Photo Contest - Dawn To Dusk (8/22-8/28)
  • Thread starter Thread starter ZapperZ
    photo contest
The discussion centers around a photo contest themed "Dawn To Dusk," where participants must submit images clearly depicting either dawn or dusk without ambiguity. Key rules include accepting only one submission per member, requiring original photos taken by the member, and allowing digital or scanned images. Participants are encouraged to upload photos to image hosting services or directly to the forum, with a recommendation to keep file sizes under 1 MB. The contest allows some image processing, particularly cropping, but aims to maintain a focus on natural composition. There is some debate about the technical definitions of dawn and dusk, with a consensus that photos should feature the sun near the horizon. Participants share their experiences and challenges, including resizing photos and discussing the aesthetic qualities of their submissions. The conversation also touches on environmental concerns, highlighting issues such as air quality affecting visibility in certain regions.
ZapperZ
Staff Emeritus
Homework Helper
Insights Author
Dawn To Dusk
Your photo this week must show a scene indicating that it was taken either at dawn or at dusk. This is crucial and there should not be any ambiguity that the photo is depicting that moment of the day.
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
4. Only ONE picture per member per contest. Once a picture is posted, it cannot be changed other than a total withdrawal by that member from that week's photo contest. Exceptions will be made for modification to comply with the rules, such as resizing.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
  • Love
Likes davenn, DennisN, JD_PM and 4 others
etotheipi said:
Unfortunately, this photo looks like it was taken in the afternoon. The sun is still high above the horizon, which means that it was not at dawn or at dusk.
Zz.
Likes etotheipi
Zz.
The color of the atmosphere says otherwise. It is only red if the sun beams travel a long way through it.
Likes etotheipi
etotheipi said:
I seem to recall that it was taken pretty late, but to remove all possible ambiguity I'll try this one instead
Can you explain a bit about this photo? Did you crop it to end up with what appears as a panoramic shot?
Zz.
Likes etotheipi
docnet said:
docnet: similar question to you. Was this a single-shot photo that you crop, or using a wide lens, to end up having this pano shot?
Zz.
Zz.
It was taken using the "pano" setting on a iPhone 6s.
Likes docnet
etotheipi said:
For that one I just used the panorama button on my phone... I hope it's allowed :nb)!
OK. A few things.
First of all, we have a dedicated contests for panorama photos. So I was hoping that we all get that out of our system in those contests.
Secondly, I think when I changed the rules to remove the size limitations on the photos, the rule against photo post-processing and image "manipulation" beyond resizing and cropping was accidentally left out. So as it stands now, there's nothing against the rule for you to use those panoramic shots in this contest.
Finally, I've always struggled trying to define the technical limitations for the photo contest since the very beginning. The spirit of the contest is that you take a standard photo with as minimal processing as possible, so that it is mainly about aesthetic composition, etc. and less about image manipulation (notice I didn't say no image manipulation). I am fully aware that digital images, by its nature, has some form of processing, settings, etc. especially raw files, but I'm trying to draw the line at something beyond that, and that includes using panoramic capability.
So for this contest, if you wish to keep those, they are fine.
Zz.
Likes DennisN and berkeman
I'll use this picture instead.
Likes atyy, davenn, Ygggdrasil and 4 others
Hi, Zz, I've got a photo too large, and no idea how to make it 1 Mb or less. It's 1,4 Mb.
Greetings!
From Cambodia looking West across border river with Thailand
Likes atyy, mathwonk, BillTre and 4 others
  • Love
Likes Fervent Freyja, jim mcnamara, berkeman and 7 others
Likes docnet, Algr, mcastillo356 and 1 other person
Photo of a sunset at Half Moon Bay, south of San Francisco.
  • Love
Likes Fervent Freyja, docnet, Rubidium_71 and 4 others
A very cool photo, to me it looks a bit like a painting.
Likes docnet
Sunset; the city at the horizon is Copenhagen.
  • Love
Likes rsk, Fervent Freyja, docnet and 4 others
Hi ZZ:
I am not a photographer, but I find your contests generally quite interesting. I am just wondering about the concept of dawn and dusk you are using. Wikipedia is quite specific.
For both dawn and disk the sun must be between 6 degrees and 18 degrees below the horizon.
Regards,
Buzz
Likes mcastillo356
Buzz Bloom said:
Hi ZZ:
Regards,
Buzz
Technically, that's correct. But I'm not going to pull hairs about that. It's bad enough that some people think "dusk" or "dawn" is defined by the color of the sky.
Anything with the sun close enough to the horizon will be fine for this contest. It will be a judgement call.
Zz.
Likes russ_watters
Basic physics.
Ok, so just to be clear. We can use here sunrise/sunset photos rather than a strict dawn/dusk definition?
Hi, Zz, can I post this thread with a photo of 1,4 Mb, as an attached file?. I don't manage to reduce it and send it with Google Photos free software.
Regards,
Marcos
  • Love
Likes docnet, DennisN, Rubidium_71 and 3 others
Regards,
Marcos
There's plenty of free app's out there
The one I have used for the last 20+ years is IrfanView -- great for resizing and compressing, converting to other formats etc
https://www.irfanview.com/main_download_engl.htm
  • Love
Likes mcastillo356
Thanks!
Likes davenn
Tough choice, but to avoid any uncertainty, I picked one which is definitely after sunset.
Likes atyy, Fervent Freyja, Algr and 4 others
wow, nice photo. location?
Likes rsk
Cádiz, Southern Spain. My 2nd choice for this was a sunset from Cadiz, maybe even the same day. I was living in Málaga and had a nice view from my window of sunrise and moonrise, so to be in a place where I could see the sunset was a novelty.
Likes atyy and mcastillo356
Arriaga Theater, Bilbao, Basque Country, a few days ago; picture taken around 21.00 hours
Likes Rubidium_71, morrobay and docnet
Likes mathwonk, morrobay, rsk and 5 others
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 23 ·
