Presumably simple logarithm equationt
  • Thread starter Thread starter Chase.
    Logarithm
The equation 6 * e^(2x) = 4x requires finding the value of x that satisfies it. The initial approach incorrectly attempts to manipulate the equation by moving constants into the exponent. Instead, taking the natural logarithm of both sides from the start is recommended, leading to ln(6) + 2x = x * ln(4). This method simplifies the problem and allows for further manipulation to isolate x. The discussion emphasizes the importance of correct logarithmic properties in solving the equation.
Chase.
What value of x satisfies the equation:
6 \cdot e2x = 4x
If I'm not mistaken, I can move the 6 to the superscripted part of e, resulting in:
e12x = 4x
And then I can take the natural log of both sides, resulting in:
12x = ln(4x)
Assuming I haven't made any mistakes, this is what I have so far and I'm stuck. This is for a practice test and I have the answer listed as:
ln6 / (ln4 - 2)
I'm just not sure how to get there.
6 \cdot e2x = 4x
e12x = 4x
You are mistaken. You can't do that. E.g. 2*32 = 18 ≠ 34 = 81.
12x = ln(4x)
Just start with taking the ln of both sides right from the beginning:
ln(6*e2x) = ln(4x)
The log of a product is the sum of the logs:
ln6 + 2x = xln4
Can you take it from here?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
