Is the Quotient of Two Operators AB-1 or B-1A?
  • Thread starter Thread starter wasi-uz-zaman
    Operators quotient
The discussion centers on the ambiguity of the notation A/B for two operators A and B, with participants debating whether it should be interpreted as AB^-1 or B^-1A. One participant asserts that A/B is conventionally read left to right, leading to the conclusion that it equals AB^-1. However, others argue that this notation is not precise and can be misleading, especially in non-commutative algebra. The conversation also touches on cultural considerations regarding reading direction, highlighting the complexity of mathematical notation across different languages. Ultimately, the consensus is that using A/B can lead to confusion and should be avoided in non-commutative contexts.
wasi-uz-zaman
HI, Suppose there are two operators A and B , We have to find A /B - Will it equal to AB-1
OR B-1 A , Because i have read that it equals to AB-1 , BUT i could not find reason for that.
thanks
There is no reason - its just A/B is read left to right so you tend to write it as AB^-1.
Thanks
Bill
I think that arab physicists will not be convinced by this answer!
Likes Nugatory
Who asks you this? I have never seen this notation and I think it isn't used precisely because it is ambiguous.
Generally in abstract algebra, \frac{x}{y} is a shorthand notation for xy^{-1} in the case that the algebraic structure is commutative. If the structure is not commutative, it simply isn't used.
I'd like to second kith's opinion. Do not use \frac{x}{y} unless you are dealing with commutative objects. At best, it would be confusing, in other cases, it would be simply wrong. Note, for example,that xy^{-1} and y^{-1}x are not even the only things this could possibly mean. Who says it should not be y^{-1/2}xy^{-1/2} or something entirely different?
hello , i have read this in BOOK " QUANTUM MECHANICS CONCEPT AND APPLICATION" (SECOND EDITION) BY Zettili , on problem 2.12 on page 147.
how do you know i am arab
Thanks"
Bill
hello i have read this in book " quantum mechanics concepts and applicatiotion" by zettlii page 147 2nd edition
He doesn't. Naima was pointing out that Bhobba's answer wouldn't be particularly helpful to someone whose native language is written right-to-left, and Arabic is the first example that came to mind.
Likes bhobba
You are right.
Israeli also write from right to left and up to down.
It becomes more complicated with traditional japonese.
Things can be read from up to down and then from right to left so ## \frac {x}{y}## has no asymmetry.
  • · Replies 27 ·
  • · Replies 0 ·
