Reach X: Find the Path Without Going Through Black Spaces
  • Thread starter SeththeBaller
    Path
3 replies · 3K views · last reply
SeththeBaller
How many different ways can I get to the square marked with X if I can't go through the black spaces?
http://i.imgur.com/HCSoD.png
This is the original image. Essentially, how can I get to X abiding by checker rules (a piece can only move diagonally forwards by one square at a time by only moving on the white squares. How many paths are there in total?
I counted two, because in order to get to the square directly beneath you, you must go either left then right or right then left. After that there is only one path to the x.
There is no way to go around the black squares to the left.
This is correct, right?
Hi SeththeBaller! :wink:
SeththeBaller said:
… Essentially, how can I get to X abiding by checker rules (a piece can only move diagonally forwards by one square at a time by only moving on the white squares. How many paths are there in total?
Grid of 8 rows by 8 columns of alternating white and gray squares, with two black squares in the upper middle, a black oval token at the top with two arrows pointing diagonally down, and an X in the bottom row.
Yep, looks like it! :smile:
Me, too. All (i.e., both) paths have to go through the white square on the right side, in the 5th row up from the lower left corner. From that square there is only one path to the X.
