Proving Quadrilateral PQRS is a Parallelogram
  • Thread starter physics kiddy
    Geometry
7 replies · 3K views · last reply
physics kiddy
Recently, I bought a book and found a strange question :
In the given figure, PQRS is a quadrilateral. PO and QO are bisectors of angle P and angle Q respectively, then prove that angle QOP = 1/2 (angle R + angle S)
I made several attempts to get the solution but failed. I guess, we need to prove that PQRS is a parallelogram.
  • Geometry diagram of quadrilateral PQRS with vertices P (top), S (right), R (bottom) and Q (left), and an interior point O joined to P and Q, forming angle QOP.
Write out the sum of angles of the yellow pentagon.
ehild
  • Quadrilateral PQRS with diagonals meeting at O; the triangles OPS and ORS are shaded yellow. Angles at P and Q are labelled p/2 and q/2, with a and s marked near O, and r marked near R.
physics kiddy said:
It's 540 degrees.
OK. How is the angle a related to p/2 and q/2? What is the sum of angles of the pentagon in terms of a, p/2, q/2, r and s?
ehild
In triangle QOP, determine angle QOP, hence determine reflex angle QOP.
Physics kiddy disappeared...
p/2+q/2=180-a (triangle)
p/2+q/2+r+s+360-a=540 (pentagon) -->
180-a+r+s+360-a=540, 2a=r+s.
ehild
Thank you ! Thank you again. I disappeared because I found the solution in a book. But you wrote a completely new and easy method to solve this question. Now, I have got two ways to solve this question.
I would like to see that solution from the book so much! Could you please show it?:smile:
ehild
