QG five principles: superpos. locality diff-inv. cross-sym. Lorentz-inv.
  • Context: Graduate
  • Thread starter Thread starter marcus
    Locality
139 replies · 23K views
BTW I appreciate your helping me engage with this paper, a lot. Having someone to talk to about it gets me revved up and I read a lot more attentively. Thx!
I'll try to respond to your point #2, if I can. The cosmo constant one, where you said "?"
For sure the cosmo const does introduce a length. Lambda is an inverse area, so you take the sqrt of the reciprocal of the cosmo const and you immediately have a length. As I recall it is around 10-15 billion lightyears, don't remember exactly.
And the cosmo const also causes there to be a cosmic event horizon, which is around 15-16 billion LY.
If there is someone today in a galaxy that far away, we could never send them a message. Even traveling at speed of light it would never get there. And if they waved at us, today, we would never see it even after trillions of years. That's the meaning of the cosmo EH. You may already be quite familiar with it. It exists because of accelerating expansion. Without that, there woud be no EH. It is not the same as the "Hubble radius" which would exist regardless.
We see things today that are much farther than that. The material that emitted the CMB is now about 45 billion LY, so we are seeing stuff that is that far away, but as it was a long time ago and nearer. The cosmo event horizon is a limit on seeing events that happen TODAY.
So there definitely is a length scale associated with Lambda. I don't remember exactly what it is, only approximately.
I haven't figured out what C.R. means by "puts in a box".
EDIT: Probably he means the cosmological event horizon as the box---a maximal distance of things which can affect us. I don't however have a concrete grasp of this as yet.
MTd2 said:
...I am waiting Marcus to open a thread about Rovelli's new paper. It seems to be the best paper of this year, in my opinion. But I want him to give an explanation, to be sure of that.
MTd2 thanks for reminding people of the new Rovelli Smerlak paper! It fills in a detail for the main October paper. You see very clearly how the plan of exposition operates. The two main 2010 papers (at least so far :biggrin:) are
1004.1780 (which this thread was begun to discuss)
and then 1010.1939 (which repeated the same overview, this time more for mathematicians and physicists outside the Loop community.)
You may remember the concise paragraph in Section IV-A, near the end, which says exactly what the new Rovelli Smerlak say, but in much more detail with all the steps of the argument shown.
The Rovelli Smerlak paper that you call attention to is the expansion of that paragraph at the end of section IV-A in the main October paper 1010.1939.
Rovelli's new paper, which MTd2 calls attention to is:
http://arxiv.org/abs/1010.5437
Spinfoams: summing = refining
Carlo Rovelli, Matteo Smerlak
5 pages
(Submitted on 26 Oct 2010)
"In spinfoam quantum gravity, are physical transition amplitudes obtained by summing over foams, or by infinitely refining them? We outline the combinatorial structure of spinfoam models, define their continuum limit, and show that, under general conditions, refining the foams is the same as summing over them. These conditions bear on the cylindrical consistency of the spinfoam amplitudes and on the presence of appropriate combinatorial factors, related to the implementation of diffeomorphisms invariance in the spinfoam sum."
Actually we were already discussing the summing=refining theme earlier in this thread! It was in post #117 and in Atyy's comments leading up to that:
marcus said:
Atyy let's lay it out (what you mentioned) and have a look. Here's the October "Simple Model" paper http://arxiv.org/abs/1010.1939
Here's the reference to the forthcoming paper that you mentioned
[68] C. Rovelli and M. Smerlak, “Summing over triangulations or refining the triangulation?” To appear.
Here is the passage where the paper is cited. The all-important concept here is the concept of a projective limit. I first encountered this in an upper division math course in pointset topology, taking the limit where the index is not the natural numbers but is a partially ordered set---like subsets ordered by inclusion or like vector subspaces. We were using a Bourbaki book and John Kelley's topology text.
==quote page 6==
A. Physical amplitudes, expansion and divergences
Physical amplitudes.
Consider the subspace of HΓ where the spins jl vanish on a subset of links. States in this subspace can be naturally identified with states in HΓ′ , where Γ′ is the subgraph of Γ where jf ≠ 0. Hence the family of Hilbert spaces HΓ has a projective structure and the projective limit
H = limΓ→∞ HΓ is well defined.
H is the full Hilbert space of states of the theory. It describes an infinite number of degrees of freedom.5
In the same manner, two-complexes are partially ordered by inclusion: we write C ′ ≤ C if C has a sub-complex isomorphic to C ′ ...
==endquote==
These two-complexes C, analogously to graphs Γ, are purely combinatorial objects (connectivity and adjacency relations described on abstract sets.) He's got a partial order now on two things---both the graph hilbertspaces and the unlabeled spinfoam frameworks (two-complexes, the bare plot-outlines of a story).
Now he's going to explain that you get the same result taking the projective limit (expanding or "refining" the graphs) as you do by summing all the possible foam histories.
==continued quote==
The transition amplitudes Z (hl ) are defined on H.
These same transition amplitudes can be defined summing over all two-complexes bounded by Γ.
In spite of the apparent difference, these two definitions are equivalent [68], since the reorganization of the sum (26) in terms of the sub-complexes where jf ≠ 0 gives (27). The sum (27) can be viewed as the analog of the sum over all Feynman graphs in conventional QFT. Thus, the amplitudes (4) are families of approximations to the physical amplitudes (26).
==endquote==
It's clear that reference [68], "to appear" is the paper that MTd2 would like us to discuss, but with an earlier title.
I see I was careless in my language here. Refining graphs is analogous to refining 2-complexes (which are graphs-analogs in one higher dimension) but not the same. Rovelli is talking about refining the 2-complexes having the same end result as summing over the 2-complexes.
Let's have a look at the 1010.5437 paper "summing=refining". It does look kind of abruptly illuminating---getting things into focus for us. MTd2, you could be right in your high estimation of it! It makes one realize clearly that a spin network is not a lattice. It is not an approximation as the nonexistent "lattice spacing goes to zero". It IS itself A GEOMETRY, but a geometry with finite complexity. Refinement, then, does not mean to make more continuous, but to allow more geometrical complexity.
I'll print out 1010.5437 and have a closer look, MTd2, as you suggested.
What impressed me it is something very startling, spin foams is now almost kind of CDT! :cool: Think about the consequences.
Yes, I was waiting for this paper. But now I am completely confused. I had thought that refining was like "renormalization" (group field theory?). But according to Rovelli and Smerlak, refining is like summing, at least under the adjustments in this paper. However, I think some sort of "renormalization" is still needed, since the physical inner product is divergent - but apparently this "renormalization" this is not equivalent to refinement - in which case, what is it?
Let's think concretely and pictorially about it. 2-complexes (foams) are just the 2D analogs of graphs. So let us think about graphs instead. And try to understand the words in the sense in which Rovelli means them.
To refine a graph means to add more nodes and links. One can refine a graph by various "moves". Break a link and add a node at the break. Add a link connecting two nodes that were not connected before. Take a node where 3 links come together and replace it by a triangle in the obvious way (by 3 new nodes and 3 new links)...and so on.
I am oversimplifying. In the real case we are talking about foams (2-complexes) and there are specified legal moves used to refine them. But I just want to give the rough idea of what refining means. Basically adding nodes: If N is the number of nodes, you can refine so that N --> infinity.
And then there is summing. Where you don't change any graph---you sum over all the graphs. Add up the amplitude for each graph to get the total amplitude (or whatever number is to be computed.)
In one case it's like the limit of a sequence---in the other it's like the sum of a series.
The upshot, unless I'm mistaken, is that refining is not "like renormalization"---I don't quite understand your conception of it. And also refining and summing are different. But you say "refining is like summing". I think the point is not that they are alike, but that the two different procedures give the same answer, give the same amplitude as a result.
Who says "the physical inner product is divergent"? This is a non-perturbative approach. Who says that something like "renormalization" has to play a role here? I thought renormalization is something that comes up in conventional perturbation theory when there are infinities. Lqg is not plagued by infinities AFAIK :biggrin: Finiteness was explained, for instance, in Rovelli's talk to Strings 2008.
I see he calls the the potentially divergent radiative corrections at fixed N "renormalization", and the potentially divergent N -> infinity the "continuum limit", whereas I had considered both to be renormalization. OK, let me use his language, since I agree with the substance.
Renormalization:
http://arxiv.org/abs/1010.1939 "radiative corrections renormalize the vertex amplitude."
http://arxiv.org/abs/0810.1714 "Self-energy and vertex radiative corrections in LQG ... At fixed N, the partition function of the theory is given by a sum over spins and intertwiners, which can be interpreted as a version of the Misner-Hawking 'sum over geometries' ... This sum may contain divergent terms. Here we study these terms."
Continuum limit:
http://arxiv.org/abs/0810.1714 "The theory is first cut-off by choosing a 4d triangulation N of spacetime, formed by N 4-simplices; then the continuous theory can be defined by the N -> infinity limit of the expectation values."
http://arxiv.org/abs/1010.5437 "III. THE SPINFOAM CONTINUUM LIMIT ... infinitely refining C, and summing over C. Since the set of foams is discrete, the latter option is easy to define in principle, at least if one disregards convergence issues. But what about the former? It can too ..."
From what you said earlier I gathered you were talking about IR divergences---not UV, but those that might arise over large distances. So I'll respond to that. That's an area where there is still stuff to work on! Earlier I didn't realize you meant InfraRed. The status is summarized in the October paper 1010.1939, page 6, section 5A
==quote==
Divergences.
There are no ultraviolet divergences, be-
cause there are no trans-Planckian degrees of freedom.
However, there are potential large-volume divergences,
coming from the sum over j . In ordinary Feynman
graphs, momentum conservation at the vertices implies
that the divergences are associated to closed loops. Here
S U 2 invariance at the edges implies that divergences are
associated to “bubbles”, namely subsets of faces forming
a compact surface without boundary [20, 72–75]. Such
large-volume divergences are well known in Regge calcu-
lus, and can be visualized as “spikes” of the 4-geometry.
Spikes are likely to be effectively regulated by going to
the quantum group. It is commonly understood that the
q-deformation amounts to the inclusion of a cosmological
constant. This is consistent with the fact that q-deformed
amplitudes are suppressed for large spins, correspond-
ingly to the fact that the presence of a cosmological con-
stant sets a maximal distance and effectively “puts the
system in a box”. Whether divergent or not, radiative
corrections renormalize the vertex amplitude...
==endquote==
Oops I edited my post #127 while you replied. As a matter of fact, the quote of mine you quoted is factually wrong, I have corrected it.
The reason I was calling Rovelli's "continuum limit" renormalization is that I was thinking in terms of what Rivasseau calls "group field theory renormalization". Whereas Rovelli's renormalization is what one might call "spin foam renormalization".
http://arxiv.org/abs/0906.5477
"There are now interesting such spin-foam models [30, 31, 32, 33], hereafter called EPR-FK models, which in four dimension reproduce Regge gravity in a certain semiclassical limit [34, 35]. There are also some glimpses that they might be just renormalizable [36]. These spin-foam models, however, capture only a finite subset of the gravitational degrees of freedom, and the question arises of the existence of a ‘continuum limit’. As the spin-foam amplitude can always be interpreted as a Feynman amplitude of a suitable GFT [37], this question boils down to the problem of renormalization in GFT ..."
If OK with you I will just eliminate the quote which you say had an error. Then my post won't seem to make as much sense because the quote that I was responding to won't be there, but that's OK.
Sure, of course - but you can keep it too, since I did write that. I would have put my correction in a later post had I known you were replying already.
It's a partial analogy with what we know and think of as renormalization. Instead of the "cutoff" being a quantity like a length or an energy, the "cutoff" is a type of complexity.
But it is not like a perturbation series where there are infinities staring you in the face that must be eliminated by actually fiddling with the couplings (the original meaning of "renormalize"). There are no infinities here waiting to bite you when you turn around.
It is just a way of organizing a calculation. Nature always has infinitely many terms to add up and we can only add up a finite number of them. So we add up the N simplest terms and approximate.
Rovelli begins a relevant section by reminding us "There is no physics without approximation." So you add up as many terms as you have time for. There is no fiddling.
If I remember, that was also what Rivasseau was doing. Grading by complexity, and truncating. Simply in order to make a calculation feasible in a finite number of arithmetical steps.
There is a big difference in principle between a calculation which is inherently convergent, so you can do a finite number of terms and it automatically approximates the answer. Versus a calculation which actually blows up and tries to give you infinite quantities, so you have to fiddle.
So I would not like to call what Rovelli is doing with spinfoams "renormalization". It is too likely to mislead people who know the usual meaning of the word. It is more like just taking the approximate limit of a sequence numerically, or numerically summing an ordinary calculus series.
I would call it "complexity graded approximation"---or "simplest-first convergent approximation".
(and so far it is just in UV, as you have reminded me, still plenty to do IR-wise!)
No, I don't think so. There are potential divergences that need to be taken care of.
There are the IR divergences which Rovelli talks about in terms of renormalization or radiative corrections - I'll call this spin foam renormalization.
Then there are N -> infinity, continuum limit divergences (I think of these as UV divergences in spirit, although as Rovelli says, technically speaking there are no UV divergences - however, he does agree that the continuum limit divergence potentially exists), which I understand to be related to group field theory renormalization.
BTW, renormalization is not fiddling - historically that's what it was - but not after Wilson. I think the next question is whether the GFT that yields EPRL/FK (or any GFT) is asymptotically safe.
Now I was the one who didn't see yours---had to get up for phonecall with the last sentence not done yet :-D
The renormalization group flow does the fiddling for you automatically. So don't call it fiddling if you like (but the coupling constants still run. :-D)
BTW in hardly more than a week Bianchi will give a talk at Perimeter. Do you recall the date? I'll look it up. He has been an important contributor to the formulation presented in the April and October papers.
Also I was impressed by the 60-page "tutorial" on gauge gravity that Randono posted today.
I didn't know Bianchi was giving a talk, look forward to seeing it when it's posted.
Yes, I'll have to read the Randono stuff.
So Matt Smerlak's on the GFT renormalization paper and the N -> infinity, continuum limit paper. It's clear from eg. his GFT renormalization paper or Perini et al's earlier work on radiative corrections that the N -> infinity limit was already regarded intuitively as a continuum limit, and this new paper makes the intuition rigourous. (But at odds with Kaminiski et al's method of defining a continuum limit?)
The N -> infinity limit is potentially divergent, and what does the final sentence of the GFT rernormalization paper http://arxiv.org/abs/0906.5477 say?
"Our method shows how the 'sum over triangulations' in quantum gravity can be tamed rigorously, and paves the way for the renormalization program in group field theory." :smile:
Bianchi's talk will be at this URL:
http://pirsa.org/10110052/
He's scheduled to speak on 9 November. ( I thought earlier but just checked.)
"...and paves the way for the renormalization program in group field theory."
What could they mean by that? When matter is included? IR limit?
Some imprecision of language, perhaps. I won't argue about what Rivasseau means, just wait and see what actually happens.
My interpretation is that no one knows how to renormalize *any* group field theory. If GFT renormalization is worked out, then it will become a class of quantum theories (just as QFTs are another class), perhaps one of which will be a theory of pure gravity, or gravity+matter or gravity unified with matter.
wrt http://arxiv.org/abs/1010.5437
There are interesting comments in the final part of this paper about compatibility of the proposed modifications to EPRL and GFT http://arxiv.org/abs/1010.5227
Also interesting is http://arxiv.org/abs/1010.4787
All talk about some sort of cylindrical consistency requirement.
I think it will be interesting to find out if GFT or canonical LQG is fundamental. I think the former would push towards unification, the latter maybe would link up with Asymptotic Safety of pure gravity.
Rovelli's April 2010 "New Look" paper was the original basis for this thread. It has now been rewritten, expanded by over 50%, and given a new title: "Lectures on Loop Gravity".
The immediate purpose of "Lectures" is to go along with the 8 hours of lecture Rovelli is scheduled to give at Zakopane March 1 thru 6, this year. The style is in large part pedagogical explaining things that a journal article might assume the reader knows. If "Lectures" continues to be expanded and improved, it could turn into a set of notes on the new formulation of Loop Gravity that could serve as an entry-level textbook.
Interestingly enough, the list of 17 open problems which researchers are invited to tackle is word-for-word unchanged except that it is noted in several cases where progress has occurred, or where a problem has been solved.
The new version is
http://arxiv.org/abs/1102.3660
Lectures on loop gravity
Carlo Rovelli
24 pages 10 figures
(Submitted on 17 Feb 2011)
"This is the first version of the introductory lectures on loop quantum gravity that I will give at the quantum gravity school in Zakopane. The theory is presented in self-contained form, without emphasis on its derivation from classical general relativity. Dynamics is given in the covariant form. The approximations needed to compute physical quantities are discussed. Some applications are described, including the recent derivation of de Sitter cosmology from full quantum gravity."
You may wish to compare the list of open problems given here, in 1102.3660, with the list at the end of the April 2010 paper http://arxiv.org/abs/1004.1780 . It gives an idea of the rate of progress.
I think the "Lectures" draft though still rough is a significant advance pedagogically, and we may be able to learn something from its organization. Why? Because Loop Gravity has been transformed in the past two years and has reached a new stage of development--and because some thought has gone into presenting the new formulation of the theory. The field is attracting interest and taking in new researchers---so a problem arises: how do you assimilate the new members into the community, bring them up to speed, and get them started on research in the most efficient way.
I'm going to copy the outline of the various sections of Lectures on L.G. so we can examine and try to understand the thinking behind the way the lectures are organized. It can also give us an idea of what the essential prerequisites are for an entry-level understanding of the subject.
I-Overview, general motivation, where are we in quantum gravity?
II-States and Operators
A-Elementary math: SU(2)
B-Elementary math: Graphs
C-Hilbert spaces
D-Operators
E-Spin network basis
F-Physical picture (this is one of the best sections IMHO)
G-Planck scale
H-Boundary states
III-Transition Amplitudes
A-Elementary math: SL(2,C)
B-Elementary math: 2-complexes
C-Transition amplitudes
D-Properties and comments
1. superposition principle
2. locality
3. local Lorentz invariance​
IV-Derivations
A-Dynamics
B-Kinematics
C-Covariant lattice quantization
D-Polyhedral quantum geometry
V-Extracting Physics
A-Coherent states and holomorphic representation
B-The euclidean theory
C-Expansions
1. graph expansion
2. vertex expansion
3. large distance expansion​
D-What has already been completed
1. n-point functions
2. cosmology​
VI-Conclusion
Appendix A: Open Problems (1 - 17)
Appendix B: Alternative Forms of the Amplitudes
1. Single equation
2. Feynman rules
3. Using Y explicitly
4. Spin-intertwiner basis
5. Other variants​
