Prove 5|(2^n a) implies 5|a by induction
10 replies · 5K views · last reply
issacnewton
Suppose ##a \mathbb{Z}##. Prove that ##5 | (2^n a) \rightarrow (5 | a)## for any ##n \in \mathbb{N}##
Mathematical Induction
Following is my proof. Let ##P(n)## be the statement that ##5 | (2^n a) \rightarrow (5 | a)##. Here ## n \in \mathbb{N}## and ##a \in \mathbb{Z}##. Base case is ##n = 1##. Suppose that ##5 | (2^1 a)##. This means that ## 2a = 5m## for some ##m \in \mathbb{Z}##. Now ##5m## is even. Since ##5## is not even, ##m## must be even. Let ##m = 2n## for some ##n \in \mathbb{Z}##. Then ##2a = 5(2n)##. We have, ##a = 5n##. So, ##5 | a##. So, ##5 | (2^1 a)## implies ##5 | a##. So, ##P(1)## is true. Now, let ## k \geq 1## be arbitrary in ##\mathbb{N}##. Suppose that ##P(k)## is true.
$$ 5 | (2^k a) \rightarrow (5 | a) $$
we have to prove that
$$ 5 | (2^{k + 1} a) \rightarrow (5 | a) $$
Suppose, ## 5 | 2^{k+1} a##. So, ## 2^{k+1} a= 5m## for some ##m \in \mathbb{Z}##. It means that ## 2(2^k a) = 5m##. As before, since ##5m## is an even number, ##m## must be even. Let ##m = 2n## for some ##n \in \mathbb{Z}##. So, we get ##2^k a = 5n##. Hence ##5 | (2^k a)##. Using, induction hypothesis, it follows that ##5 | a##. This means that ##P(k+1)## is true. This means that
$$ \forall k \geq 1 [P(k) \rightarrow P(k+1)] $$
So, by induction, its proven that
$$ 5 | (2^n a) \rightarrow (5 | a) $$
for any ## n \in \mathbb{N}##. Is this a valid proof ?
Thanks
I'm not a math whiz, but it looks pretty good to me.
Note the statement is true for ##n=0## as well.
issacnewton said:
Homework Statement: Suppose ##a \mathbb{Z}##. Prove that ##5 | (2^n a) \rightarrow (5 | a)## for any ##n \in \mathbb{N}##
Relevant Equations: Mathematical Induction
Suppose that ##5|(2^1a)##. This means that ##2a=5m## for some ##m∈Z##. Now ##5m## is even. Since ##5## is not even, ##m## must be even. Let ##m=2n## for some ##n∈Z##. Then ##2a=5(2n)##. We have, ##a=5n##. So, ##5|a##. So, ##5|(2^1a)## implies ##5|a##.
Why to use the induction? Just modify your first paragraph (quoted above) like this:
Suppose that ##5|(2^na)##. This means that ##2^na=5m## for some ##m∈Z##. Since ##5## does not divide ##2^n##, ##m## must. Let ##m=2^nk## for some ##k∈Z##. Then ##2^na=5(2^nk)##. We have, ##a=5k##. So, ##5|a##. So, ##5|(2^na)## implies ##5|a##.
  • Skeptical
This is basically the definition of a prime number. A number ##p## is prime if it is not invertible and ##p\,|\,a\cdot b## implies ##p\,|\,a## or ##p\,|\,b##.
The only invertible numbers are ##\pm 1,## and ##5## is prime. Since ##5\,\nmid\,2^n## we may conclude ##5\,|\,a.##
Now, you could ask why ##5## is prime. The reason is, that ##5## is irreducible (cannot be written as a product with factors that are not invertible - this rules out that we write ##5=(-1)\cdot (-1)\cdot 5##) and irreducibility and primality are identical in the domain of integers. You could try to show this equivalence.
Well, arguably more practical, test the ( finitely many) possible divisors of 5.
Edit: Show too, that ##5| 2^{n}## never happens because all multiples of## 5 ##end in ##\{0,5\}## , while all powers of ##2## end in## \{2,4,6,8\}##
Or you take the big canon again.
##5\,\nmid\,2.## If ##5\,|\,2^n=2\cdot (2^{n-1})## then ##5\,|\,2^{n-1}## since ##5## is prime. But ##5\,\nmid\,2^{n-1}## by induction hypothesis, contradicting the assumption that ##5\,|\,2^n.##
Of course, the even bigger cannon, the FTA solves all at once.
Seems your phrase doesn't translate that well to English. Do you mean along the lines of " Using a tank to kill a fly"?
So far so good.
What do you use here, FTA? Why is this the case? I do not see it. Maybe a language issue? I complete the missing sentence as
Hill said:
Since ##5## does not divide ##2^n##, ##m## must [divide ##2^n##].
If we assume ##5=2\cdot b## and ##n=1## then it does not follow that ##m\,|\,2.## Please explain how
5\nmid 2^n \wedge 5m=2^na \Longrightarrow m|2^n
Edit: ##5\nmid 2^3=8## and ##5\cdot 24= 2^3\cdot 15## but ##24## does not divide ##8.##
If you wanted to say ...
Hill said:
Since ##5## does not divide ##2^n##, ##m## must [be divided by ##2^n##].
... then how does this differ from what had to be shown anyway? I'm confused by your argument and the missing part of your sentence.
Yes. We say "Shooting at sparrows with cannons". Wiki says cannon is the correct translation:
https://en.wikipedia.org/wiki/Cannon
FTA = fundamental theorem of arithmetics, which is a big cannon to shoot at a prime number
Edit: This idiom is far older than Captain Sparrow's difficulties with authorities having cannons to shoot at him. And before I forget, Captain Sparrow's real-world name has a meaning in German, too, even though not a nice one.
fresh_42 said:
So far so good.
You are right. I actually meant your first version of the completed sentence, but my shortcut is wrong anyway.
Suppose that P(k) is true.
5|(2ka)→(5|a)
5|(2k+1a)→(5|a)
## 5|(2^{k+1}a) \Rightarrow 5|(2^k2a) \Rightarrow 5|(2a) \Rightarrow 5|a ##
