 divisible by 10
  • Thread starter Thread starter Math100
    Prime
15 replies · 5K views
Math100
If ## p\neq5 ## is an odd prime, prove that either ## p^{2}-1 ## or ## p^{2}+1 ## is divisible by 10.
None.
Proof:
Suppose ## p\neq5 ## is an odd prime.
Applying the Division Algorithm produces:
## p=10q+r ## where ## 0\leq r\leq 10 ##,
where there exist unique integers ## q ## and ## r ##.
Note that ## p\equiv 1, 3, 7 ## or ## 9 ## mod ## 10 ##.
This means ## p^{2}\equiv 1, -1, -1 ## or ## 1 ## mod ## 10 ##.
Then we have ## p=10q+1, p=10q+3, p=10q+7 ## or ## p=10q+9 ##.
Now we consider four cases.
Case #1: Suppose ## p=10q+1 ## for some ## q\in\mathbb{Z} ##.
Then we have ## p^{2}-1=(10q+1)^{2} -1
=100q^{2} +20q+1-1
=100q^{2}+20q
=10(10q^{2}+2q)
=10m ##,
where ## m=10q^{2} +2q ## is an integer.
Thus, ## p^{2} -1 ## is divisible by ## 10 ##.
Case #2: Suppose ## p=10q+3 ## for some ## q\in\mathbb{Z} ##.
Then we have ## p^{2} +1=(10q+3)^{2} +1
=100q^2 +60q+10
=10(10q^{2} +6q+1)
=10n ##,
where ## n=10q^{2} +6q+1 ## is an integer.
Thus, ## p^{2} +1 ## is divisible by ## 10 ##.
Case #3: Suppose ## p=10q+7 ## for some ## q\in\mathbb{Z} ##.
Then we have ## p^{2} +1=(10q+7)^{2} +1
=100q^{2} +140q+49+1
=100q^{2} +140q+50
=10(10q^{2} +14q+5)
=10r ##,
where ## r=10q^{2} +14q+5 ## is an integer.
Case #4: Suppose ## p=10q+9 ## for some ## q\in\mathbb{Z} ##.
Then we have ## p^{2} -1=(10q+9)^{2} -1
=100q^{2} +180q+81-1
=100q^{2} +180q+80
=10(10q^{2} +18q+8)
=10s ##,
where ## s=10q^{2} +18q+8 ## is an integer.
Therefore, if ## p\neq 5 ## is an odd prime, then either ## p^{2} -1 ## or ## p^{2} +1 ## is divisible by ## 10 ##.
We can construct a shorter and simpler proof without so many cases.
NB The latex in the following doesn't quite render properly. The symbol ##\not|## should be a diagonal stroke through (not next to) a vertical stroke, meaning "does not divide".
$$odd(p)\to 2\not|p\to 2\not|p^2\to 2|(p^2-1) \wedge 2|(p^2 +1)$$
$$prime(p)\wedge p\neq 5\to 5\not|p$$
$$5\not|(p^2-1) \to 5\not|((p-1)(p+1))\to 5\not|(p-1)\wedge 5\not|(p+1)$$
So if ##prime(p)\wedge 5\not|(p^2-1)## we know that ##5## doesn't divide ##p-1,p## or ##p+1##. What can we then say about whether it divides ##p^2-4## and what does that imply about whether it divides ##p^2+1##?
Once you get to ##p^2 \equiv \pm 1~\rm (mod~10)##, can't you conclude ##p^2 \mp 1 \equiv 0~\rm (mod~10)##?
Math100 said:
Homework Statement:: If ## p\neq5 ## is an odd prime, prove that either ## p^{2}-1 ## or ## p^{2}+1 ## is divisible by 10.
Relevant Equations:: None.
Proof:
This reminds me a beginner's chess game where several apparently brilliant moves lead to checkmake in one more move, But, instead of giving checkmate, the player plays some other random move and the game continues for another thirty moves!
## 5 ## divides ## p^{2}-4 ##, and also
## 5 ## divides ## p^{2}+1 ##.
Sorry, but I do not understand ##p^2 \mp 1 \equiv 0~\rm (mod~10)##. Can you please explain what this is?
It comes down to ## a \equiv b ~\rm (mod m) \rightarrow a-b \equiv 0( modm)##, assuming a,b are coprime to m.
nuuskur said:
Your proof is done in 6 lines.
So the first 6 lines in my original proof is sufficient?
Just lines 1, 5, 6, plus one more to finish, I'd say.
That's what you had to prove. That ##p^2 -1 = 0 \ (mod \ 10)## or ##p^2 + 1 = 0 \ (mod \ 10)##. Or, using the shorthand ##\pm## for "plus or minus"; or, ##\mp## for "minus or plus", you have to show that: ##p^2 \mp 1 = 0 \ (mod \ 10)##.
Do you not see that you got within one step of a finished proof, but then went off at random in a different direction?
Okay, here's my revised proof:
Note that ## p\equiv1, 3, 7 ## or ## 9 ## mod ## 10 ##.
This means ## p^{2}\equiv1, -1, -1 ## or ## 1 ## mod ## 10 ##.
Now we consider two cases.
Case #1: Suppose ## p\equiv1 ## or ## 9 ## mod ## 10 ##.
Then we have ## p^{2}\equiv1 ## or ## 81 ## mod ## 10 ##.
Thus ## p^{2}-1\equiv 0 ## mod ## 10 ##.
Case #2: Suppose ## p\equiv3 ## or ## 7 ## mod ## 10 ##.
Then we have ## p^{2}\equiv 9 ## or ## 49 ## mod ## 10 ##.
Thus ## p^{2}+1\equiv 0 ## mod ## 10 ##.
Therefore, if ## p\neq5 ## is an odd prime,
then either ## p^{2}-1 ## or ## p^{2}+1 ## is divisible by ## 10 ##.
That's fine, but I would have written it less wordily as
## p^{2}+1\equiv2, 0, 0 ## or ## 2 ## mod ## 10 ##
## p^{2}-1\equiv0, -2, -2 ## or ## 0 ## mod ## 10 ##
either ## p^{2}-1 ## or ## p^{2}+1 \equiv0 ## mod ##10##.
What you used should have worked, but given that it didn't, you could use \nmid instead: ##x\nmid y##.
Note that we didn't really need ##p## to be prime here.
If ##n## is odd and not divisible by ##5##, then either ##n^2 -1## or ##n^2 +1## is divisible by ##10##. It's always worth noticing this sort of thing.
