Redshift vs blueshift definitions
  • Level: High School
  • Thread starter Thread starter phys-lexic
    Blue shift Shift
9 replies · 5K views · last reply
phys-lexic
i just have the two mixed up, and need an example to set it straight...
lets say you're source is a red light (height wavelength, low frequency) to green light (lower wavelength, higher frequency)... that would be a blue shift?
redshift = wavelength (H->L)
frequency (L->H)
blueshift = wavelength (L->H)
frequency (H->L)
... is that right or do i have it backwards?
Astronomy news on Phys.org
I'm not quite sure what you're asking. If a source is approaching you, it's blue-shifted. If it's receding, it's red-shifted. Think of it as compressing or stretching the waves relative to your position. Simply changing the colour of something doesn't involve a Doppler shift at all.
You are correct though that if a red laser appears as green due to doppler shift, that would be a blueshift.
phys-lexic said:
red shift = wavelength (H->L)
frequency (L->H)
blue shift = wavelength (L->H)
frequency (H->L)
in a red shift Wavelength would be shorter to longer wavelength
and f higher frequency to lower frequency
red shift higher energy to lower energy photon.
I'm not a chromatologist, so I'm not sure about this. I'm fairly certain, though, that green would not appear in a Doppler shift. It's not a normal part of the visible spectrum; it is rather a combination of blue and yellow. I can't see that a red source approaching at a significant percentage of light speed would produce it.
(I'm not sure that 'chromatologist' is an actual job title; I just mean someone who specializes in colour.)
Green (λ ≈ 530 nm) is most definitely part of the "normal" visible spectrum.
I know the concept behind the shifts, i just am not sure what they mean by an increase/decrease in wavelength... do they mean from the source to the observed or from the observed to the source... which is why i gave the example from a source it is 630nm (red) to being observed as 530nm (green), would that be considered an increase in wavelenghth or decrease in wavelength (it depends on what you consider the change to be from and to)
-i agree with doc, green light is most definitely in the "normal" spectrum
That example is a decrease in wavelength (compared to what the source is emitting) and thus is a "blue" shift.
If the source is emitting red light (630nm)--which means that someone traveling along with the source would measure the wavelength to be 630nm--and that source is moving towards you fast enough that you observe the light to have a wavelength of 530nm (green), that is called a "blue" shift, because the observed wavelength is shortened by the relative motion.
ya i was wondering if it would work 2 cause if u put a red laser through a prism u get red out of the other side , but i think with the doppler shift u could still have it look green.
