Shoot a basketball with a minimum speed at some angle
McFluffy
You should shoot a basketball at the angle ##\theta## requiring minimum speed. Avoid line drives and rainbows. Shooting from (0, 0) with the basket at (a, b), minimize ##f(\theta)= 1/(a \sin (\theta) \cos (\theta) -b \cos^2 (\theta))##.
(a) If b =0 you are level with the basket. Show that ##\theta=45\deg## is best (Jabbar sky hook).
(b) Reduce ##df\over d\theta## = 0 to ##\tan (2\theta) = -a/b##. Solve when a =b.
(c) Estimate the best angle for a free throw
I have no idea on how this derived:##f(\theta)= 1/(a \sin (\theta) \cos (\theta) -b \cos^2 (\theta))##, but based on the question, it seems that this is the initial speed ##f##, as a function of angle, ##\theta##? How does one derive this?
Coming from a person that only plays basketball when friends invited to play, I don't understand the terminologies that are being used such as, "line drives", "rainbows", and "Jabbar sky hook". So the first thing I did was to google these phrases:
Line drives = a flat shot with no arc, which is a straight line from (0,0) to (a,b)
Rainbows = A type of shot in basketball which has a higher than normal arc as it moves towards the basket, so it's a parabola.
Jabbar sky hook = When you're level at the basket, you throw the ball, this video explains it:
Now that we know the terminologies(I think), we can proceed. So a straight line or a parabolic path is a no. The question first asked me to minimize ##f(\theta)##, setting ##df \over d\theta## = 0 then finding what ##\theta## to plug into ##f(\theta)## is fairly straightforward but I want to know how was ##f(\theta)## derived? I tried sketching what it would look like in the xy plane and find some clues on how to derive ##f(\theta)## but I can't find it.
Other than that,the part where I'm stuck is the formulation part. The calculus part, I can do those. So what now?
Eliminate the time from the two projectile equations and get ##y(x)##. Be sure to write the trig functions in the equation in terms of Tan(θ), then solve for v02. You will get ##f(\theta)## to within a constant which is irrelevant because you are minimizing.
On edit: Actually you don't have to express the trig functions in terms of the tangent. That becomes necessary if you want to find the angle of projection given a, b and the initial speed.
