Proving 4(sin⁴x + cos⁴x) = cos(4x) + 3
12 replies · 4K views · last reply
phospho
Show that:
[itex]4(\sin^4x+\cos^4x) \equiv \cos4x + 3[/itex].
Really stuck with this, no idea how to go ahead with it. The book gives a hint: [itex]\sin ^4 x = (\sin ^2 x)^2[/itex] and use [itex]\cos 2x = 1 - 2\sin ^2 x[/itex]
But I don't even understand the hint, where did they get
[itex]\cos 2x = 1 - 2\sin ^2 x[/itex] from?
phospho said:
Show that:
This is one of three double-angle identities for cos(2x).
The other two are
cos(2x) = cos2(x) - sin2(x)
cos(2x) = 2cos2(x) - 1
The 2nd one above and the one you're asking about can be obtained from the first one I showed by using the identity sin2(x) + cos2(x) = 1.
cos2x=1−2sin2x from?
[tex]cos (x + x) = cos^2x - sin^2x = (1 - sin^2x) -sin^2x = 1 - 2sin^2x,[/tex] using the identity [itex]sin^2x +cos^2x =1[/itex]
To start you off, write the given equation as, [tex]4((\sin^2x)^2 + (\cos^2x)^2),[/tex] and use the double angle identities to get this solely in terms of [itex]\cos.[/itex]
You can start by using this:
a2+b2=(a+b)2-2ab
This would mean that:
[tex]4(\sin^4x+\cos^4x)=4((sin^2x+cos^2x)^2-2sin^2xcos^2x)[/tex]
Now rest should be easy to solve.
working :
[itex]4((sin^2x)^2 + (cos^4x)[/itex]
[itex]4((1-cos^2x)^2 + cos^4x))[/itex]
[itex]4(1-2cos^2x + cos^4x + cos^4x)[/itex]
[itex]4(1-2cos^2x + 2cos^4x)[/itex]
Pretty much stuck here.
a2+b2=(a+b)2-2ab
continuing from your working: [itex]4(1 - 2sin^2xcos^2x)[/itex], but I don't really know any identities to go from here...
How about doing the angle sum on the RHS: Cos4x= Cos(2x+2x) , and expand?
He doesn't have [itex]cos(4x)[/itex], he has [itex]cos^{4}(x)[/itex], or [itex](cos(x))^{4}[/itex]
phospho said:
working :
[itex]4((sin^2x)^2 + (cos^2x)^2)[/itex]
Use the following double-angle identities:
sin2(x)=0.5(1-cos(2x))
cos2(x)=0.5(1+cos(2x))
ehild
Bacle2 explicitly was referring to the right side of the original identity, which has a cos(4x) term in it.
See below.
Look at the RH side of the original post, it has a Cos(4x)+3.
Edit: Sorry, I did not see Mark44's post, and now I cannot see the 'delete' option.
Try using these identities:
i)sin(2x)=2sin(x)cos(x)
ii)cos(2x)=1-2sin2x
If you square both the sides of i identity, you may see a way through.
Use what ehild suggested if attempting the way I started (which is just one way to tackle the problem - there are many others).
We have, as suggested in my last post,
[itex]4((\sin^2x)^2 + (\cos^2x)^2)[/itex]
Now, use the double angle identities that ehild suggested, specifically [itex]\sin^2x = -\frac{1}{2}(\cos2x - 1)[/itex] and [itex]\cos^2x = \frac{1}{2}(cos2x +1)[/itex]
Substitute these into the eqn, expand the brackets and simplify...
