Physical Properties Dimethyl ether vs ethanol
The discussion focuses on the differences in solubility in water and evaporation rates between dimethyl ether and ethanol. Dimethyl ether is immiscible with water due to its molecular structure, which lacks a dipole necessary for hydrogen bonding, while ethanol is miscible because it can form hydrogen bonds. Additionally, dimethyl ether evaporates more quickly than ethanol due to weaker Van der Waals forces compared to the stronger hydrogen bonds present in ethanol. It is noted that dimethyl ether can contain small amounts of water, indicating some interaction between the two substances.
  • Understanding of molecular polarity and dipole moments
  • Knowledge of hydrogen bonding and intermolecular forces
  • Familiarity with the concepts of miscibility and solubility
  • Basic principles of evaporation and boiling points
  • Research the molecular structure of dimethyl ether and ethanol
  • Study the principles of hydrogen bonding and its effects on solubility
  • Explore the concept of intermolecular forces and their impact on evaporation rates
  • Investigate the effects of temperature on the miscibility of organic compounds
Chemistry students, educators, and professionals interested in organic chemistry, particularly those studying the physical properties of alcohols and ethers.
trollcast
Explain the difference in the following properties of dimethyl ether and ethanol:
1) Solubility in water
2) Rate of evaporation
1) Due to the oxygen being bonded to 2 carbon atoms none of the hydrogen atoms in the dimethyl ether molcule have a dipole. This means that diethyl ether cannot form hydrogen bonds with the water molecules, this means the dimethyl ether is immiscible with water.
In ethanol the oxygen atom is bonded to a hydrogen which gives it a dipole, this allows the ethanol molecule to form hydrogen bonds with the water molecules and therefore it is miscible with water.
2) As noted above dimethyl ether cannot from hydrogen bonds. This means that the only intermolecular forces are Van der Waal's forces. These are weaker than the hydrogen bonds that can form between ethanol molecules. As both molecules have the same RFM this would imply that diethyl ether will boil at a lower temperature and therefore evaporate more quickly at a given temperature compared to ethanol.
I just wanted to check if my answers made sense and if I had used the right words in places.
It makes sense.
Only one extra detail: ether is not totally immiscible with water. In fact depending on how it is made most ether will contain a little water. Dry ether will absorb water from the atmosphere unless prevented.
If you add water to ether or vice versa they mix till the ether is about 7%, then they separate into two layers; the ether layer contains some water and the water layer some ether.
So you have to think there is still some dipolar interaction between water molecules and the O of the ether.
20K
11K
  • · Replies 16 ·
  • · Replies 16 ·
