jfy4 said:
Thank you very much for your responses guys, they were great. Just to clarify, do you think it would be ok for me to write the acceleration operator like this:
[tex]\hat{a}=-\frac{i \hbar}{m}\frac{d}{dt}\nabla[/tex]
Like i suggested then in the OP?
This is the in principle correct operator which one obtains via the
method given by meopemuk. With the operator also goes a method
of how to apply the operator into an observable.
The observed acceleration (which is the 4-acceleration actually)
should be real and should not contain anymore the phase information
of the wave function. The standard way of applying the operator is
(as long as [itex]\tilde{\mathcal{O}}^i[/itex] contains no higher as first order derivatives)[tex]
\left(\, \tilde{\mathcal{O}}^i~\hat{\psi} \,\right)~|\psi|^2 ~=~<br />
\frac{1}{2}\left(\, \psi^* \tilde{\mathcal{O}}^i \psi ~-~ \psi\, \tilde{\mathcal{O}}^i \psi^*\,\right)<br />
\end{equation}[/tex]This won't work however if the operator contains higher order derivatives
as is the case of the acceleration operator. A way of applying the operator
which works for a general wave function is this one:[tex]
\mathtt{A}^i\,\psi^*\psi~=~ -\frac{i\hbar}{2m}\left[~\frac{\partial}{\partial t}\left(~ \frac{1}{\psi}\frac{\partial \psi }{\partial x^i} - \frac{1}{\psi^*}\frac{\partial \psi^* }{\partial x^i} ~\right)\right] \psi^*\psi[/tex]This gives you the 4-acceleration density. Integrating over the wave-
function will give you the acceleration (average) just like integrating over
the position operator turns a "position density" into the average position.
You can find the derivation and the description in the relevant chapter of
my book here:
http://physics-quest.org/Book_Chapter_Klein_Gordon_operators.pdf
In section 10.7 you'll see meopemuk's commutator as equation (10.45),
your result as equation (10.47) and the expression above as (10.60)Regards, Hans
