Photo Contest - What Time Is It? (9/28-10/4)
  • Thread starter Thread starter ZapperZ
    photo contest
The thread revolves around a photo contest with the theme "What Time Is It?" Participants are encouraged to submit photographs that depict objects or scenes that indicate the time of day, excluding devices that measure elapsed time, such as stopwatches. The discussion includes contest rules, submission guidelines, and various interpretations of what constitutes a valid time-telling subject.
  • One participant mentions using a microwave oven to tell time since their watch is broken.
  • Another participant shares a photo of a steam-powered clock from Vancouver, BC.
  • Several participants discuss the challenges of reading a BCD display clock, with one explaining the binary-coded decimal system.
  • There are humorous suggestions, such as taking a picture of a stomach to indicate lunchtime.
  • Some participants assert that the position of the sun can be considered a time-telling device, while others argue it does not meet the contest criteria due to lack of specific hour accuracy.
  • One participant emphasizes that the contest rules do not specify the required accuracy of the time-telling device, suggesting that the sun's position satisfies the criteria.
  • There is a contention regarding whether a sundial qualifies as a valid entry, with conflicting views on its accuracy and adherence to the contest theme.
  • Participants express uncertainty about the implications of the contest rules and the criteria for judging the photos.
Participants express multiple competing views regarding what qualifies as a valid time-telling subject for the contest. There is no consensus on the interpretation of the rules, particularly concerning the accuracy required for the time-telling devices depicted in the photos.
Some participants note that the contest rules do not explicitly define accuracy requirements for time-telling devices, leading to differing interpretations. The discussion reflects a variety of perspectives on what constitutes a suitable entry based on the theme.
ZapperZ
Staff Emeritus
Homework Helper
Insights Author
What Time Is It?
This week, the main subject of your photo must be something that tells time. A stop watch doesn't count since it only measures elapsed time. This must be something someone looks at to know the time of day without doing much "calculation".
Contest Rules:
2. Size limitations: Your photo is only limited to the file size limitation set by PhysicsForums. However, your may want to consider reducing the size of your photo if the file size exceeds 1 Mb. If your file is being hosted elsewhere, I will have to see how it is being displayed here, and I may ask you to resize and resubmit if it causes problems.
3. Upload your photos to any of the photo servers such as imageshack or photobucket. Then post it the relevant contest thread and link your picture using the img command. PM me if you do not know how. Alternatively, you may simply upload your image file to PF, and then have the full image displayed in your post.
7. The photo of the subject must be something that you took directly, not via in intermediary medium, and not taken by someone else. Unless otherwise noted, a photo of another photo, painting, print, etc. does not qualify.
Zz.
Ever since my watch died I have been relying on my trusty microwave oven to tell me what time it is (at least when I am in the kitchen).
from my recent trip to Canada ...
The steam powered clock in Vancouver, BC
Zz.
I'm tempted to take a picture of my stomach, because it's telling me it's time for lunch.
  • Haha
By the front door
BCD display clock. Time showing: 10:06:19 (LSB at bottom)
  • Haha
Janus said:
BCD display clock.
I had to look that one up. Do you ever get to where you can read it on sight? Without counting on your fingers? :smile:
It's just a matter of memorizing recognizing the pattern.
In BCD:
0001 =1
0010= 2
0011= 3
0100= 4
0101= 5
0110= 6
0111= 7
1000 =8
1001 =9
If you work with it long enough, it becomes pretty automatic to see 0111 and think "7"
It's a little more more tricky in the other mode where the hours, min and sec are done in pure binary.
Hrs aren't bad, as you you don't use the left most column with two lights, you instead just use the second column, and add
1010 =10
1011=11
1100=12
Again easily remembered by anyone familiar with hexadecimal
However, telling at a glance that the third column showing 011 and the forth column shows 0011 equates to
0110011 = 51 min without some mental addition isn't as easy.
I've got a big clock on my PC:
(I bought it today very cheap at a second hand store)
The sun breaks from the ocean as the stars
Pass on, they were but signs of One to come
Light and shadow wage celestial wars
While down below the human race lies numb.
I wonder if the city uncovers our town clock briefly twice a day.
The grim reapers personal collection. Get your capped watch now ! Stocks limited
where's the timepiece ?
The sun (and its position in the sky) is the oldest clock known to man.
true but you can't tell specific time ... it fails to conform to the contest theme ...
per Zz's heading post ...
ZapperZ said:
What Time Is It?
😉 😉 :smile:Dave
The voters can certainly consider the accuracy of the clock in each photo. Of course, older clocks are going to be less accurate than more modern clocks. The instructions say nothing about the required accuracy of the clock or needing to be man made, but rather that it tell the time of day and not merely an elapsed time. The position of the sun in the sky satisfies the stated criteria. Inventing an accuracy criteria after a photo is submitted would be arbitrary and capricious.
that's correct ... we are not after seconds accuracy, else NONE of the other entries would count
no it doesn't ... it doesn't even tell you hour accuracy 😉 :wink:
Anyway ... @ZapperZ will have the final say :smile:
A new criteria added after the contest began that includes the sundial, but excludes the sun itself. Why decide on the last day of entries that the clock needs "hour accuracy" and not "minute accuracy" or "second accuracy"? Why not add a rule today that the clock needs to specify morning or evening? Most of the clocks in the photos do not do that. At least my photo distinguishes morning from evening. The voters should have the final say.
A sun dial qualifies.
Zz.
Zz.
Where you see a sun dial here will remain your secret ...
Final day to submit your photo for this contest.
Zz.
Synchronised clocks (usually called Alice, Bob and Charlie aren't they?).
Zz.
That wasn't the one in question 😉
Z
ZapperZ said:
Zz could you tell us where that is? I have a feeling I've seen this before, but so many places have St. George and his cross.
Their relative velocity seems to be negligible.
  • Haha
epenguin said:
Z
That, actually, is at the German Pavilion in Epcot. 😄 I'm sure it's a replica of a familiar location somewhere in Germany, but I don't know where exactly.
Zz.
  • · Replies 26 ·
  • · Replies 18 ·
