Post form of a living hinge as a joint
  • Thread starter Thread starter mikesydwest
    Form Hinge Joint
The discussion revolves around the design and material considerations for a joint that incorporates a living hinge. Participants explore the dimensions and structural integrity of the hinge, as well as potential manufacturing methods such as ultrasonic welding.
  • One participant describes a hinge with a length of 220 mm and an inter radius of 1.8 mm, expressing uncertainty about how to introduce the material for the hinge while maintaining rigidity in larger parts.
  • Another participant questions the feasibility of the stated dimensions, suggesting that a 220 mm length with a 1.8 mm radius seems impractical.
  • A participant defends the dimensions, clarifying that the hinge is indeed 220 mm long and 3 mm wide, and emphasizes the need for respectful dialogue while seeking assistance.
  • Further clarification is provided regarding the hinge's dimensions, with a participant noting that the yellow part depicted is a short segment of the overall hinge.
  • Another participant expresses similar confusion about the dimensions and requests a dimensioned sketch for better understanding, while also inquiring about the material requirements for the hinge.
  • There is a suggestion to improve the thread title for clarity, as the current title does not effectively convey the topic being discussed.
Participants express differing views on the feasibility of the hinge dimensions, with some finding them questionable while others defend their validity. The discussion remains unresolved regarding the optimal design and material choices.
There are limitations in the clarity of the dimensions provided, and the discussion includes assumptions about the material properties and structural requirements that are not fully detailed.
mikesydwest
How did you find PF?: google
Hi
I have a scenario where I just cannot make up my mind when creating this joint and hinge at the same time.
Obviously yellow is the hinge, red section to the left has two wings hanging off it held there by two hinges, 250 um.
thinking about ultra sonics to weld this or form the hinge and weld at same time I should say. The hinge length is 220 mm and the inter rad of the hinge is 1.8mm.
The stumbling bloke is how do I introduce the material for the hinge, especially when I consider the idea of a softer PP than what is used on the larger parts. Rigidity on the larger parts is imperative.
I must be missing something, as I find that combination ridiculous. Did you mean the width is 220mm? With a 1.8mm radius turn, 220mm would wrap around it about 10 times
ridiculous hmm , the length of the hinge is 220mm long, the width is 3mm in a 45 deg ark at approx. 1.8 mm rad, think about it, its not ridiculous. please do not be rude I just look for help not ridicule.
did you look at the images, hinges do not wrap around them selves
the yellow part is a short piece of the hinge, its 5mm long in this image - it is 220 long spanning the length of the part
I SPECIFICALLY said I must be missing something.
cool
Welcome to the PF. :smile:
I'm also having the same problems understanding these dimensions like @phinds is. Do you have a dimensioned sketch of what you are trying to do?
Also, what material do you want to use for this "hinge"? Can you just use fabric? Or does it need to be some special material?
And I'd like to try to fix up your thread title a bit to help your thread get more views. I'm not able to parse what you are saying in the current title below -- can you think of an alternate title that may explain better what you are asking? What is "living" here? Thank you.
Post form of living hinge as joint
its all good thanks, sorry to make a nuisance
