Perpendicular Vector with given magnitude
To find a vector perpendicular to A = 8i - 5j with a magnitude of 14, the dot product method reveals potential perpendicular vectors such as B = -5i - 8j or B = 5i + 8j. However, these vectors need to be scaled to achieve the desired magnitude of 14. The magnitude formula √(a² + b²) must equal 14, which requires multiplying the perpendicular vectors by appropriate scalar values. The discussion emphasizes that the scaling factors do not have to be integers, allowing for various solutions. Understanding how to apply these multiples is crucial for solving the problem effectively.
NEUhusky
Given a vector A = 8i − 5j, find the vectors in the xy plane that are perpendicular to A and have a magnitude of 14.
I can find the vector perpendicular to A quite easily. I'm having trouble finding the perpendicular line when it has the given magnitude of 14. I have a feeling it's going to be an easy solution but something isn't clicking in my brain at the moment. Any help would be greatly appreciated. Thanks!
Welcome to PF!
Hi NEUhusky! Welcome to PF! :wink:
The magnitude of ai + bj is √(a2 + b2) …
show us what you get. :smile:
Thanks! Glad I found this place! :smile:
Hm, well the magnitude of the given vector A is √(8^2+5^2) which is approximately 9.43.
Using the dot product I know that the perpendicular lines are either B = -5i-8j or 5i+8j because the dot product equals zero. Unfortunately the magnitude is still the same as A when it needs to be 14. Still kinda lost.
ah!
no, 5i + 8j is a point on the perpendicular line …
multiply it by anything, and you'll get more points on the perpendicular line …
choose the correct multiples to get 14. :wink:
tiny-tim said:
ah!
Ugh, still a bit confused. Multiples to get 14 would be either 2 & 7 or 1 & 14. I'm not sure how that applies. Doesn't the magnitude ( √(a2 + b2) ) have to equal 14?
Hi NEUhusky! :smile:
(just got up :zzz: …)
(try using the X2 icon just above the Reply box :wink:)
Yes, but it doesn't have to be an integer! :wink:
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
