Photon sphere density transformation between frames
  • Level: High School
  • Thread starter Dreads
8 replies · 3K views · last reply
Dreads
please see the attachment. I am on a computer usign Microsofts new crap word software and it won't allow me to copy and paste can you believe it
In the attachment i refer to a previous post of mine .It is the post where I showed that the density of a sphere of photons will change in a moving frame as opposed to a stationary frame
Hello Dread.
This may be relevant. If you Google Headlight Effect and look at Wolfram Demonstration tou will find an animation. I copied a bit of the text:-
-----A standard problem in special relativity asks you to consider light emitted uniformly in all directions from both the rocket frame (where the light is emitted from) and the laboratory frame (watching the rocket fly past). From the point of view of an observer in the laboratory frame, the light emitted from the rocket frame (in the forward hemisphere) is measured to be compressed into a cone in the forward direction.------
Matheinste.
In the attachment you write:
The boxcar now leaves the station and attains a constant velocity. Dash can assume the station is moving or he is moving. Still Bill can conclude the station is moving or Dash is moving.
The boxcar strobe again goes off Dash will see a sphere of photons but the photon density will be uneven. Still Bill will also see an uneven photon density and a sphere.
The station strobe again goes off Dash will see an uneven photon density Still Bill will see and EVEN photon density.
Still Bill now telephones Dash and tells him what he has seen. Dash and Still Bill can now conclude Dash is absolutely moving and Still Bill is moving at his original velocity ie the velocity of the Earth through space.
Why do you think that Dash would see an uneven photon density from the boxcar strobe, which is at rest relative to him? As long as the boxcar strobe is built the same way as the station strobe, then if Still Bill sees an even photon density from the station strobe, Dash will see an even photon density from the boxcar strobe.
Hi Dreads, why don't you guess my suggestion based on your other threads?
Do you need some help with the Lorentz transforms?
Dreads said:
The arguments there only suggest that if the photons are emitted at equal angles in the rest frame of the emitter, then they'll be emitted at unequal angles in the frame where the emitter is moving. I agree with that. But in your example, Dash's frame is the rest frame of the emitter on board the train, so why do you think he should see unequal angles? The "moving frame" relative to this emitter is Still Bill's frame, not Dash's.
--The boxcar strobe again goes off Dash will see a sphere of photons but the photon density will be uneven. Still Bill will also see an uneven photon density and a sphere.
The station strobe again goes off Dash will see an uneven photon density Still Bill will see and EVEN photon density.--
I admit on some of this this I was guessing but that bit is actually irrelevent. I am firm on the following:
1. The boxcar pulls out of the station
2. Still Bill may assume:
Dash is not at his original velocity but Still Bill is at his orginal velocity (ie dash is moving)
Still Bill is not at his original velocity, Dash is at his orginal velocity (ie Still Bill is moving)
Dash and Still Bill are not at their original velocity (ie both are moving)
3.Dash may assume:
Still Bill is not at his original velocity Dash is at his orginal velocity
4.Still Bill's strobe goes off, he sees a sphere of photons of even density
Dash's strobe goes off Dash see a sphere of photons UNEVEN density
5.Dash now knows he is no longer at his original velocity
6.Still Bill telephones Dash and they tell each other what they see
7.Still Bill now knows he is at his original velocity.
8. Still Bill now knows Dash is NOT at his original velocity.
9. Dash now knows Still Bill is at his original velocity.
10. Dash now knows he is no longer at his original velocity
11.Dash knows he is at some velocity other than zero. Dash sees a sphere of photons from his strobe, with himsef at the centre of that sphere at all times. He must concludes either photons are ballistic or that there is an error with the theory!
As I see it if Dash is at rest wrt the moving emitter he will aslo see uneven angles
Dash is in a spaceship docked at the launch pad and his strobe goes off. The striobe is at the origin os a cartesian coor system and there are 2 light intensity meters (LIM) measuring the light in each hemisphere. The reading from each LIM comes up on an LCD display. Dash reads the reading each LIM gives and they are the same.
The spaceship now takes off and attains a constant velocity. The strobe now goes off again. The LIM will give unequal readings and Dash will see that from the LCD display. That is all I am saying nothing more or less. I don't care what Still Bill sees.
If Dash assumes his velocity at the launch pad was zero then wihtout reference to phenomena external to the spaceship he will now know he is moving at a non zero velocity relative to his original velocity
Why do you think that? It's in direct contradiction with SR's principle of the equivalence of all inertial frames, and you haven't given any arguments as to why there is any problem with the idea that Dash will see even angles. Perhaps you are confusing yourself with the phrase "moving emitter"--remember that in SR there is no absolute truth about what's moving and what isn't, Dash's emitter is moving relative to Still Bill, but then Still Bill's emitter is also a "moving emitter" in Dash's frame.
But do you have any actual argument for thinking this is how it will work? It's definitely not what relativity would predict.
