Question about an 8th grade math problem
The discussion revolves around an 8th grade math problem involving the volume of a pyramid with a square base. Participants explore the relationship between the base length and height, questioning the validity of the solution provided in the textbook.
  • Participants discuss the implications of the given volume formula and the potential for multiple solutions based on varying values of base and height. Some question the assumption that the apex of the pyramid must be directly above the center of the base, while others consider the geometric properties of the pyramid's faces.
The conversation is ongoing, with participants offering insights and raising questions about the geometric configuration of the pyramid. There is a recognition of the complexity of the problem, and various interpretations are being explored without a clear consensus.
Some participants note the constraints of the problem as presented in the textbook, including the lack of specific details about the pyramid's orientation and the implications of the pieces being arranged in a cube.
murshid_islam
Poster reminded to post schoolwork-type question in the Homework Help forums.
TL;DR Summary: It seems like not enough information is given for this 8th grade math problem
For the attached problem,
let b = the side length of the square base of the pyramid and
h = the height of the pyramid
1/3 b2h = 9
b2h = 27
One simple and obvious solution is b = h = 3 (and that's the answer given at the back of the book). But there are infinitely many other solutions here depending on the values of b and h. So why choose b = h = 3? From the image, it kind of looks like the front face of the pyramid is an isoceles right triangle with the base and height being equal. If that's true, then the solution makes sense. What am I missing?
Note that only the vertical projection of each side makes an isosceles right triangle with the base and height being equal.
The leaned front faces can't be isosceles right triangles then (slant height > perpendicular-to-base height).
I believe that making the values of b and h of each of the ten wood pieces of the puzzle equal, eliminates a clue regarding their proper orientation.
Note in the picture, that each side accommodates three parts.
The leaned front faces can't be isosceles right triangles then.
I meant the front face looks vertical to me. I don't know if that is actually the case or not.
Can you clarify that a bit? I didn't understand what you wrote there.
What do you call the front face?
It is just an idea.
Just like you, I believe that the given volume of the pyramid could be achieved with unequal values of bpyramid and hpyramid.
For any of those cases, each part would also have to have unequal values of bpart and hpart, which makes me suppose that such characteristic could be used as a clue for choosing the vertical or horizontal orientation of the part.
Judging by the picture, at least all the parts in one level or layer seem to need to measure the same hpart.
This face:
What do you mean by "part"? Do you mean the faces? Or do you mean the 10 smaller pieces the puzzle consists of?
murshid_islam said:
Then, that face can’t be vertical.
Note that the height of that face is called slant in the diagram of post #2.
Also note that it is the perpendicular height the “h” computed in the shown equation of the volume.
I meant each of the 10 smaller pieces the puzzle consists of.
I'm asking myself: have I seen use of the given information 'comes with the pieces arranged in a cube' ?
There must be lots of 90 degree angles on the pieces ...
8th grade ?
I'm not getting why a pyramid with a square base cannot have its apex directly vertically above one of the corners of the square. Can you explain?
I can't think of a use of that information.
BvU said:
8th grade ?
Yes, the problem is from the book "MYP Mathematics 3: A Concept-Based Approach" by David Weber, Talei Kunkel, Rose Harrison and Fatima Remtulla
It can.
I may be wrong, but I have assumed that the picture shows the apex centered on the base.
Look at the apex single piece.
Copied from:
https://en.m.wikipedia.org/wiki/Square_pyramid
“If the apex of the pyramid is directly above the center of the square, it is a right square pyramid with four isosceles triangles; otherwise, it is an oblique square pyramid. When all of the pyramid's edges are equal in length, its triangles are all equilateral. It is called an equilateral square pyramid,...”
Lnewqban said:
It can.
Copied from:
Since the problem did not specify it's a right square pyramid, I assumed it doesn't necessarily have to be one and that it could be an oblique square pyramid.
Perfectly possible.
murshid_islam said:
This face:
Yes, I agree. That face looks to be vertical. Also, the face that's viewable in that same image, and which is adjacent to indicated face also looks to me to be vertical. These two faces share a common edge, which is the altitude of the pyramid. Not only are these two faces perpendicular to each other, they both are perpendicular to the square base and furthermore, each is perpendicular to the oblique face it intersects along an edge. It seems to me that having all these surfaces with these perpendicular relationships is needed because, the same pieces go together to form a cube.
Up to this point, there is no reason to set ##h=b=3\,\rm{cm}##. But having ##h=b=3\,\rm{cm}## makes the numbers work out nicely. However, there is an additional interesting feature of such a square oblique pyramid for which ##h=b##. If we take three such pyramid's, we can place them together in such a way that they form a cube. This cube has a volume of ##h^3## or equivalently ##b^3## or in or our case, a volume of ##3^3=27\,\rm{cm}^3##.
That's some 8th grade math problem !
The answer in the book is wrong.
In order to tessalate to form both a cube and a pyramid it is necessary to rotate the pieces relative to each other and so the triangular faces of the pieces must have rotational symmetry. They must therefore be equilateral triangles, and so therefore are the triangular faces of the pyramid.
After two applications of Pythagoras we find that ## b = 3\sqrt[6]{2} \approx 3.37\text{ cm}, \, h = \frac{\sqrt{2}}{2} b \approx 2.38\text{ cm} ##
Edit: for a better image see https://www.wickeduncle.co.uk/childrens-presents/great-pyramid-of-giza-puzzle
I did not follow that. Can you elaborate a little?
Also, is a regular 8th grader supposed to know that?
I agree with you. That explanation is well beyond 8th grade level.
I doubt that the puzzle in the link can be made into a cube.
A square pyramid is always 1/3
the size of the cube.
Everyone making it so complicated lol.
And since the cube is clearly 3 on a side, put that in the formula for a pyramid. Or just put 7
There are not infinite answers, there are clear equations given.
If the cube has side 3, its area is ##6L^2=54##. Then ##(1/3)54=18 ##.
They asked for the dimensions and volume not the area. Read the OP
Otherwise correct :)
kickaxe said:
A square pyramid is always 1/3 the size of the cube.
I'm not getting how that helps. The problem statement says that 1 cube is to be rearranged into 1 square pyramid.
The cube has a volume of 9 cm3
  • · Replies 16 ·
9K
