Photon travel time quadratic equation in Weinberg p. 72
36 replies · 5K views
Thanks a lot strangerep. The decomposition appears to be ##A = VDV^{-1}##, not ##VDV^T##, so it doesn't quite match up with our equation ##g=b^T\eta b##. Of course, ##A^{-1}=A^T## for orthogonal matrices, but is ##b## orthogonal?*
It is interesing to note that the definition of a Lorentz transformation is ##Λ^T\eta Λ=\eta## so we can see that when ##g=\eta## then ##b=Λ##, which does agree with the known fact that b is only defined up to a Lorentz transformation.
I'll try to tidy this up ... I think it still isn't clear enough to me ... but it does seem that Weinberg made a little bit of a jump here.
*Edit: Yes. Since g is symmetric, in fact ##g=VDV^T## where D is the diagonal matrix of eigenvalues of g, and V is the matrix of g's [orthogonal] eigenvectors. But our equation is ##g=b^T\eta b##, so ##b=V^T##. And again here it's obvious that b (or V) is valid up to a Lorentz transformation because ##Λ^T\eta Λ=\eta##.
Again many thanks. Your last post really helped me crack this.
As you note in your edit, ##A = VDV^T## is correct if ##g## is real symmetric. Additional discussion here.
[...] it does seem that Weinberg made a little bit of a jump here.
Yes -- that's an example of what I meant when I said that Weinberg tends to be more suitable as an advanced text. He requires rather more of his readers, and sometimes this isn't obvious -- as in the present case.
strangerep said:
It's just an application of eigendecomposition, i.e.,$$A ~=~ V D V^T ~,$$where ##D## is diagonal (with entries being the eigenvalues of ##A##), and the columns of ##V## are the eigenvectors of a (real, symmetric) matrix ##A##. In our case: $$g ~=~ b \eta b^T ~,$$ and the "constructive" solution for ##b## is obtained by finding eigenvectors of ##g##.
Note that in general, ##~g ~=~ b \eta b^T ~## is not an eigendecomposition of ##g##. The diagonal elements of ##\eta## are not, in general, the eigenvalues of ##g## and the columns of ##b## are not, in general, eigenvectors of ##g## .
As an example, suppose ##g =
\left( \begin{array}{cc}
7 & 4 \\
4 & 1 \\
\end{array} \right)##.
Then you can show that ##g = b \eta b^T## where ##\eta =
-1 &0 \\
0 & 1 \\
\end{array} \right)## and ##b =
3 & 4 \\
0 & 1 \\
But the eigendecomposition of ##g## is ##g = VDV^T ## where ##V =
1/\sqrt{5} &2/\sqrt{5} \\
-2/\sqrt{5} & 1/\sqrt{5} \\
\end{array} \right)## and ##D =
-1 &0 \\
0 & 9 \\
TSny said:
Note that in general, ##~g ~=~ b \eta b^T ~## is not an eigendecomposition of ##g##. [...]
Heh, I was wondering whether someone would mention that.
In GR, the equivalence principle motivates an assumption that we have a metric field with signature (-,+,+,+) at each point of spacetime. Indeed, Weinberg actually starts from ##\eta## and transforms to ##g## -- see p71. His ##b##'s are then also expressed as coord transformation coefficients -- see eqn(3.2.13).
IOW, we're not really starting from an arbitrary ##g##, but one with the right eigenvalues.
Strangerep, I agree. Weinberg's discussion starts from the equivalence principle. This implies that (3.2.14) must have a solution where the ##b##'s are associated with the coordinate transformation as in (3.2.13).
Still, the eigenvalues of ##g(X)## need not be the diagonal elements of ##\eta##.
But, as you say, you can't just start from any symmetric matrix ##g##. For example, taking the determinant of each side of (3.2.14) requires that the determinant of ##g## be negative.
The EP just says that you can, at any point ##x_0## in spacetime always find local coordinates in which ##g_{\mu \nu}(x_0)=\eta_{\mu \nu}##. This implies that the symmetric matrix at each point must have 1 negative and 3 positive eigenvalues (Sylvester's theorem).
Kostik said:
Weinberg starts this discussion in the middle of p. 72 by saying "The values of the metric tensor ##g_{\mu\nu}## and the affine connection ##Γ^\lambda_{\mu\nu}## at a point X in an arbitrary coordinate system ##x^\mu## PROVIDE ENOUGH INFORMATION TO DETERMINE THE LOCALLY INERTIAL COORDINATES ##\xi^\alpha## in a neighborhood of X." *This* is what I am not yet convinced of.
Thanks again for any help.
Weinberg’s statement is a provable statement. Let [itex]x = 0[/itex] be the point in question, and define new coordinates [itex]y^{\mu}[/itex] by
[tex]x^{\mu} = A^{\mu}{}_{\alpha}y^{\alpha} - \frac{1}{4} A^{\mu}{}_{\tau}B^{\tau}{}_{\alpha \beta}y^{\alpha}y^{\beta} , \ \ \ \ \ (1)[/tex] where [itex]A^{\mu}{}_{\alpha}[/itex] and [itex]B^{\tau}{}_{\alpha \beta} = B^{\tau}{}_{\beta \alpha}[/itex] are constants to be determined from reasonable requirements. At [itex]x = 0[/itex], any rank-2 tensor [itex]g_{\mu\nu}(x)[/itex] will therefore have the following transformation law [tex]\bar{g}_{\alpha\beta}(0) = A^{\mu}{}_{\alpha} \ g_{\mu\nu}(0) \ A^{\nu}{}_{\beta} . \ \ \ \ \ \ \ \ \ \ \ \ (2)[/tex] In matrix form, (2) reads [tex]\bar{g} = A^{T} \ g \ A . \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ (3)[/tex]
If [itex]g_{\mu\nu}(x)[/itex] is a metric tensor on some differentiable manifold [itex]M^{n}[/itex] then: (I) it must be symmetric, i.e., [itex]g_{\mu\nu}(x) = g_{\nu\mu}(x)[/itex]. And, more importantly: (II) In order to model our spacetime by an equivalent class of pairs [itex](M^{n} , g_{\mu\nu})[/itex], [itex]g_{\mu\nu}[/itex] must be a non-degenerate metric of Lorentz signature. (bellow I will be using the mostly minus signature).
Now,
(I) [itex]\Rightarrow \ \exists R \in O(n)[/itex] such that [itex]R^{T}gR = G[/itex] is diagonal, and
(II) [itex]\Rightarrow \ G = \mbox{diag}(\lambda_{0}^{2}, - \lambda_{1}^{2}, \cdots , - \lambda_{n-1}^{2})[/itex], where [itex]\lambda_{r} \neq 0 \ \forall r[/itex].
So, we have
[tex]R^{T} \ g \ R = \mbox{diag}(\lambda_{0}^{2}, -\lambda_{1}^{2}, -\lambda_{2}^{2} ,\cdots , -\lambda_{n-1}^{2}) . \ \ \ \ \ (4)[/tex] Define the matrix [itex]D = \mbox{diag}(1/\lambda_{0},1/\lambda_{1}, \cdots , 1/\lambda_{n-1})[/itex], and sandwich (4) by [itex]D[/itex] to obtain
[tex]DR^{T} \ g \ RD = \mbox{diag}(1, -1, -1, \cdots , -1) .[/tex] Thus [tex](RD)^{T} \ g \ (RD) = \eta . \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ (5)[/tex] However, for any [itex]\Lambda \in SO(1,n-1)[/itex] , we also have [tex](RD \Lambda )^{T} \ g \ (RD \Lambda ) = \Lambda^{T} \eta \Lambda = \eta .[/tex] So, we can set [tex]A^{\mu}{}_{\alpha} = (RD)^{\mu}{}_{\alpha} \ \ \mbox{mod} \ \Lambda \in SO(1,n-1) . \ \ \ \ \ \ (6)[/tex] Using the choice (6) together with (5), equation (2) or (3) gives us our first desired result, that is [tex]\bar{g}_{\alpha \beta}(0) = A^{\mu}{}_{\alpha} \ g_{\mu\nu}(0) \ A^{\nu}{}_{\beta} = \eta_{\alpha\beta} . \ \ \ \ \ \ (7)[/tex]
The fact that the matrix [itex](RD)[/itex] determines [itex]A[/itex] up to Lorentz transformations can also be deduced from parameter-counting: there are [itex]n^{2}[/itex] parameters in [itex]A[/itex], [itex]n[/itex] parameters in [itex]D[/itex] and [itex]\frac{1}{2}n(n-1)[/itex] parameters in the [itex]O(n)[/itex] matrix [itex]R[/itex]. This leaves us with the [itex]n^{2} - [\frac{1}{2}n(n-1) + n] = \frac{1}{2}n(n-1)[/itex] free parameters needed for a Lorentz transformation.
To complete the proof of Weinberg’s statement, we need to choose the constants [itex]B^{\mu}{}_{\alpha\beta}[/itex] so that, together with the choice (6) for [itex]A^{\mu}{}_{\alpha}[/itex], the system [itex]y[/itex], as defined in (1), becomes locally inertial system. This requires a bit of algebra which I will describe them for you. Differentiating the transformation law [tex]\bar{g}_{\alpha\beta}(y) = \frac{\partial x^{\mu}}{\partial y^{\alpha}} \frac{\partial x^{\nu}}{\partial y^{\beta}} g_{\mu\nu}(x) ,[/tex] with respect to [itex]y^{\gamma}[/itex], we get at [itex]x = 0[/itex]
[tex]\frac{\partial \bar{g}_{\alpha\beta}}{\partial y^{\gamma}}(0) = T_{\alpha\beta\gamma}(0) - \frac{1}{2}\left(A^{\mu}{}_{\alpha}g_{\mu\nu}(0) A^{\nu}{}_{\tau}\right) B^{\tau}{}_{\beta\gamma} - \frac{1}{2} \left(A^{\mu}{}_{\tau}g_{\mu\nu}(0)A^{\nu}{}_{\beta}\right) B^{\tau}{}_{\alpha\gamma} , \ \ (8)[/tex]
where we have defined the object [tex]T_{\alpha\beta\gamma}(0) \equiv A^{\mu}{}_{\alpha}A^{\nu}{}_{\beta}A^{\rho}{}_{\gamma} \frac{\partial g_{\mu\nu}}{\partial x^{\rho}}(0) . \ \ \ \ (9)[/tex]
Using our first result (7), we find
[tex]\frac{\partial \bar{g}_{\alpha\beta}}{\partial y^{\gamma}}(0) = T_{\alpha\beta\gamma}(0) - \frac{1}{2} (B_{\alpha\beta\gamma} + B_{\beta\alpha\gamma}) . \ \ \ \ (8')[/tex]
So, to complete the proof we need to solve the following equation for [itex]B_{\alpha\beta\gamma}[/itex]
[tex]T_{\alpha\beta\gamma} = \frac{1}{2}\left(B_{\alpha\beta\gamma} + B_{\beta\alpha\gamma}\right) . \ \ \ (10)[/tex]
To do this, write another 2 copy of (10) using the permutation [itex](\alpha\beta\gamma) \to (\gamma\alpha\beta) \to (\beta\gamma\alpha)[/itex], then add the first two and subtract the third one. Then, due to [itex]B_{\alpha\beta\gamma} = B_{\alpha\gamma\beta}[/itex], you obtain the final result
[tex]B_{\alpha\beta\gamma} = T_{\alpha\beta\gamma}(0) + T_{\gamma\alpha\beta} (0) - T_{\beta\gamma\alpha}(0) ,[/tex] with [itex]T(0)[/itex] as defined by (9).
So, from the values of [itex]g_{\mu\nu}(0)[/itex] and [itex]\partial g (0) \sim \Gamma (0)[/itex] we were able to determine (up to Lorentz transformation) the constants [itex]A[/itex] and [itex]B[/itex] that are needed to make the [itex]y[/itex]-system locally inertial.
