One more Linear Transformation
9 replies · 3K views · last reply
says
I've posted a few of these recently. I have one question about this problem -- hopefully my calculations are correct.
f: R2 to P1, f(a,b)=b+a2x
Is this a linear transformation?
f(u+v) = f(u) + f(v)
f(cu) = cf(u)
where u and v are vectors in R2 and c is a scalar.
let u=(u1,u2)
let v=(v1,v2)
f(u+v) = ((u2+v2) + (u12x+v12x))
f(u) + f(v) = (u2 + u12x) + (v2 + v12x)
So f(u+v) = f(u) + f(v) (First condition met)
c(u1,u2) = (cu1,cu2)
f(cu) = cu2 + cu12x
cf(u) = c(u2 + u12x)
= cu2 + cu12x
Second condition met.
However, my question is -- The question asks is this a linear transformation from R2 to p1. If my calculations are correct, both conditions are met, but the polynomial has a degree of 2, not 1, so it's not a linear transformation from R2 to p1.
The squared u1 and v1 will have a c^2 coefficient, not c. So second condition is not met.
if v1 -> c*v1
then v1^2 -> c^2*v1^2
f(cu) = cf(u)
let u=(u1,u2)
let v=(v1,v2)
The way you compute ##f(u+v)## is not correct: in general, ##(u_1+v_1)² \neq {u_1}²+{v_1}²##.
f(cu) = cu2 + cu12x
This is not correct, you should have a ##c²{u_1}²x## in the right hand side expression.
= cu2 + cu12x
The polynomial has a degree of 1 in ##x##.
I see what you mean with the c2 on the right hand side of the equation, I forgot to put a parenthesis around it (cu12)x
Just looking at the first part now. Thanks for your replies.
f(u+v) = [(u2+v2)+(u1+v1)2x]
I can see now (with @DuckAmuck's reply) that the second condition is not met.
Oh yes, you are correct with the polynomial having a degree of 1 as well! I got my u,v and x variables mixed up there!
I'm still making a few mistakes, but I'm a lot more confident with these now than I was a couple of days ago.
Working that out will show that the first condition isn't met either.
The never ending joy of learning. :smile:
f(u) + f(v) = u2 + u12x + v2 + v12x
That condition isn't met either! Totally skipped over that one.
Pretend that you're trying to convince an idiot, and show why the first line above isn't equal to the second line.
*Convincing myself*
(u1+v1)2 ≠ u12 + v12
says said:
*Convincing myself*
Better:
f(u+v) = (u2+v2)+(u1+v1)2x = ##u_2 + v_2 + (u_1^2 + 2u_1v_1 + v_1^2)x##
f(u) + f(v) = u2 + u12x + v2 + v12x = ##u_2 + v_2 + (u_1^2 + v_1^2)x##
Since ## u_1^2 + v_1^2 \ne u_1^2 + 2u_1v_1 + v_1^2##, if ##u_1 \ne v_1##, then f(u + v) ##\ne## f(u) + f(v)
