Proving C-linearity iff F(iX) = iF(X) in Tapp Prop 2.4
3 replies · 3K views
Math Amateur
MHB
TL;DR
I am reading Kristopher Tapp's book: Matrix Groups for Undergraduates.
I am currently focused on and studying Section 1 in Chapter2, namely:
"1. Complex Matrices as Real Matrices".
I need help in fully understanding how to prove an assertion related to Tapp's Proposition 2.4.
Proposition 2.4 and some comments following it read as follows:
In the remarks following Proposition 2.4 we read the following:
" ... ... It (##F##) is ##\mathbb{C}##-linear if and only if ##F(i \cdot X) = i \cdot F(X)## for all ##X \in \mathbb{C}^n## ... "My question is as follows ... can someone please demonstrate a proof of the fact that ##F## is ##\mathbb(C)##-linear if and only if ##F(i \cdot X) = i \cdot F(X)## for all ##X \in \mathbb{C}^n## ...
Help will be much appreciated ...
Peter===================================================================================
*** EDIT ***
After a little reflection it appears that " ... ##F## is ##\mathbb{C}##-linear ##\Longrightarrow F(i \cdot X) = i \cdot F(X)## ... " is immediate as ...
... taking ##c = i## we have ...
##F(c \cdot X ) = c \cdot F(X) \Longrightarrow F(i \cdot X) = i \cdot F(X)## for ##c \in \mathbb{C}##Is that correct?
Peter
Note that Tapp defines##\rho_n## and ##f_n## in the following text ... ...
Also note that ##R_B## (actually ##R_A##) is defined in the following text ...
Hope the provision of the above text helps with definitions, notation and context ...
Peter
The proof uses that a map ##T:V\to W## between ##\mathbb{C}##-vector spaces is ##\mathbb{C}##-linear if and only if if ##\mathbb{R}##-linear and ##T(iv)=iT(v)## for all ##v\in V##.
From left to right is obvious by the definition, from right to left requires a little easy two-line proof.
Note that in the proof one says that ##T## is ##\mathbb{C}## linear if and only if ##T(iv) = iT(v)## for all ##v\in V## since it was already established that ##T## was ##\mathbb{R}##-linear.
Thanks for the post and the hint ...
We are considering ##F \ : \ \mathbb{C}^n \to \mathbb{C}^n## where ##F = f_n^{ -1 } \circ R_B \circ f_n## ...
We know that ##F## is ##\mathbb{R}##-linear ... that is ...
##F(X + Y) = F(X) + F(Y)## for all ##X, Y \in \mathbb{C}^n## ... ... ... ... ... (1)
... and ...
##F(rX) = r F(X)## for all ##X \in \mathbb{C}^n## and ##r \in \mathbb{R}## ... ... ... ... ... (2)We have to prove that ##F## is ##\mathbb{C}##-linear ... ...
... that is ...
... which holds from the ##\mathbb{R}##-linear case ...
and ...
##F(cX) = cF(X)## for all ##X \in \mathbb{C}^n## and ##c \in \mathbb{C}## ... ... ... ... ... (3)So ... essentially we have to prove (3) ...
So then ... let ##c = a + bi## ... and proceed as follows ...
##F(cX) = F( (a+bi)X)##
##= F(aX + biX)##
##= F(aX) + F(biX)## since ##F## is ##\mathbb{R}##-linear
##= F(aX) + iF(bX)## since ##F(iY) = iF(Y)##
##= aF(X) + biF(X)## since ##F## is ##\mathbb{R}##-linear
##= (a +bi)F(X)##
##= cF(X)##Hope the above is correct ... ...
Peter
... and ...
... that is ...
and ...
##= F(aX + biX)##
##= (a +bi)F(X)##
Peter
Yes, completely correct. Well done!
