Proving S ⊆ v + S₀ for solution sets of Ax = b
9 replies · 5K views · last reply
kramer733
http://people.math.carleton.ca/~mezo/A8math1102-11.pdf
1b) please
1. Suppose F is a field, A ∈ Mmn(F), b ∈ Fm and v ∈ Fn is a particular solution to the equation Ax = b. Let S0  ⊆ Fn be the solution set to
the (homogeneous) equation Ax = 0, and S ∈ Fn be the solution set
to Ax = b.
(a) Prove that the set v + S0 = {v + w : w ∈ S0} is a subset of S.
(b) Prove that S is a subset of v + S0. (Hint: Suppose w ∈ S. Show that w - v ∈ S0. What does this say about w?)
How do I even know that w ε S? That's a huge supposition isn't it? Well to prove that one set is a subset of the other set, all you need to do is prove that each share a common element right?
And we know that the Set S has the following elements:
1. v+w [from the last proof]
2. v [as stated from our supposition that " v ε F^n is a particular solution to Ax=b"]
3. x [as stated from our supposition " S subset F^n be the solution set to Ax=b"
and S_0 contains the following elements in it's set:
1. 0 [trivial solution]
2. w [v+S_0) is defined as {v+w: w ε S_0}
3. x [from our supposition "Let S_0 subset F^n be the solution set to the (homogenous) equation Ax=0."
So since both have x in their elements, can't we say that S subset (v+S_0)?
1b) please
Unless S is empty, it has to have some elements. Any vector w in S satisfies Aw = b.
No, not at all. Consider A = {1, 3, 5} and B = {1, 2, 3}. Both sets have 1 and 3 in common, but neither set is a subset of the other. For one set to be contained in another, each element of the first set must also be in the second set.
Thank you but w is also in S_0. So it has to be the same value as S_0 right? How do we know if w ε S?
Just so that other readers and I don't have to keep jumping from this page to the page you posted as a link, here is the problem statement. It would have been helpful for you to post it.
1. Suppose F is a field, A [itex]\in[/itex] Mmn(F), b [itex]\in[/itex] Fm and v [itex]\in[/itex] Fn is a particular solution to the equation Ax = b. Let S0  [itex]\subseteq[/itex] Fn be the solution set to
the (homogeneous) equation Ax = 0, and S [itex]\in[/itex] Fn be the solution set
to Ax = b.
(a) Prove that the set v + S0 = {v + w : w [itex]\in[/itex] S0} is a subset of S.
(b) Prove that S is a subset of v + S0. (Hint: Suppose w [itex]\in[/itex] S. Show that w - v [itex]\in[/itex] S0. What does this say about w?)
to Ax = b.
Sorry mate.
I'm getting the idea that you think you are providing a complete list of the elements of S. IOW, that S = {v+w, v, x}. That is not the case.
In #1 above the hypothesis probably was something like, "suppose v and w are in S." Then you showed that v+w was also in S, thereby showing that S was closed under vector addition. v and w are symbols that can represent any of a possibly infinite number of vectors.
Here's what i know now:
A ε M_mn (F) where F is a field
b ε F^m
v ε F^n [is a solution to Ax=b]
x ε F^n [is a solution to both Ax=b and Ax=0]
w ε F^n [since the definition states v+S_0 = {v+w: w ε S_0}]
S_0 is the solution set to equation Ax=0
S is the solution to Ax=b
I also know that A(v+w)=b. Then from there it follows that (v+w) is an element of S
But I'm not sure if i can say w ε S since (v+w) is an element of S.
I'm not able to make that next step to come to that conclusion. This is where I'm stuck at.Is it because (v+w) ε S, and S is a subset of F^n, then from the field axiom v ε F and w ε F?
kramer733 said:
But I'm not sure if i can say w ∈ S since (v+w) is an element of S.
Of course you can assume that w ∈ S. That's what "Suppose w ∈ S" means.
b ε F^m
Fine up to here.
No, what you wrote would imply that b=0.
The problem statement is saying that S is the solution set to the equation Ax=b. In other words, [itex]S = \{x \in F^n : Ax=b\}[/itex]. Similarly, you have [itex]S_0 = \{x \in F^n : Ax=0\}[/itex].
This isn't really a definition of w, which is really just a dummy variable here. The problem statement is saying the notation "v+S0" means "the set of vectors of the form v+w where w is some vector in S0." You could have just as well written [itex]v+S_0 = \{v+Z : Z \in S_0\}[/itex] That no more defines Z as the original definition defines w. Both w and Z are dummy variables. They have no meaning outside of the context of the definition of v+S0.
You have to somehow define w first. Note that the w in part (a) and the w in part (b) have absolutely nothing to do with each other.
You seem to be unclear on what you can assume.
To show S is a subset of v+S0, what you need to show is that for all vectors w in Fn, if w is in S, it is also in v+S0. So you assume w is in S and then show it follows that w is an element of v+S0. (If w is not in S, it doesn't matter because the implication is then automatically true.)
