How does the von Neumann equation relate to Schrödinger's equation?
The discussion focuses on the relationship between the von Neumann equation and Schrödinger's equation in quantum mechanics. It establishes that the evolution of the state ket of a pure state is not unique due to the indeterminate phase factor, which does not affect the uniqueness of the state itself. The participants clarify that a pure state can be represented by a unit ray in Hilbert space or by statistical operators, with the latter being a more practical approach. The necessary conditions for the density operator and the implications of the smoothness assumptions are also highlighted.
  • Understanding of quantum mechanics concepts such as the von Neumann equation and Schrödinger's equation.
  • Familiarity with Hilbert space and the concept of state kets.
  • Knowledge of functional analysis, particularly in the context of quantum states.
  • Basic grasp of statistical operators and their properties in quantum mechanics.
  • Study the derivation of Schrödinger's equation from the von Neumann equation in detail.
  • Explore the properties of Hilbert space and its implications for quantum states.
  • Learn about the role of phase factors in quantum mechanics and their impact on state representation.
  • Investigate the concept of statistical operators and their applications in quantum theory.
Quantum physicists, students of quantum mechanics, and researchers interested in the mathematical foundations of quantum theory will benefit from this discussion.
TeethWhitener
TL;DR
Formalism for going from the von Neumann equation to the Schrödinger equation
I was trying to show how to get Schrödinger’s equation from the von Neumann equation and I’m not quite confident enough in my grasp of the functional analysis formalism to believe my own explanation. Starting from
$$i\hbar\frac{\partial}{\partial t}\rho=[H,\rho]$$
We have
$$i\hbar\left(\frac{\partial |\psi\rangle}{\partial t}\langle \psi| +|\psi\rangle\frac{\partial \langle\psi|}{\partial t}\right) =H|\psi\rangle\langle\psi|-|\psi\rangle\langle\psi|H$$
Collecting bra and ket terms,
$$\left(i\hbar\frac{\partial |\psi\rangle}{\partial t}-H|\psi\rangle\right)\langle\psi|=|\psi\rangle\left(-i\hbar\frac{\partial\langle\psi|}{\partial t}-\langle\psi|H\right)$$
My hand-wavy explanation is to put everything on one side and zero on the other and claim that the bra and ket coefficients have to go to zero separately. If I just had any two independent vector spaces, this explanation would suffice, but is this still true when the bra space and ket space are dual to one another? Apologies if I’m missing something obvious.
One cannot derive it without aligning the phases. One just shows that given a wave function satisfying the SE, the corresponding density operator satisfies the von Neumann equation. Assuming the initial-value problem to be uniquely solvable (which amounts to adding smoothness requirements) it is the only solution with a density operator of rank 1. But of course, the wave funcgtion's phase is not yet determined. Again one needs to make some smoothness assumption to get that.
What you can conclude from your equation is that ##i\hbar\frac{\partial |\psi\rangle}{\partial t}-H|\psi\rangle## is parallel to ##|\psi\rangle##. Call the (complex) factor ##\alpha(t)##. Write down the resulting equation and take the adjoint. Insert the two equations obtained into your equation to get a necessary and sufficient condition on this factor. But it will not be uniquely determined.
Thanks for your response! I’ll work through your suggestion when I get a moment.
Also, it’s clear from my original post (and @A. Neumaier ’s response), but I wanted to point out that I edited the summary to correctly reflect my question.
The upshot is that the evolution of the state ket of a pure state is not unique since always a maybe timedependent phase is indetermined. That doesn't affect the uniqueness of the state, because the state is not represented uniquely by the state-ket, but only the state-ket up to this indetermined phase factor.
You can formalize this by either saying that a pure state is represented by a (unit) ray in Hilbert space, i.e., a state ket modulo a phase factor (which can depend on time) or, and that's imho a bit simpler in practice, you define states generally to be presented by statistical operators, and the special case of a pure state is that it is a projector, i.e., fulfilling the equation ##\hat{\rho}^2=\hat{\rho}## in addition to the general constraints (##\hat{\rho}## self-adjoint, ##\mathrm{Tr} \hat{\rho}=1##, and positive semidefiniteness).
  • · Replies 0 ·
  • · Replies 29 ·
