Question about the absorption of heat based on color
  • Context: Undergrad
  • Thread starter Thread starter timeuser84
The discussion revolves around the relationship between the color of clothing and its heat absorption properties, particularly focusing on whether darker colors, such as black, absorb more heat than lighter colors. Participants explore various aspects of this topic, including the effects of different parts of the light spectrum on heat absorption and the implications for clothing choices in different conditions.
  • Some participants assert that dark clothes, like black, will warm up more in direct sunlight compared to light-colored clothes.
  • One participant explains that the color of clothing corresponds to the visible light reflected, with unreflected light converting to heat, which can warm the wearer.
  • Another participant introduces the idea that absorptivity and emissivity are related, suggesting that color may not significantly affect heat absorption, but acknowledges the complexity of the solar spectrum.
  • It is noted that black clothing may absorb visible light better but could also radiate infrared heat more effectively.
  • Participants discuss the role of material thickness as an insulator and the impact of environmental conditions on heat transfer, particularly in relation to body temperature regulation.
  • There is mention of the importance of clothing design, such as loose-fitting garments, in facilitating heat loss through sweat evaporation.
Participants express differing views on the extent to which color affects heat absorption, with some suggesting that color plays a significant role while others argue that other factors, such as material properties and environmental conditions, are equally or more important. The discussion remains unresolved regarding the definitive impact of color on heat absorption.
Participants highlight the complexity of the topic, noting that factors such as the solar spectrum, material properties, and environmental conditions can influence heat absorption and transfer, which complicates any straightforward conclusions.
timeuser84
Hello there all, long time. I am not sure where to ask this question so If I am in the wrong area of forum, I ask that the moderator or administrator move this thread to the correct one please.
Is it true that any clothes you wear depending on the color will absorb heat because its black? For example if you wear black socks, will the black socks absorb heat more because its black or a dark color?
Science news on Phys.org
Direct sunlight will tend to warm up dark clothes more than light colored clothes.
Three different parts of the spectrum need to be considered.
1. Ultraviolet, UV.
2. Visible light colour.
3. Infrared, heat, IR.
The colour of clothing you see, is the colour of the visible light that is reflected from the clothing. Visible light that is not reflected becomes heat in the cloth. Some of that is radiated, while some will warm the wearer.
The reflectivity of the cloth to IR and UV cannot be seen by our eyes, but any IR or UV absorbed, will also heat the cloth.
Black clothing will absorb visible light better, but black may also radiate IR better. Material thickness will act as an insulator between your body and the environment. At night, you may want to stay warm.
Absorptivity at any frequency will be the same as emissivity at the same frequency. That 'could' imply that the colour would make no difference but the solar spectrum is wider than the visible spectrum and what goes on beneath the surface is as important as just on the surface.
This could be very relevant and we would have no clue by just looking at the fabric colour. In a simple model, the white and black cloth would reach the same equilibrium temperature and feel the same to the wearer. Left in a vacuum under sunlight this would happen. However, heat energy can go both ways from the fabric so the above 'ideal' description won't apply and the actual heat energy available to warm up the skin under a shite shirt will be less so the equilibrium temperature of the body will be lower (we have cooling mechanisms to help that).
Black socks are largely out of the direct sunlight and they get IR radiated from inside your clothes and also heat transfer by convection and conduction (ditto, your underclothes) so, in very hot conditions, you may be better off with insulating underclothes - unless you are active when you actually need to lose heat. Loose clothing of any colour will allow sweat to do its work. . . . . and so it goes on.
This was more than enough knowledge, thank you for the quick responses.
  • · Replies 101 ·
9K
  • · Replies 30 ·
  • · Replies 19 ·
18K
