Question about showing that a set is a vector space
2 replies · 3K views
brinethery
Hi everyone,
I keep seeing in textbooks and examples online that when someone proves that a set is a vector space, they only use a few of the axioms to prove it.
Is there a general guideline for when to use all of the axioms, and when you only need to use select ones to prove that a set is a vector space?
Obviously, you only need one axiom to prove that a set isn't a vector space. But for sets that are vector spaces, I'm not sure.
Finally, if you have a good example of proving that set is a vector space using all axioms, I would really appreciate it if you could post that as well :-)
brinethery said:
Hi everyone,
there are 2 different situations, which you are probably thinking "are the same".
1) to prove an arbitrary set, along with a given addition operation and scalar multiplication is a vector space, one must verify every axiom. there is no short-cut for this situation.
2) to prove a subset of a given vector space is a subspace, it suffices to verify only 3 conditions:
a) closure under vector addition
b) closure under scalar multiplication
c) being non-empty (or, equivalently, containing the 0-vector of the parent space).
why does verifying a "subset is a subspace" require only checking these 3 things?
well, suppose we have a vector space V, and S is some subset we think MIGHT be a vector space in its own right.
if u and v are 2 elements of S, then u and v are also 2 elements of V, and IN V:
u+v = v+u, so we don't need to check commutativity of addition again for S.
the same goes for: associativity of vector addition, and the two "distributive" laws. also, if 1v = v, for every v in V, it certainly still holds for those v that are merely in S (S is, after all, a subset of V). so what does that leave us with?
well, we must check that "+", restricted to S, is a valid binary operation on S, that for u,v in S, u+v is still in S (so S is "self-contained" as a vector space). a similar consideration holds for a scalar c, and an element v in S: we require that cv also be in S.
in particular, closure of scalar multiplication tells us that if v is in S, then so is (-1)v. and closure of addition tells us that:
v + (-1)v = (1 + -1)v = 0v = 0 is also in V...provided that "something" (the "v" we postulated to begin with) is indeed in S to start with (the empty set can NEVER be a vector space, for it has no additive identity).
from the above discussion, you can see that the 3 criteria i gave earlier automatically give us an identity for S (which is the same 0-vector V has), and additive inverses.
long story short: it depends on whether you have a parent vector space you can appeal to, or you don't. if the closure rules are satisfied, subspaces inherit many properties from the parent space.
For an easy counter example, show that the set of points in R^2 with first coordinate identically 1 , i.e., the set of points S:={(1,b), b real} is not a vector space. Check against Deveno's axiom #2 .
