Pressure from CO2 molecules striking a wall
  • Thread starter Thread starter zeshkani
14 replies · 3K views · last reply
zeshkani
If 1.0 x 10^23 carbon dioxide molecules strike 1.0 cm2 of wall per second at a 90o angle to the wall when moving toward it with a speed of 45,000 cm/s, what pressure (in atm) do they exert on the wall?
does anybody know what equation to use for this problem ??
zeshkani said:
well iit can't be P=nRT/V
That's correct... that is not the definition of pressure.. but merely an important equation that is applicable in certain situations.
well can't i just convert the molecules into grams, then into kilograms then use F=MA
to get force then convert it into atm, but what do i do with the 1.0cm2 wall, those that even matter
oh and the definition of pressure is P=F/A
F/A is right. I think robphy would now ask you if you remember that force is also the time rate of change of momentum. Since momentum=mv and F=ma and a=dv/dt. What's the time rate of change of momentum for your collection of molecules?
ok well i can't use F=ma since the problem has a velocity and not acceleration, but momentum can be used in this way, i hope iam right :)
so F = P/t
So for P =(CO2 in Kg * 450m/s) then F= (CO2Kg*450m/s)/(1sec) then when i get Force put it bake into P=F/A
so then
P= (CO2Kg*450m/s)/(1sec)/(1.00cm^2) those this seem right ??
Does the CO2 bounce off the wall or stick to it? There's a factor of two in the momentum change between the two cases since after the bounce they are now going 450m/sec AWAY from the wall. I'm assuming you mean them to bounce.
well since its a gas it would bounce of the wall and this is the question again
"If 1.0 x 10^23 carbon dioxide molecules strike 1.0 cm2 of wall per second at a 90o angle to the wall when moving toward it with a speed of 45,000 cm/s, what pressure (in atm) do they exert on the wall?"
and this is what i got when i sloved it
P=(.007308Kg of CO2)(450m/s)
P= 3.28869
so then
F= 3.288869/1sec
F= 3.28869
and fianlly
P= 3.28869/.0001m^2
i converted the area of 1.00cm^2 to .0001m^2 and used this as area instead does this seem right
and my finaly answer in Pressure in Pascal = 32886.91
Your numbers seem right, except you weren't listening. F is not equal to P/t. It's equal to delta(P)/delta(t). P is +mv before it hits the wall and -mv after it hits the wall. What's the delta P?
And before someone stomps me here, yes, the real expression is F=dP/dt. It's a rate.
The force exerted by the gas on a patch of the wall is equal to the rate at which that patch of wall is changing the momentum of the gas molecules. Your answer is off by a factor of two, because to change P to -P I need a delta(P) of 2*P. I seem to be just repeating myself...
so would be something like this if iam understanding right
P=(.007308Kg of CO2)(450m/s)*2
P= 6.57738
so then
F= 6.57738/1sec
F= 6.57738
and fianlly
P= 6.57738/.0001m^2
and my finaly answer in Pressure in Pascal = 65773.8
