Proof d/dx e^x=e^x using substitution
19 replies · 8K views
Jkohn
Proof d/dx e^x=e^x, use e=limit (1+1/h)^h h->infinity
Show how that implies d/dx e^x=e^x
t
Ive tried using chain rule--wasnt accepted
Also, I did e=(1+h)^[1/h]-->e^h=1+h, then reduced to e^x, still didnt accept
How can I prove it using limit substitution? He told me to google finding limits by substitution then he said e^h-1=U
So have you tried taking the derivative of ex in the limit form?
[tex]\frac{d}{dx}e^x=\frac{d}{dx}\lim_{h\to \infty}\left(1+\frac{1}{h}\right)^{hx}[/tex]
Ive attempted, but its a limit inside a limit?
Aren't you allowed to use the derivative rules? [tex]\frac{d}{dx}a^{cx}=c\ln(a)a^{cx}[/tex]
Exactly what i did when he first said, its obvious, but he wants mathematical reasoning using limits..
[tex](e^x)'=\lim_{\delta\to 0}\dfrac{e^{x+\delta}-e^{x}}{\delta}=e^{x}\lim_{\delta\to 0}\dfrac{e^{\delta}-1}{\delta}[/tex]
Now you want to show
[tex]\lim_{\delta\to 0}\dfrac{e^{\delta}-1}{\delta}=1[/tex]
And you are given that
[tex]\lim_{h\to \infty}\left(1+\frac{1}{h}\right)^{h}=e[/tex]
That's very close. Don't forget the hint you are given: letting u=e^h-1.
Hmm... ok...
Can you clarify what he meant by e^h-1=U?
What about if we tried to just go back to the basics. So we'll use any positive number a,
[tex]\frac{d}{dx}a^x=\lim_{h\to 0}\frac{a^{x+h}-a^x}{h}[/tex]
[tex]=\lim_{h\to 0}\frac{a^xa^h-a^x}{h}[/tex]
[tex]=a^x\lim_{h\to 0}\frac{a^h-1}{h}[/tex]
Now, we're interested in the case where the limit is equal to 1,
[tex]\lim_{h\to 0}\frac{a^h-1}{h}=1[/tex]
[tex]\lim_{h\to 0}a^h-1=\lim_{h\to 0} h[/tex]
[tex]\lim_{h\to 0}a^h =\lim_{h\to 0}1+h[/tex]
Can you see where this is heading?
edit: klondike beat me to it.
uh-oh, this doesn't sound right.
Mentallic said:
Hmm... ok...
Put that in my "attempts" he says that e^h ≠ (1+h) because its a ≈ and not =, I even told him under a certain domain "its true" he won't accept lol..
So what exactly should I be substituting??
Actually, yeah, you're right. We should be starting off with the limit expression for e.
let [tex]\frac{1}{h}=e^{\delta}-1 \quad;; h\to \infty \quad as \quad \delta \to 0[/tex] then write δ in terms of h, and plug them back in, and you are all set.
Im a bit confused here. Where are you getting the (1/h)=e^δ−1 from?
Because e^δ−1 goes zero as δ goes zero. You want some quantity goes zero as something goes zero or, more conveniently as something goes infinity as you are given a known limit as its independent variable goes infinity.
Hence, it's mostly conveniently to set the quantity to 1/h as h approach infinity. It satisfies both condition and closely resemble what you are given.
You can, of course first set y=e^δ−1 as well.
how do I put δ in terms of h..where am I plugging it in??
EDIT: SORRY I realized h=1/(e^δ - 1)
do I insert that h into the e= limit (1+ 1/h)^h ??
thanks
[tex]e^{\delta}-1=\frac{1}{h}[/tex]
[tex]\delta=ln(1+\frac{1}{h})[/tex]
And put these 2 into it. And recall that aln(x)=ln(x^a). I'm sure you will figure it out.
mhm I am doing this:
lim e^δ−1/ δ =1
e^δ - 1= 1/h
δ=ln(1+ 1/h)
so I get: limit [(1/h)]/ [ln(1+(1/h))] h-->infinity
Im getting 1
Now go back to check post #6. Isn't that what you're trying to prove?
lim e^δ−1/ δ =1
e^δ - 1= 1/h
δ=ln(1+ 1/h)
Im getting 1
