Proving 0!=1: An Analysis of the Fundamental Mathematical Concept
  • Thread starter Thread starter rock.freak667
    Proof
The discussion centers on the mathematical proof that 0! = 1, a fundamental concept in combinatorics and calculus. Participants highlight that 0! is defined as 1 to maintain consistency in mathematical equations, particularly in permutations and combinations. The recursive definition of factorial, n! = n * (n-1)!, leads to the conclusion that 0! must equal 1 when n = 1. Additionally, the gamma function, Γ(z), provides a formal basis for this definition, as Γ(1) = 0! = 1.
  • Understanding of factorial notation and definitions
  • Familiarity with recursive functions in mathematics
  • Basic knowledge of the gamma function, Γ(z)
  • Combinatorial principles, specifically permutations and combinations
  • Study the properties and applications of the gamma function, Γ(z)
  • Explore combinatorial proofs for factorial definitions
  • Learn about recursive definitions in mathematics
  • Investigate the implications of defining operations for non-positive integers
Students of mathematics, educators teaching combinatorics, and anyone interested in the foundations of mathematical definitions and proofs.
rock.freak667
Proof that 0!=1??
How does one prove that 0!=1, which I've only been told to accept as true.
n!=n(n-1)(n-2)(n-3)*...*3*2*1
well using the def'n for n!
0!=0(-1)(-2)(-3)(-4)(-5)*...*3*2*1
which should be zero as...any number by 0 is 0
It is a matter of definition. Period.
For n>=1, we have the recursive relationship n!=n*(n-1)!
Yes, it's a matter of definition, but this is a useful definition. Note that arildno's recursion relation can be written as (n-1)!=n!/n. Plugging in n=1 yields 0!=1.
Also, formulas like e^x = \sum_{n=0}^\infty x^n/n! only work if 0!=1.
hm...but then the same goes for 1!...as that is the same as 0! by the definition of n!
How many ways can you order 0 things? 1 way!
I had originally thought that you were asking why 0 was not equal to 1. A very interesting question to pose compared to other more tired equalities.
Well, no. Formally these things are defined recursively starting at 1.
Yes, 1!=1 as well.
Do you know about the gamma function?
\Gamma(z) = \int_0^\infty dt\,t^{z-1}\,e^{-t}.
This has the interesting property that for an integer n, \Gamma(n)=(n-1)!
For more, see http://en.wikipedia.org/wiki/Gamma_function
never heard of this gamma function...shall read now
We also define 0! = 1 to provide consistency in the equations for nPr and nCr : when r = 0 or r = n, the formula should give values of 1. This will only be possible if (n-n)! equals 1.
There are a number of such situations in mathematics where an operation originally defined only for positive integers ("counting numbers"), as evolved from ordinary human uses, is extended to larger sets of numbers. A widely-used example is x^n .
So then I guess there is no way to prove it but it is just taken as 1 just to make things simpler
Yes, that's basically it.
Actually, there is an algebraic proof. Try a search of physicforums. I know I saw the proof somewhere, but I cannot remember exactly where, and I do not remember this proof myself.
http://www.jimloy.com/algebra/zero-f.htm
What do you think a "proof" is?
It is a valid deduction from ACCEPTED AXIOMS OR DEFINITIONS.
Thus, that some statement is an axiom or a definition is NOT some flaw with it as if ideally we would have liked to prove it.
Of course, we have the freedom to choose another set of axioms&definitions than the "standard" set; in that case, axioms in another set might be needed to be proved, and vice versa.
Specifically, if we CHOOSE to define the factorial in terms of the gamma function, then we may prove the statement 0!=1.
I can't agree with that. We'd like to use the minimal number of axioms. If one can be shown to be derivable from the others, that's an improvement. People spent 2000 years trying to show that Euclid's fifth postulate was derivable before concluding that it couldn't be done.
I can agree to that; I should have inserted the word "necesssarily" in "...is NOT necessarily a flaw..", which should cover the instances you mentioned.
To Prove:- 0! =1.
Known:
y! = y x (y-1)!
So,
1! = 1 x (1-1)!
1! = 0!
or
0! = 1! -(a)
Proof:
As We know,
n! = n x n-1 x n-2 x n-3 x n-4 x ... 2 x 1
So,
4! = (3+1)! = 4 x 3! = 4 x 3 x 2 x 1
3! = (2+1)! = 3 x 2! = 3 x 2 x 1
2! = (1+1)! = 2 x 1! = 2 x 1
1! = (0+1)! = 1 x 0! = 1 -(b)
Hence, from (a) and (b)
We get, 0! = 1
Personally I tend to prefer the combinatorial approach. There is just one way to choose 0 objects from a set of n objects, hence:
<br /> ^{n}C_{0} = \frac{n!}{(n-0)!(0!)} = \frac{1}{0!} = 1<br />
which thus implies that 0! = 1
rjoshi1906 said:
To Prove:- 0! =1.
Known:
y! = y x (y-1)!
This is "known" for what values of y? And how is it known? Exactly what definition of factorial are you using?
So,
1! = 1 x (1-1)!
1! = 0!
or
0! = 1! -(a)
Proof:
As We know,
So,
We get, 0! = 1
By exactly the same "proof" then, 0!= 0(0-1)!. But 0 times any number is 0 so whatever (-1)! is, 0!= 0.
Well then couldn't (-1)! simply be undefined to keep the consistency that 0!=1.
In the same way that lim_{x \rightarrow 0}\left(x.\frac{1}{x}\right)=1you are similarly saying that the first factor x=0 but whatever the next factor 1/x is equal to, the RHS should equal 0 since 0 times any other number is 0. This is not the case however.
f(x)= x^5 = [5!/5!] x5
f(x)(1)= 5x^4 = [5!/4!] x^4
f(x)(2)= 20x^3 = [5!/3!] x^3
f(x)(3)= 60x^2 = [5!/2!] x^2
f(x)(4)= 120x^1 = [5!/1!] x^1
f(x)(5)= 120x^0 = [5!/0!] x^0 [Following the observed pattern… ]
f(x)(k)= n!/((n-k)!) [x^(n-k)] […in general, for coefficient of x^n = 1, and n a positive real integer ]
Since f(x)(5) = 120, we must conclude that 0! = 1
alright, consider the gamma function:
Γ(z)=∫(t^(z-1)e^(-t)dt, 0, infinity)
which has the property Γ(z+1)=zΓ(z) (too long to prove, look it up),
in turn implying that Γ(z+1)=z!
so 0!=Γ(0+1)=Γ(1)
Γ(1)=∫(t^(1-1)e^(-t)dt, 0, infinity)
=∫(e^(-t)dt, 0, infinity)
= -e^(-t), 0, infinity
=0-(-1)
=1
sorry for the poor formatting, but I hope you get the idea here. The gamma function can also show that (1/2)!=sqrt(pi)
Agreed. There are some sets containing X such that X*a=a (X==1) and X+a=a (X==0) for all a. Depending on the definition of '*' and '+', I suppose there could be more than one such set.
So, I don't know what the OP means, really. I mean, if we're talking Peano's integers, then 1!=0 because 1 is the successor of 0. If we're talking real numbers, then those are an extension of the former...
lol, I get it now. Not "prove that 0 is different from 1", but "prove that factorial of 0 is 1".
Just refer to the definition of factorial, then, 0! = 1 does not contain ANY information whatsoever.
You've been told to accept it as true because it is a convenient convention. Just like any other word, n! means nothing unless we agree on a meaning for it. Well, n! means n*((n-1)!) if n >0 and 0! means 1. People could have agreed that n! means n*((n-1)!) if n >1, that 1! means 1, and that 0! means nothing, but that would be inconvenient in most applications even though both conventions coincide for any n>0.
This thread is some years old!
Indeed. I'm a new joiner. This post was on top of some category.
But, not matter how old the thread is, it is very frustrating that it did not meet its purpose : some high school student asked why 0! = 1 ; most replies were tentative demonstrations, hence gibberish. The answer the OP needed had nothing to do with the Γ function
If some other student googles this question, he may be glad to find my reply, however old it may be.
Regards.
Regards.
Now I realize you are the OP :) Well, you got my point, right ?
The fact that 0!=1 is not a convention, it is a mathematical fact (not something we "agreed" on). And his can be proved, as the OP was asking. The Γ function is unique because it shows step by step that 0!=1, without any subjective reasoning. To further my point, we could not have decided that (1/2)!=sqrt(pi), but we can derive it.
And this post is super old, but it's never too late to revisit it!
If I understand correctly, you define n!=Γ(n+1) for all integer and I define n!=n(n-1)...1. In the scope of my definition, 0! is NOT defined.
Depending on the OP's definition of n!, either the Γ function argument is (obviously) a satisfactory answer to his question, or there is no absolute answer because it is a matter of convention. In this later case, agreed, the Γ function argument would be one among many other justifications of the convenient convention 0!=1.
Considering "The attempt at a solution" of the OP, it seemed obvious to me that he was working in the set of integers, and that he was looking for an (impossible) arithmetic proof. I agree that your analytic definition is on top of the pure arithmeric one, but it does rely on a much heavier set of axioms.
Apologies if I'm starting to sound like a troll :)
Cheers
  • · Replies 19 ·
