Shell theorem and Mercury's precession from outer planets
  • Level: Graduate
  • Thread starter Thread starter zincshow
    Precession
38 replies · 10K views · last reply
zincshow
When calculation GR, the component due to other planets is removed. In that calculation outer planets are assumed to be rings of mass and the effect of that mass is seen to have an effect on mercury precession :
http://www.physics.princeton.edu/~mcdonald/examples/mechanics/price_ajp_47_531_79.pdf
How does this square with the idea of the shell theorem that says you do not feel a gravitational force from the inside of a hollow sphere of mass :
http://en.wikipedia.org/wiki/Shell_theorem
Thanks
Thanks
The authors of the paper abstract the other planets as circular rings , not as spherical shells
Thanks. For some reason it seemed to me that if there is no force inside a 3d sphere of mass that there would be no force inside a 2d ring of mass. I will have to think about that for a while...
You are absolutely right, look at the calculations in paragraph II, in the opinion of the authors, the ring does not behave like a shell, the resultant force is non-null. I think that the paper is wrong, and I think I know where the authors introduced an error. AmJPhys is not a model of correctness, quite the opposite.
Here is a link to how a ring's gravitational field can be derived.
"[URL
[/URL]
Here is an application to the planets.
http://farside.ph.utexas.edu/teaching/336k/Newton/node128.html"
No error here. That a ring does not act like a shell is correct.
The force is not null except at the center of the ring. Take the gradient of the potential and you will see that this is the case.
Rings are used to prove the shell theorem, but the rings are carefully constructed so that the point in question lies on the axis of each ring.
starthaus said:
Yes, this appears to be the correct solution to the problem, by using the non-null potential rather than the force. The paper is still wrong, the link you cite is correct.
I have just run through the (analytical) calculations. To the level of approximation in
the results in this reference and in
http://farside.ph.utexas.edu/teaching/336k/Newton/node127.html
are the same.
Again, you have jumped too quickly to a conclusion.
Yes, the analytic formula of the infinitesimal mass, "dm" used in calculating the resultant force for a spherical shell is different from the formula for the "dm" in a ring. This is why rings behave differently from shells. This is why a ring does not exhibit zero force, though it has the same radial symmetry as a shell.
Here is a simple visual demonstration that the gravity inside a ring is not null as inside a hollow sphere (in Newtonian terms):
Diagram of a hollow circle with a point P inside, two thin cones from P cutting out red areas A1 and A2 on opposite sides of the circle, labelled r1 and r2 from P to each area.
In the above image the particle at point P inside the hollow sphere shell is at different distances from the shell but the shell mass contained in the circular intersection of the cone on the left is greater than the shell mass intersected on the right and this difference in intersected shell mass exactly compensates for the differences in distance. The regions outside the intersecting cones are identical and trivially cancel each other out, no matter what arbitary angle is chosen for the intersecting cones. See http://galileo.phys.virginia.edu/classes/152.mf1i.spring02/GravField.htm for the source of the diagram.
If a section of the shell above and below point P (the green sections in the attached diagram) are removed, leaving an equatorial ring, then some of the compensating shell mass is removed (the light blue regions in the attached diagram) and the forces no longer cancel out. Anything in the plane of the ring, but not exactly at the centre, moves outwards as if there is a repulsive force at the centre of the ring.
  • Diagram of a green hollow sphere with a point P inside, two thin cones from P cut opposite arcs of the shell labelled Area A1 and Area A2 in red, with light blue regions marking the shell slivers that differ between the two sides.
In short, to re-echo the claims of MIT students at the 1971 World Science Fiction Convention, "The Ringworld is unstable!"
It is also important to remember that Mercury's perihelion precession was known to be anomalously large well before Einstein. (The anomaly was first reported in 1859.) Those physicists were quite adept with calculation; they had to be because they did not have those electronic marvels that we rely on (possibly overly so) these days.
Yes, it is :-)
Sure, the advancement of the perihelion was never in debate, just the approach used by the paper cited in the OP for calculating the force inside the ring. I find their approach inferior to the approach used for the shell calculation. The wiki calculation for the shell is quite elegant, makes a much better use of radial symmetry.
The proof of the shell theorem such as that in wikipedia constructs the rings so that the point in question is along each of the rings axes. That construction ensures radial symmetry.
There is no radial symmetry in this problem to take advantage of. Mercury is not located along the axis of the outer planet's orbits. It is more or less located on the orbital planes of those orbits. The projection of Mercury's location onto each of those orbital planes is not at the center of those orbits.
This is quite obvious. Nevertheless, it is easy to adapt the wiki proof for the shell to the ring. The only change required is a recalculation of the infinitesimal mass element "dm".
Try it. You're going to get something rather ugly. In fact, the integral that results does not have a simple solution. You will get what are called elliptical integrals.
This isn't homework, so if you want I can give you a link to a solution. (You probably wouldn't believe me if I the words came from my fingers. Fortunately, the solution is out there on the 'net. Besides, I don't particularly want to typeset the LaTeX with my fingers when the solution is out there on the 'net.)
Or you can try it yourself. When/if you get stuck I'll be glad to help.
Of course I believe you.
Thank you, I appreciate the offer, what I was saying is that I have already worked it out. In the wiki solution you need to replace the spherical mass element with the ring one. Everything else in the solution stays same.
D H said:
No, it does not. Show your work.
I don't like your tone. Bye.
Here's the calculation for the potential.
First some definitions. We want to calculate the gravitational potential due to a uniform ring of mass at some point. Define z as the distance between the point and the ring plane and x as the distance between the point and the ring axis. Without loss of generality, define
  • [itex]\hat x[/itex] is the direction from the center of the ring to the projection of the point in question onto the ring plane,
  • [itex]\hat z[/itex] is parallel to the ring axis, with positive z in the direction of the point in question, and
  • [itex]\hat y[/itex] completing a right-hand system ([itex]\hat y \equiv \hat z \times \hat x[/itex]).
We also need some definitions regarding the ring itself.
  • [itex]a[/itex] is the radius of the ring,
  • [itex]m[/itex] is the mass of the ring,
  • [itex]\rho[/itex] is the linear density of the ring ([itex]\rho \equiv m/(2\pi a)[/itex]).
Potential obeys the superposition principle. Thus
[tex]\phi(\mathbf x) = \int \frac{G\,dm}{r} =<br /> \int_0^{2\pi} \frac {G \rho a}{\sqrt{z^2+x^2+a^2-2ax\cos\theta}} d\theta[/tex]
This is an elliptical integral.
The above paper is definitely wrong. The resultant integral in paragraph II needs to be an elliptic integral , therefore it will not have a closed expression. The authors have inadvertently canceled out the square roods (which give the integral its elliptic charracter).
Thanks
You will get the desired elliptic integral that gives the correct answer by simply noticing that, for a ring:
[tex]dM=\frac{d \theta}{\pi} M[/tex]
Once you insert the modified expression for dM, you will get the elliptic integral that represents the resultant force along the direction that connects the center of the ring with the probe mass (in our case, the planet Mercury).
It seems to me that this not true.
Why isn't their integral an elliptic integral? Do you know the reason?
No, the authors have not "inadvertently canceled out the square roots," so this isn't the reason why their integral is not an elliptic integral.
George Jones said:
It seems to me that this not true.Why isn't their integral an elliptic integral? Do you know the reason?
I explained why. I also explained how you can modify the solution on the wiki page in order to get the correct solution for the force exerted by a ring. The solution is an elliptic integral (with no closed form). The paper authors obtained a totally different integral.
D H said:
Do you know what perturbation techniques are?
Yes.
What does your question have to do with figuring out the expression of the integral that defines the resultant force?
The planetary effects on Mercury's orbit are perturbative. The exact integral isn't needed. All that are needed to estimate these perturbative effects are first-order terms. That is what the author of the paper cited in the original post developed in equations (2) to (5) of that paper.
The author's intent in this paper is "to show that the component of the precession of Mercury's perihelion due to the outer planets can be calculated easily at the undergraduate level." He did so quite admirably IMO. The mathematics is quite simple, and yet comes remarkably close to those obtained by "more advanced treatments."
I don't know what Dicke did in Gravitation and Relativity, but I suspect he used Lagrange's Planetary Equations or some similar formulation (e.g., Dalaunay's or Hill's Planetary Equations). Computing the Poisson brackets of orbital elements is not a lower level undergraduate treatment.
This is not what we were discussing, I just showed that the correct answer is obtained by using [tex]dM=\frac{d \theta}{\pi}M[/tex] in the approach used on the wiki page. Do you have an argument with that?
That is [exactly[/i] what we are discussing. That paper is the central topic of this thread.
Yes. First, a minor correction, that should be [itex]dM=M/(2\pi)\,d\theta[/itex].
More importantly, your result is only correct when angle is measured from the center of the ring. It is not correct when the angle is measured with respect to some non-central point such as the location of Mercury.
The paper produced the incorrect formula for the force.
Incorrect: [itex]dM=M/(\pi)\,d\theta[/itex]
There are two symmetrical elements participating in the force calculation n(see the drawing on the wiki page), so :
[tex]dM=\frac{2 R d \theta}{2 \pi R}M[/tex]
It is precisely the case described in the paper and in the wiki page. The wiki description of the solution is very good, I suggest that you read it.
