Proving There's No Solution to csc(x)+cot(x)=1
  • Thread starter Thread starter e^(i Pi)+1=0
14 replies · 3K views
e^(i Pi)+1=0
solve this equation
csc(x)+cot(x)=1
after some symbol shunting this simplifies to sin-cos=1
I believe there is no solution to this problem. Let sin = a and cos = b
if a-b=1
then
a2+b2=1+2ab
but we know that a2+b2 must =1 therefor, no solution. Is this a valid proof?
e^(i Pi)+1=0 said:
solve this equation
csc(x)+cot(x)=1
if a-b=1
then
a2+b2=1+2ab
Not at all, a=1 and b=0 solves a-b=1.
Well then I am stumped. Are you saying there is a solution? It certainly doesn't look it when I graph it.
Of course there is a solution. What's the max value that sin(x) or cos(x) will output? Is there any angle x, such that sin(x) or cos(x) will output 1, and the equation sin(x) - cos(x) = 1 is still satisfied?
Clearly from that equation, you know that either:
a.) cos(x) outputs a value >0, and then to satisfy, sin(x) must output a value >1.
or...
You must be graphing it incorrectly then. Think about values of x where sin(x) is positive and cos(x) is negative. Can't it certainly be possible that sin(x)-cos(x)>1 in this case?
To begin solving this problem, try converting sin(x)-cos(x) into [itex]R\sin(x+\alpha)[/itex] for some constants R and [itex]\alpha[/itex] that you need to determine.
Well when you put it like that it's pretty damn obvious :shy:
Graphing [itex]\frac{1}{sin(x)}[/itex]+[itex]\frac{1}{tan(x)}[/itex] yields holes at y=1 and y=-1. What other way is there to graph it?
What does that graph have to do with anything? In particular, what does tan(x) have to do with anything? You are asking about the equation csc(x)+ cot(x)= 1. At [itex]x= k\pi/2[/itex], csc(x)= 1 and cot(x)= 0. THAT'S what you should be graphing.
He was graphing the original equation in order to see where it equals 1.
[itex]\frac{1}{tan}[/itex] is cotan, and until my TI-84 magically grows cot, sec and csc buttons that's how I'll have to graph it.
If you know half angle formulas, then your original equation reduces to:
[tex] \csc x + \cot x = \frac{1 + \cos x}{\sin x} = \frac{2 \, \cos^2 \frac{x}{2}}{2 \sin \frac{x}{2} \cos \frac{x}{2}} = \cot \frac{x}{2}, \ \cos \frac{x}{2} \neq 0[/tex]
You may check that when:
[tex] \cos {\frac{x}{2} } = 0 \Leftrightarrow \frac{x}{2} = \frac{\pi}{2} + n \, \pi \Rightarrow x = (2 n + 1) \pi[/tex]
then
[tex] \sin x = \sin \left[ (2 n + 1) \pi \right][/tex]
so there is no loss of solutions by canceling with [itex]\cos ( x/2 )[/itex]. On, the other hand, if you multiply the equation by [itex]\sin x[/itex], and convert it as you did to:
[tex] \sin {x} - \cos{x} = 1[/tex]
you may see that [itex]x = (2 n + 1) \pi[/itex] are solutions of this equation, whereas they are not for the original equation.
I can tentatively follow your logic, but I'm still not clear on what the solution is. Is the answer x= [itex]\frac{∏}{2}[/itex] [0,2∏) or no solution? If my simplification generated an invalid answer then surely yours did as well because neither works in the original equation.
[tex] \cot \frac{x}{2} = 1[/tex]
has the solution:
[tex] \frac{x}{2} = \frac{\pi}{4} + n \pi \Rightarrow x = \frac{\pi}{2} (4 n + 1)[/tex]The set of solutions:
[tex] (2 n + 1) \pi = (4 n + 2) \frac{\pi}{2}[/tex]
is not of the above form, so do not need to exclude any of them.
What was your question?
Also, I'm not sure about x=∏/2 [0,2∏) a couple posts ago.
Dickfore did get the correct general solution of [itex]x=\frac{\pi}{2}(4n+1)[/itex]
I also managed to rewrite the original equation as sinx - cosx = 1, but this has one set of solution, x = 2πn + π, which doesn't work for the original equation.
Again, my question is..
