Proving a set to be a vector space,
5 replies · 5K views · last reply
u5022494
I know that a set (let's call it V) of all functions which map (R -> R) is a vector space under the usual multiplication and addition of real numbers, but i am having trouble proving it, i understand that the zero vector is f(x)=0, do i just have to prove that each element of V remains in V under additon and scalar multiplication? If that's the case then i can't work out how to go about proving it, if it isn't the case, then what exactly am i proving?
You have to notice that when you want to see how a set of functions forms a vector space, you are *not * taking the addition operation of real numbers.
f ( c ) may be a real number for any c, but the images of a function are not the function "object" itself. You need to think about how you can take two functions, add them, and have a resulting function that is still from R to R
No, that is not true. You don't have the correct definition of addition and scalar multiplication of functions. The usual multiplication of real numbers doesn't apply, since we are dealing with a space of functions.
The correct definitions are that V is a vector space under pointwise addition and scalar multiplication. What does that mean? If f and g are elements of V, then we define f+g to be the function defined by
(f+g)(x) = f(x) + g(x).
Now we have to verify that f+g, as defined, is in fact an element of V. You should prove that.
Scalar multiplication of a function f by a scalar a is defined as
(af)(x) = a * f(x).
Again, we need to show that if f is in V, then so is af for any scalar a.
Having shown that V is closed under addition and scalar multiplication as defined, you then need to verify each of the vector space axioms.
Yes, you need to prove that; then you need to prove that V satisfies the vector space axioms. I think you'll find it easier once you understand how addition and scalar multiplication of functions are defined. Did you understand the definitions I gave?
@ SteveL27, How would i go about proving those? perhaps an example would help considerably,
What i was thinking was that i could set V := {v1, v2, ... , vn} where each V is a function which maps R -> R and thus an element of V, but i can't quite get a rigorous proof using this notation..
I hope you can clear something up for me.
I'm not quite sure what you mean here with [itex]V=\{v_{1} ,v_{2} ,\dots ,v_{n} \}[/itex]. This would imply that [itex]V[/itex] has [itex]n[/itex] elements, which is not true if [itex]V[/itex] is a vector space. This can be seen that if [itex]V[/itex] is a vector space over the field [itex]\mathbb R[/itex] and [itex]f\in V[/itex], then [itex]af\in V,\,\forall a\in \mathbb R[/itex]. However, there are uncountably many [itex]a\in \mathbb R[/itex], so [itex]V[/itex] has much more than only [itex]n[/itex] elements.
Does that make sense? I hope it helps.
Do you mean for [itex]\{v_{1} ,v_{2} ,\dots ,v_{n} \}[/itex] to be a basis of [itex]V[/itex]? Because if so, then I want you to ask yourself if we know that [itex]V[/itex] is finite-dimensional.
We need to get the definition of addition and scalar multiplication clear first. Do you understand what the definitions of f+g and af for a scalar a? Your idea is unfortunately not in the right direction, but before discussing that, it's important to get the definition of V nailed down.
Are you taking a class or working from a book? Have you worked through other examples yet of being given a set with operations, and showing that it is or isn't a vector space?
