Proving three points are collinear using vectors
11 replies · 6K views
Natasha1
The diagram shows parallelogram ABCD. (you don't really need the diagram)
vector AB= (2 above, 7 below) and vector AC= (10 above, 11 below)
The point B has coordinates (5, 8)
(a) Work out the coordinates of the point C.
The point E has coordinates (63, 211)
(b) Use a vector method to prove that ABE is a straight line.
I did this:
So
5-2 = 3 and
8-7 = 1
So point A (3, 1)
So
10+3 = 13
11+ 1 = 12
The coordinates of the point C are (13, 12)
I did this:
I know I need to prove that ABE a collinear by proving that vector AE is a multiple of vector AB
2 x (63/2) = 63
7 x (63/2) = 220.5
I'm sure there's a better way? But how? Please help...
But I'm a very visual person! Please use the UPLOAD button in the lower right of the Edit window to attach the diagram (in PDF or JPEG format) to your OP or as a reply. Thanks.
Yes! So what is the vector AE? What is the vector AB? Can you express AE = k * AB, where k is some scalar constant?
Well AE = 31.5 x AB
Is that it?
How do you find the vector from point A to point E?
I think you are confusing points with the vectors between points.
"The point E has coordinates (63, 211)". This could also be thought of as the vector from the origin (0,0) [let's call that point O] to E. So the vector OE = (63,211).
Point A is (3,1), so the vector OA = (3,1) [or (3 above, 1 below)]. Point B is (5, 8), so the vector OB = (5,8)
"vector AB= (2 above, 7 below)" This is AB = OB - OA, you could also think of this as point B - point A.
So, what is the vector AE then?
Is AB not BO + OA?
I get
AE = OE - OA
= (63, 211) - (3, 1)
= (60, 210)
How does this prove that ABE is a straight line?
Natasha1 said:
Is AB not BO + OA?
No. The vector notation AB means a vector that starts at point A and ends at point B. The vector sum BO + OA will give the vector BA, not AB. You may also think of this as going from B to O then from O to A which is that same as going from B to A.
Also note that the vector AB = -1*BA, so OA +BO = OA - OB = BA.
Natasha1 said:
I get
AE = OE - OA
= (60, 210)
Yes, AE =(60,210) is correct. You also know that AB = (2,7).
As you said before "I need to prove that ABE a collinear by proving that vector AE is a multiple of vector AB".
So can you find a number k that satisfies AE = k*AB? This is the same as saying that AE is a multiple of AB.
Ah yes yes yes!
AE = 30 x AB
Thanks so much DaveE. Super helpful... Much appreciated!
