Prove |a+b+c| ≤ |a|+|b|+|c|
6 replies · 10K views · last reply
Seda
Prove that abs(a+b+c) is less than or equal to abs(a)+abs(b)+abs(c)
None
This makes sense to me that this would always be true, but i just can't seem to figure out how to write it out
Write it as abs((a+b)+c) then use the triangle inequality a couple times.
Are you asking to prove |a+b+c| < |a| + |b| + |c| given |a+b| < |a| + |b|? Or do you need to prove |a+b| < |a| + |b| as well?
Yes, we are given that the triangle inequality is true, (and we also know how to prove the triangle inequality if that helps.)
But it doesn't seem that I can prove this the same way.
I know abs(a+b) <= abs(a) + abs(b)
So I can very easily get that abs(a+b) + abs(c) <= abs(a) + abs(b) + abs(c)
But how do I a get the left half to what i want?
Let d = a+b. |d+c| < |d|+|c| by tri. ineq.
So, |a+b+c| < |a+b|+|c|.
Now use the tri. ineq. on a+b, then add |c| to both sides.
Think of (a+b) as a single number. That is, look at |x+ y| and then set x= a+b, y= c.
Wow...it seems so obvious now...
Sometimes I feel like a genius, others I feel stupid as hell, guess what's the case now?
Thanks so much.
