Proper Time Interval: A Puzzler
The discussion revolves around the concept of proper time intervals in Special Relativity and the confusion regarding the perspective from which they are measured. Proper time is defined as the time interval between two events as measured by an observer who perceives the events occurring at the same point in space. The example of an observer on a moving train measuring the time for light to travel vertically is clarified; within the train's frame of reference, the observer remains at the same position during both events. It is emphasized that "point in space" is frame-dependent, meaning it varies based on the observer's reference frame. Understanding these nuances helps clarify the measurement of proper time in different contexts.
cdenne
Hello. I'm having trouble figuring out from which perspective to measure the proper time interval for Special Relativity. In the textbook, the definition says it's "the time interval between two events measured by an observer who sees the events occur at the same point in space." But in the derivation of the formula for time dilation, the authors use an example with two observers, one on a moving train, one stationary on Earth. The observer on the train measures the proper time interval as being the time it takes for a beam from a flashlight to go up (directly vertical), bounce off a mirror on the ceiling directly above the observer and return to the flashlight. But as I see it, the observer is not viewing the two events (the light leaving the flashlight and the light returning to the flashlight) at the same point in space because they've moved down the track and are in a different position from when the light left the flashlight. If anyone can help me with this, I'd appreciate it. Thanks.
I don't know much Special Relativity, so sorry if I'm wrong.
They've only "moved down the track" from the perspective of someone outside of the train. Within the train perspective, though, the flashlight's "position" is the same.
Thank you for your response. I thought about that as I was typing the post. "The same position in space" probably refers to the reference frame in which the two events take place. From that perspective, the observer on the train is still in the same position on the train when both events occur whereas the observer outside the train has moved by the time the second event occurs.
cdenne said:
In the textbook, the definition says it's "the time interval between two events measured by an observer who sees the events occur at the same point in space." .
Yes, you have figured it out (in post#3). It should say "by an observer who sees the events occur at the same point in space IN HIS FRAME OF REFERENCE".
There is no such thing as a "point in space" except as referenced against some OTHER point. That is "point in space" is frame dependent.
Great. Thank you.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
