Photo Contest - Waterworld (6/27-7/3)
  • Thread starter Thread starter ZapperZ
    photo contest
The discussion revolves around a photo contest themed "Waterworld," where participants are required to submit photographs that depict water exclusively. The conversation includes clarifications on contest rules, interpretations of the theme, and various submissions related to water imagery.
  • One participant emphasizes that the photo must show water over the entire image, allowing for exceptions only for objects submerged in water, such as fish or rocks.
  • Another participant shares a photo of a zebrafish with a pigmentation mutation, discussing its biological significance and the structural pigments involved.
  • A participant describes an action shot of a black drum fish caught in Louisiana, noting the fish was released afterward.
  • Some participants express confusion regarding the contest rules, particularly about what constitutes being "in the water," leading to clarifications about submissions that do not meet the criteria.
  • There are multiple mentions of catfish in relation to underwater photos, with participants debating their identification and characteristics.
  • One participant describes a cenote in Yucatan, Mexico, highlighting its beauty and the light effects created by its structure.
  • Several participants share their experiences and thoughts on the aesthetics of their photos, including comments on color and composition.
Participants express differing interpretations of the contest rules, particularly regarding what qualifies as being "in the water." Some submissions are challenged for not adhering to the theme, indicating a lack of consensus on certain entries.
Participants have noted the need for clarity on the contest rules, particularly concerning the definition of being "in the water" and the types of objects that can be included in submissions.
Individuals interested in photography, particularly underwater or water-themed photography, as well as those participating in or observing community contests related to visual arts.
ZapperZ
Staff Emeritus
Homework Helper
Insights Author
Waterworld
The requirement for this contest is not as simple as at first glance, so you should pay a bit more attention.
The theme is on water, but it must be ALL water. Your photo must show water over the entire photo, not just over a majority of it. Every square inch (or mm) of your photo must show water.
So a photo taken underwater qualifies. A photo of a water surface and nothing else in the photo also qualifies. A photo of water taken through a clear, transparent glass also qualifies as long as the glass medium is not apparent.
The only exception being made here will be the inclusion of objects that are in the water. So fish, rocks, etc. that are in the water are allowed. Thus, a photo of the inside of a fish tank qualifies IF it does not show the outline of the tank itself. A photo of water in the pool showing the bottom of the pool (and maybe coins resting at the bottom of the pool) also qualifies.
So show us your water world!
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
I have prettier pictures of things in water, this is one of my favorites from a physics in biology point of view.
This zebrafish (in an aquarium) has a pigmentation mutation. (Gave the mutant to a friend who researches ZF pigmantion patterning and mutants.)
Most normal pigmentation cells are not present, but iridophores (a reflecting structural pigmentation containing kind of pigmentation cell) cover more of the body than is normal.
The structural pigment is flat crystals (lying parallel to the body surface tangent), in the pigment cells (packed in vesicles), that reflect light. The spacing between different reflecting surfaces in the crystals is different depending upon the the angles that the body surface is illuminated and observed from.
The result is the rainbow-like color pattern (blue, green, yellow, red from top to bottom) across the fish's body.
This is an action shot of a 15 lb black drum being caught in one of my favorite fishing spots in Grand Isle, Louisiana. The fish was released to fight another day.
Looks like Jaws! :oops:
  • Love
Some nice water at the Similan Islands
A scout from the shadow hive.
OK, so it appears that the theme for this contest is getting away from me.
Let me remind you that everything in your photo must be in the water. The only exception here is a clear, transparent glass that may hold the water in case of a water tank or aquarium. Otherwise, if there is anything else that is not water, that object must be IN the water completely.
So an object floating on water is not in the water. A fish that is partially submerged in the water is also not in the water. Therefore, photo submissions so far by @Dr. Courtney (if I interpret the picture correctly) , @rsk , and @jtbell do not qualify. You may resubmit if you wish.
Zz.
OK, actually immersed completely in the water... now I get it!
diving with sharks
  • Wow
  • Love
Ok, my mistake. Resubmitting. Do I have to delete the original one?
  • Love
Makes a great wallpaper. The color is amazing!
Feel free!
Are they catfish?
chemisttree said:
Are they catfish?
It's all fun and games until you realize that it's zoomed way out and it's actually hundreds of sharks, and you are way below the surface, running out of oxygen, and have to reach the surface in order to escape being eaten alive
They look like catfish to me.
I'm ashamed to say I don't know but apparently yes, catfish do live in the cenotes. This is the photo I meant when I said I was torn between it and the original one. It's Cenote Hubiku near Valladolid in Yucatan, México. Cenotes are pools, often well below ground level but open at the top which creates beautiful light effects. There are loads of them there, some of them very touristy but others still quiet and peaceful.
Teaching physics has allowed me to see some amazing places ;)
Early morning -- the calm before the storm... (medical shift at a big swim meet) :smile:
davenn said:
Hard to tell if that is water, mud, lava or chocolate :wink:
My guess was basalt from the Kīlauea.
chemisttree said:
Are they catfish?
definitely look like it ... they have the "feeler" thingies ( really scientific haha) coming off their snouts,
sharks dont
It's the surface of water, honestly- in the wake of a boat. Fast shutter speed and high viewpoint.
davenn said:
"feeler" thingies
Barbels.
Besides touch sensitivity, they are covered with taste buds, as are most of many catfishes's bodies.
They have been called swimming tongues.
Final day to submit your photo for this contest.
Zz.
  • · Replies 26 ·
