Richardson constant in thermionic emission equations
  • Level: Graduate
  • Thread starter Petar Mali
    Emission
Petar Mali
[tex]I_A=BT^2e^{-\frac{e\varphi}{k_BT}}[/tex]
We measure [tex]T[/tex] and [tex]I_A[/tex] and from that get work. If [tex]T_0[/tex] is first temperature in which we measured than
we get
[tex]\frac{I_A}{I_{A0}}=\frac{T^2}{T^2_0}e^{-\frac{e\varphi}{k_BT}(\frac{1}{T}-\frac{1}{T_0})}[/tex]
And from that we get
[tex]\varphi=-\frac{k_B}{e(\frac{1}{T}-\frac{1}{T_0})}ln\frac{I_AT^2_0}{I_{A0}T^2}[/tex]
and from that they calculate tangent like
[tex]\varphi=-\frac{k_B}{e}\frac{\Delta ln\frac{I_AT^2_0}{I_{A0}T^2}}{\Delta \frac{1}{T}}}[/tex]
What happened with [tex]T_0[/tex]?
Your question is puzzling. What is it exactly that you didn't understand? [itex]T_0[/itex] is still in all your equations. As far as I can see, nothing happened to it.
Zz.
OK! You don't have any more [tex]\frac{1}{T}-\frac{1}{T_0}[/tex]. In last equation you have [tex]\frac{1}{T}[/tex] instead.
lol.what does [itex]\Delta\frac{1}{T}[/itex] stand for? And [itex]T_{0}[/itex] occurs once more in the equation. Can you find it?
EDIT:
I think the numerator should have [itex]\Delta \ln(\frac{I}{T^{2}})[/itex] instead of what you wrote, because you are looking for the slope. Put differently, if you plot [itex]\ln(\frac{I}{T^{2}})[/itex] vs. [itex]\frac{1}{T}[/itex] (for several T's and not just two), then you should get a line with a slope proportional to the work function.
Yes I work that for several T and get graph. From that graph I must find slope. But please look at lines that I wrote. My problem is because I use
to get that work. THAT IS IN SCRIPTS. WHAT HAPPENED WITH [tex]-\frac{1}{T_0}[/tex], If that is easier for you?
